Strange error in ROMS compiling
s.celestino
#1 Unread post by s.celestino »
Hi everyone,
I'm trying to install ROMS on a parallel cluster. I need to install NETCDF in my home directory, so I installed the netcdf-4.1.3 (with zlib and hdf5) and then netcdf-fortran-4.2. Everything went well. But after configuring ROMS I get this error in the build.bash script in the WC13 test case.
distribute.f90:2951.10:
      USE netcdf
          1
Fatal Error: File 'netcdf.mod' opened at (1) is not a GNU Fortran module file
It seems netcdf.mod is not compiled with the fortran compiler. I have used gfortran to compile both netcdf and ROMS.
Any ideas?
Re: Strange error in ROMS compiling
You should be able to check the compile logs to see if it is the same netcdf.mod that you just compiled (probably not).
s.celestino
#3 Unread post by s.celestino »
kate wrote:You should be able to check the compile logs to see if it is the same netcdf.mod that you just compiled (probably not).
Thanks for the answer. Here you will find my log file. But I'm sure it is the newest netcdf.mod (all the make check during the netcdf compiling went well).
log.txt
(514.22 KiB) Downloaded 407 times
What is the date on: /home/simone/netcdf/include/netcdf.mod?
Did you recently build netcdf-fortran as well? It is now a separate package.
s.celestino
#5 Unread post by s.celestino »
kate wrote:What is the date on: /home/simone/netcdf/include/netcdf.mod?
Today date.
$ ls -l netcdf.mod
-rw-r--r-- 1 simone users 21984 Jul 26 06:20 netcdf.mod
I compiled everything togheter. And yes I compiled also netcdf-fortran. This is the version for all the packages I have used:
zlib-1.2.8.tar.gz
hdf5-1.8.13.tar.gz
netcdf-4.1.3.tar.gz
netcdf-fortran-4.2.tar.gz
Now I'm downloading all the latest software version to verify if there is some version problem. Now I'm testing:
zlib-1.2.11.tar.gz
hdf5-1.10.1.tar.gz
netcdf-4.4.1.1.tar.gz
netcdf-fortran-4.4.4.tar.gz
s.celestino
#6 Unread post by s.celestino »
Nothing changes with the latest package. I get always that error.
Any ideas?
s.celestino
#7 Unread post by s.celestino »
I compiled netcdf with gfortran and ROMS with mpif90 (with gfortran option also), it can be this the problem?
