Hi Forum,
I wanted to do experiments with the salinity flux, for this I want to run by making the precipitation zero and different run with evaporation zero. Will it be correct if I provide precipitation with zero values through my netcdf file?. Since I am using bulk flux how can i turn off evaporation effect on salinity.I would be grateful, if anyone can give a clue that how can I implement this. Thanking you in advance.
Regarding the salt flux experiments
Re: Regarding the salt flux experiments
I think you can just turn off the EMINUSP option to prevent evaporation.
Hi Kate,
Thanks for the suggestion, I will try that. And regarding precipitation, can I provide precipitation with zero values through my netcdf file?
Yes, or you can define ANA_RAIN.
Hi Kate,
As you suggested, I turned off EMINUSP option to prevent evaporation, but I got an error message asking for swflux as follows.
INQUIRE - unable to find requested variable: swflux
in files:
Since my experiment is with no evaporation, can i give swflux, which is (E-P) as just (-P with unit converted to cm/day from kg/m2/s)that is no evaporation? . I have switched on Bulk_Flux and i am providing all other parameters for bulk including precipitation separately.
in files:
The place to see what ROMS is needing is in get_data.F. The string swflux is in varinfo.dat, where you can see that it is tied to "idsfwf". Checking that part of get_data.F:
If you don't want EMINUSP, you might instead try ANA_SSFLUX, setting it to zero. Then you'll have to check to see if that plays nicely with your rain. If not, you'll have to modify the code.
# elif !(defined ANA_SSFLUX || defined EMINUSP || defined SRELAXATION)
! Surface net freshwater flux: E-P.
CALL get_2dfld (ng, iNLM, idsfwf, ncFRCid(idsfwf,ng), &
& nFfiles(ng), FRC(1,ng), update(1), &
& LBi, UBi, LBj, UBj, 2, 1, &
# ifdef MASKING
& GRID(ng) % rmask, &
& FORCES(ng) % stflxG(:,:,:,isalt))
Hi Kate,
I will try your suggestions and will reply. Thanks again for your support .
