tide velocity problem
Rocky_Wang
#1 Unread post by Rocky_Wang »
Hello, I run the roms model with only tide forcing. We have put an ADCP into the modeled region to record the tide current velocity. When I compare the computed current velocity with observed data,I find the simulated result is smaller. which method or parameter I should adjust to increse the simulated currtrn velocity? Attachments are my H file and some paremeters about bottom boundary layer.
bhseatide.h
(1.76 KiB) Downloaded 644 times
lfparejar
Re: tide velocity problem
#2 Unread post by lfparejar »
One way could be to decrease the value of Zob in ocean.in. Zos is the surface roughness length, and you wouldn't need to tweak that here.
Another would be to decrease rdrg2, also in the ocean.in you show.
And another way could be to prescribe a constant, lower, bottom drag coefficient to increase the velocity. To do that (and if you want to keep using a quadratic drag law with the #define UV_QDRAG you have in the header file), you need to add these lines:
#define ANA_DRAG
#define UV_DRAG_GRID
Then you will need to modify and use ana_drag.h and add something like this:
#if defined YOUR_HEADER_NAME
# elif defined UV_QDRAG
DO j=JstrT,JendT ! based on Chezy coefficient (g/c^2)
DO i=IstrT,IendT
rdrag2(i,j)= *your new drag value*
I'd expect quite some testing if you want to tweak rdrag2 to match your ADCP data.
Rocky_Wang
#3 Unread post by Rocky_Wang »
lfparejar wrote:One way could be to decrease the value of Zob in ocean.in. Zos is the surface roughness length, and you wouldn't need to tweak that here.
#define ANA_DRAG
DO i=IstrT,IendT
Thanks very much, it is really helpful!
Now I want to set a constant, spatially varying bottom roughness length Z0B (m) associated with grain roughness z0N, I have the median grain size distribution data of the region that I modeled.
I know that
Z0N = 2.5 * D50 / 30
So how to modify and use ana_drag.h to achieve the goal.
#if defined MY_HEADER_NAME
# elif defined UV_LOGDRAG
DO i=IstrT,IendT
rdrag2(i,j)= *your new drag value* !Sorry I do not know how to modify there, can you give me more detaild reminder?
Chang
#4 Unread post by Chang »
hello Rocky_Wang
I meet the same problem with you.so if you have figured it out,could you please show me how to do that?
Thanks in advance.
my qq is 2454518664.
