Model blow-up after adding river discharge
I am using ROMS to simulate tidal flow in a coastal region containing a long and curved river. The grid also includes wetlands, so I have turned on WET_DRY. This setting runs smoothly to the end.
Now I want to add a point source to the upstream to account for the river discharge. I have turned on ANA_PSOURCE instead of making a Netcdf file of my own.
The related setting in ocean.in is
LuvSrc = T
LtracerSrc = F T
Related setting in ana_psource is
IF (Master.and.DOMAIN(ng)%SouthWest_Test(tile)) THEN
Nsrc(ng)=2
SOURCES(ng)%Dsrc(1)=1.0_r8
SOURCES(ng)%Isrc(1)=2
SOURCES(ng)%Jsrc(1)=368
SOURCES(ng)%Dsrc(Nsrc(ng))=1.0_r8
SOURCES(ng)%Isrc(Nsrc(ng))=3
SOURCES(ng)%Jsrc(Nsrc(ng))=368
DO k=1,N(ng)
DO is=1,Nsrc(ng)
i=SOURCES(ng)%Isrc(is)
j=SOURCES(ng)%Jsrc(is)
IF (((IstrT.le.i).and.(i.le.IendT)).and. &
& ((JstrT.le.j).and.(j.le.JendT))) THEN
IF (ubar(i,j,knew).ne.0.0_r8) THEN
cff=ABS(u(i,j,k,nnew)/ubar(i,j,knew))
ELSE
cff=1.0_r8
SOURCES(ng)%Qshape(is,k)=cff* &
& (z_w(i-1,j,k )- &
& z_w(i-1,j,k-1 )+ &
& z_w(i ,j,k )- &
& z_w(i ,j,k-1 ))/ &
& (z_w(i-1,j,N(ng))- &
& z_w(i-1,j,0 )+ &
& z_w(i ,j,N(ng))- &
& z_w(i ,j,0 ))
IF ((tdays(ng)-dstart).lt.0.5_r8) THEN
fac=1.0_r8+TANH((time(ng)-43200.0_r8)/43200.0_r8)
ELSE
fac=1.0_r8
DO is=1,Nsrc(ng)
SOURCES(ng)%Qbar(is)=fac*100.0_r8
The model only runs for 2 minutes before blow-up. The error message said,
DIAG speed trouble 24.64562562679086
DIAG speed ijk 34.85276857974117 2 368 8
When I plot the result from restart file, I can see the water level rising up from upstream. So I think I got the locations right for the point sources. Can anyone tell me how to deal with this problem?
Amy
LuvSrc = T
LtracerSrc = F T
Nsrc(ng)=2
DO k=1,N(ng)
DO is=1,Nsrc(ng)
ELSE
cff=1.0_r8
& (z_w(i-1,j,k )- &
& z_w(i ,j,k )- &
& z_w(i-1,j,0 )+ &
& z_w(i ,j,0 ))
ELSE
fac=1.0_r8
DO is=1,Nsrc(ng)
Amy
Re: Model blow-up after adding river discharge
When you specify a river inflow, you have to provide values for all of the tracers. You can't have:
without developing an instability. I'm not sure your Qshape is done in a stable fashion either.
LtracerSrc = F T
Hello Kate,
Thanks for the quick response. I really appreciate it.
Do you suggest I should change to
or
For the Qshape, I am simply using the example from riverplume1 in the ana_psource. What do you mean that it may not be stable?
Amy
LtracerSrc = T T
LtracerSrc = T T T T
Amy
I have changed the Qshape to
With
and,
The model runs for 30 minutes before blow-up. Any suggestions?
Amy
DO k=1,N(ng)
DO is=1,Nsrc(ng)
ELSE
cff=1.0_r8
& (z_w(i,j-1,k )- &
& z_w(i,j-1,k-1 )+ &
& z_w(i,j ,k )- &
& z_w(i,j ,k-1 ))/ &
& (z_w(i,j-1,N(ng))- &
& z_w(i,j-1,0 )+ &
& z_w(i,j ,N(ng))- &
& z_w(i,j ,0 ))
LtracerSrc = T T
IF (DOMAIN(ng)%NorthEast_Test(tile)) THEN
DO k=1,N(ng)
DO is=1,Nsrc(ng)
SOURCES(ng)%Tsrc(is,k,itemp)=T0(ng)
SOURCES(ng)%Tsrc(is,k,isalt)=0.0_r8
Amy
How many tracers do you have? They all need values on inflow. Have you looked at the blow-up?
I don't know about the Qshape. I just specify mine to be a fixed function of k.
Sure, why not? The trick is in finding an appropriate value.
Ken Coyle and I have had to change the ROMS "speed limit" for some major rivers. If you work out the velocity of the inflow as specified, is it ever above 20 m/s? If so, you can change the speed limit in mod_scalars.F:
#ifdef NWGOA
real(r8) :: max_speed = 80.0_r8 ! m/s
#else
real(r8) :: max_speed = 20.0_r8 ! m/s
In ocean.in,
I don't have any other tracers. You said they all needed to be specified in the inflow. I don't know how to set the values in ana_psource, except changing LtracerSrc = T T T T in ocean.in.
I have looked up the blow up, but I don't see anything wield in salinity or temperature or zeta. ubar can be 10^37 in the masked region, but I don't think this is relevant.
Amy
NAT = 2
Amy
This is four tracers, so the two NAT tracers plus two passive tracers. ROMS will likely ignore the last two if there are no passive tracers.LtracerSrc = T T T T
If the velocity is going bad, is it largest right at the source or a grid or two away? I sometimes add stations right there to watch what's going on. For a handful of stations in a short job like this, you can write to the stations file every timestep.
