I am having the above run time error and I have seen already some posts about it but found no "easy" explanation for it. I am suspecting the model initial and boundary conditions files and I have a question about these. I am running a coupled physical-biogeochemical simulation and I added several variables to both the initial and boundary files. However, I noticed that these variables do not contain all the attributes of the other tracers in the netcdf file. I wonder if this may cause some problems messing with the initialization of something and thereafter causing the problems I am experiencing.
For example, the metadata corresponding to chlorophyll looks like this:
double chlorophyll(ocean_time, s_rho, eta_rho, xi_rho) ;
chlorophyll:_FillValue = 9.99999993381581e+36 ;
Whereas that corresponding to salt looks like this:
float salt(ocean_time, s_rho, eta_rho, xi_rho) ;
salt:long_name = "salinity" ;
salt:time = "ocean_time" ;
salt:coordinates = "lon_rho lat_rho s_rho ocean_time" ;
salt:field = "salinity, scalar, series" ;
salt:_FillValue = 1.e+37f ;
The error does not occur always at the same point so it seems to cause some random effect which suggests some variable not properly initialized. However, I have used all possible compile option and found nothing....
run time error forrtl: error (78): process killed (SIGTERM)
Re: run time error forrtl: error (78): process killed (SIGTE
If the attributes were a problem, I would expect a (slighty) more informative error message at the time of reading the file, not some random time later.
You're not running out of memory, are you?
Hi Kate,
Thanks for your answers. No, I don't think there is a memory problem. It seems one of those difficult errors without a consistent pattern. I guess I will have to move further back in time in the repository I am using and see if I can be sure about when the error starts to show up...
Pedro
Pedro
