easy grid
easy grid
hello. how can i download easygrid software? i am from iran and when i go to easygrid-WikiROMS site it doesnt go to download page and i can not download the software. what should i do?
Re: easy grid
Hi, maybe you can download it from here
https://code.google.com/archive/p/easygrid4roms/
I guess it's an area related issue because the page is up and working.
I've attached a file with the wiki page, so that you can at least see the instructions.
Stamatis
Stamatis
- seagrid_wikipage.zip
- Extract this and open easygrid-WikiROMS.html to view the page.
- (318.36 KiB) Downloaded 565 times
Re: easy grid
hello. thanks alot because of your reply. but i couldnt go to the page that you send the address of it... it is because of my country. can you please send me everything that i need for easygrid in zip file?
Re: easy grid
hello. i download seagrid but it is not a software to install. it is just a folder that there are alot of .m file in it. i am Amateur in seagrid and matlab. please explain me how should start with seagrid? the beginnig step?
i just install matlab R2009a. what should i do next?
this is everything that i download for seagrid. is it true and enogh? but there is not any application in it to install.
- seagrid-master.zip
- (2.4 MiB) Downloaded 648 times
Re: easy grid
I attached the two files that were in the url I sent you.
The second one is the application and the first one is probably an example.
I have not used these before, so I cannot tell about their working condition.
I build my grids with pygridgen-pyroms and never used seagrid.
Maybe you can get more help from those who do use it.
As a quick hint, after installing Matlab you will have to include the paths to all the matlab-tools you will be using, into matlab's startup file.
Then you can follow the instructions of the README.m file in the seagrid folder (basically read all the README files you can find; they are very explanatory).
I would highly recommend to use John Wilkin's PRE_processing tools (they include seagrid as well as other tools you will be needing).
- FJORD_grid_ini.rar
- (78.62 KiB) Downloaded 657 times
- EASYGRID_v0.rar
- (48.44 KiB) Downloaded 677 times
Re: easy grid
thanks alot. would you please send me mexnc,snctools,ROMS Matlab tool-kit,ocean.in files for me in a zip file? i use matlab R2009a. because it is not possible for me to download them from the website(because of my country).
kind regards,
Hoda
kind regards,
Hoda
Re: easy grid
Hello.thanks alot because of your attachments.
first:i generate ROMS grid by its example in the file (Fjord_bathy.mat and Fjord_coast.m). but it show me the grid in 2D. how can i have 3D plot? anything should change in the romsgrid.mat code?
second:what is ocean.in file?where can i find it?
- Capture.PNG (55.97 KiB) Viewed 9381 times
Re: easy grid
There are examples of the ocean.in file in the ROMS/External directory.
Re: easy grid
hello.would you please send me mexnc,snctools and ROMS matlab tool-kit for my matlab R2009a? because of my country i can not download it from the website.please.
