creat boundary files from Hycom data
Vera
#1 Unread post by Vera »
I will appreciate it if anyone can give me some advice.
Before creating boundary files(by pycnal), I used the make_remap_weights_file.py, and the hycom grid was made by the get_hycom_GLBa0.08_Palau_grid.py. I just changed the domain.
when I run "python3 make_remap_weights_file.py", the error message is:
Traceback (most recent call last):
File "make_remap_weights_file.py", line 7, in <module>
srcgrd = pycnal_toolbox.Grid_HYCOM.get_nc_Grid_HYCOM('./HYCOM_GLBa0.08_PALAU_grid.nc')
File "/usr/local/pycnal/lib/python3.5/site-packages/pycnal_toolbox/Grid_HYCOM/get_nc_Grid_HYCOM.py", line 47, in get_nc_Grid_HYCOM
h[j,i] = depth_bnds[bottom[j,i]+1]
IndexError: only integers, slices (`:`), ellipsis (`...`), numpy.newaxis (`None`) and integer or boolean arrays are valid indices
I think there must be something wrong with the hycom grid, any suggestions?
Thanks in advance.
Vera
Re: creat boundary files from Hycom data
No, the problem is not with the HYCOM grid. The problem is that Python is getting picky as it matures. This:
needs to be:
h[j,i] = depth_bnds[int(bottom[j,i])+1]
I need to collect my current code and push the updates.
Vera
#3 Unread post by Vera »
That's very nice of you. Thank you, Kate!
I'm sorry that I didn't know python much.
Vera
#4 Unread post by Vera »
I met anyother strange problem again, please help me.
After I run make_bry_file.py, it will list all the hycom data I get,and give the following message:
Load geographical grid from file
b'/home/le/PyCNAL-master/examples/Nanhai/data/HYCOM_GLBa0.08_salt_2015_001.nc'
Creating boundary file /home/le/PyCNAL-master/examples/Nanhai/bdry/HYCOM_GLBa0.08_salt_2015_001_ssh_bdry_Nanhai.nc
multiprocessing.pool.RemoteTraceback:
  File "/usr/lib/python3.5/multiprocessing/pool.py", line 119, in worker
    result = (True, func(*args, **kwds))
  File "/usr/lib/python3.5/multiprocessing/pool.py", line 44, in mapstar
    return list(map(*args))
  File "make_bdry_file.py", line 26, in do_file
    zeta = remap_bdry(file, 'ssh', src_grd, dst_grd, dst_dir=dst_dir)
  File "/home/le/PyCNAL-master/examples/Nanhai/remap_bdry.py", line 40, in remap_bdry
    src_var = cdf.variables[src_varname]
KeyError: 'ssh'
The above exception was the direct cause of the following exception:
  File "make_bdry_file.py", line 83, in <module>
    results = p.map(partial_do_file, lst_file)
  File "/usr/lib/python3.5/multiprocessing/pool.py", line 260, in map
    return self._map_async(func, iterable, mapstar, chunksize).get()
  File "/usr/lib/python3.5/multiprocessing/pool.py", line 608, in get
    raise self._value
KeyError: 'ssh'
The first thing I'm comfused is, why the file is not a grid file after the sentence "Load geographical grid from file"? should I change this and how to change? I have no clue.
The second, which file is the target file of the function "do_file" in make_bry_file.py? I can't understand python well, sorry.
The last, how to solve my problem.
Thank you very much
#5 Unread post by kate »
Sorry, I've been playing with multiprocessing to use more than one core at a time. These are much, much easier to debug without that. Some of the examples have both the straightforward version of things as well as the multiprocessing version. See if you can find one of those to work from.
Vera
#6 Unread post by Vera »
Thank you for your reply, Kate!
I set processes = 1, but it is still the same problem.
I find the straight version in Yellow_sea example, and imitate it(still using Hycom data).The error messeage is:
File "make_bry.py", line 46, in <module>
KeyError: 'ssh'
So I think the problem maybe isn't relative to Multi-process。
#7 Unread post by kate »
It's looking for 'ssh' in the HYCOM file. What variables are in your HYCOM file? Do you know how to read the traceback? Both agree that line 40 of remap_bdry.py is in trouble. So you look at that line and figure out if it should be succeeding, or why it isn't.
Vera
#8 Unread post by Vera »
I have solved it, thank you.
prasanna1
#9 Unread post by prasanna1 »
How did you solve this? I am getting the same error while creating Boundary Condition for ROMS grid using GODAS data. Please help me to find out the error.
