I thought there might be an increase in bed porosity, so I tried getting a sum of the bed mud mass over the entire grid for each timestep (in Python:
for tt in range(timelength):
mudsum=np.sum(mudmass[tt,:,:,:]
This gives an increase of 33 times the original mass of sediment in the domain grid over the model run:
Suspended sediment also reaches extreme values over time:
Is this a known issue? I have no sediment sources, and I set the boundary conditions to closed in sediment.in:
My boundary conditions in ocean.in are set like this:! Keyword Lateral Boundary Condition Type
! Cla Clamped _____N_____ j=Mm
! Clo Closed | 4 |
! Gra Gradient | |
! Nes Nested 1 W E 3
! Nud Nudging | |
! Per Periodic |_____S_____|
! Rad Radiation 2 j=1
! i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isTvar) == Clo Clo Clo Clo ! idsed(:), compact
! conditions keywords.
ad_LBC(isTvar) == Clo Clo Clo Clo ! idsed(:), compact
The initialization of the model looks like this:! Keyword Lateral Boundary Condition Type
! Cha Chapman_implicit (free-surface)
! Che Chapman_explicit (free-surface)
! Cla Clamped
! Clo Closed
! Fla Flather (2D momentum) _____N_____ j=Mm
! Gra Gradient | 4 |
! Nes Nested (refinement) | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics (2D momentum) 2 j=1
! Shc Shchepetkin (2D momentum) i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Cha Per Clo Per ! free-surface
LBC(isUbar) == Fla Per Clo Per ! 2D U-momentum
LBC(isVbar) == Fla Per Clo Per ! 2D V-momentum
LBC(isUvel) == Gra Per Clo Per ! 3D U-momentum
LBC(isVvel) == Gra Per Clo Per ! 3D V-momentum
LBC(isMtke) == Gra Per Clo Per ! mixing TKE
LBC(isTvar) == Cla Per Clo Per \ ! temperature
Cla Per Clo Per \ ! salinity
Clo Per Clo Per ! passive
ad_LBC(isFsur) == Che Per Clo Per ! free-surface
ad_LBC(isUbar) == Red Per Clo Per ! 2D U-momentum
ad_LBC(isVbar) == Red Per Clo Per ! 2D U-momentum
ad_LBC(isUvel) == Gra Per Clo Per ! 3D U-momentum
ad_LBC(isVvel) == Gra Per Clo Per ! 3D V-momentum
ad_LBC(isMtke) == Gra Per Clo Per ! mixing TKE
ad_LBC(isTvar) == Cla Per Clo Per \ ! temperature
Friday - February 17, 2017 - 12:08:21 PM
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/local/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 802M
Local Root : /home/nws747/trunk
Header Dir : /home/nws747/cor_yearmodel/Inc
Header file : upwelling.h
Analytical Dir: /home/nws747/cor_yearmodel/Inc
Resolution, Grid 01: 0162x0032x032, Parallel Nodes: 16, Tiling: 004x004
10368000 ntimes Number of timesteps for 3-D equations.
15.000 dt Timestep size (s) for 3-D equations.
2880 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
2880 nHIS Number of timesteps between the writing fields
into history file.
518400 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
5760 nAVG Number of timesteps between the writing of
518400 ndefAVG Number of timesteps between creation of new
time-averaged file.
2880 nDIA Number of timesteps between the writing of
518400 ndefDIA Number of timesteps between creation of new
diagnostic file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
0.0000E+00 nl_tnu2(03) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 03: dye_01
(m2/s) for momentum.
F LtracerSponge(03) Turning OFF sponge on tracer 03: dye_01
for tracer 02: salt
1.0000E-06 Akt_bak(03) Background vertical mixing coefficient (m2/s)
for turbulent energy.
3.0000E+00 theta_s S-coordinate surface control parameter.
5.0000E-01 theta_b S-coordinate bottom control parameter.
25.000 Tcline S-coordinate surface/bottom layer width (m) used
180.000 dstart Time-stamp assigned to model initialization (days).
2.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
2.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
2.0000E+00 Tnudg(03) Nudging/relaxation time scale (days)
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
F LtracerSrc(03) Turning OFF point Sources/Sinks on tracer 03: dye_01
F LtracerCLM(03) Turning OFF processing of climatology tracer 03: dye_01
F LnudgeTCLM(03) Turning OFF nudging of climatology tracer 03: dye_01
T Hout(idUbms) Write out bottom U-momentum stress.
T Hout(idVbms) Write out bottom V-momentum stress.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(inert) Write out inert passive tracer 01: dye_01
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 08: Zo_def
T Hout(idBott) Write out bottom property 09: Zo_app
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idVvis) Write out vertical viscosity: AKv.
T Hout(idTdif) Write out vertical diffusion: AKt(itemp).
T Hout(idSdif) Write out vertical diffusion: AKt(isalt).
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
T Aout(inert) Write out averaged inert passive tracer 01: dye_01
T Dout(iTrate) Write out rate of change of tracer 03: dye_01
T Dout(iThadv) Write out horizontal advection, tracer 03: dye_01
T Dout(iTxadv) Write out horizontal X-advection, tracer 03: dye_01
T Dout(iTyadv) Write out horizontal Y-advection, tracer 03: dye_01
T Dout(iTvadv) Write out vertical advection, tracer 03: dye_01
T Dout(iThdif) Write out horizontal diffusion, tracer 03: dye_01
T Dout(iTxdif) Write out horizontal X-diffusion, tracer 03: dye_01
T Dout(iTydif) Write out horizontal Y-diffusion, tracer 03: dye_01
T Dout(iTvdif) Write out vertical diffusion, tracer 03: dye_01
Output Restart File: /home/nws747/hdrive/Documents/clusteroutput/dwc/5yearcorcalmobcdeep_rst.nc
Prefix for History Files: /home/nws747/hdrive/Documents/clusteroutput/dwc/5yearcorcalmobcdeep_his
Prefix for Averages Files: /home/nws747/hdrive/Documents/clusteroutput/dwc/5yearcorcalmobcdeep_avg
Prefix for Diagnostics Files: /home/nws747/hdrive/Documents/clusteroutput/dwc/5yearcorcalmobcdeep_dia
Tile partition information for Grid 01: 0162x0032x0032 tiling: 004x004
tile Istr Iend Jstr Jend Npts
0 1 40 1 8 10240
1 41 81 1 8 10496
2 82 122 1 8 10496
3 123 162 1 8 10240
4 1 40 9 16 10240
5 41 81 9 16 10496
6 82 122 9 16 10496
7 123 162 9 16 10240
8 1 40 17 24 10240
9 41 81 17 24 10496
10 82 122 17 24 10496
11 123 162 17 24 10240
12 1 40 25 32 10240
13 41 81 25 32 10496
14 82 122 25 32 10496
15 123 162 25 32 10240
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 40.50 0.50 8.50 RHO-points
1 40.50 81.50 0.50 8.50 RHO-points
2 81.50 122.50 0.50 8.50 RHO-points
3 122.50 162.50 0.50 8.50 RHO-points
4 0.50 40.50 8.50 16.50 RHO-points
5 40.50 81.50 8.50 16.50 RHO-points
6 81.50 122.50 8.50 16.50 RHO-points
7 122.50 162.50 8.50 16.50 RHO-points
8 0.50 40.50 16.50 24.50 RHO-points
9 40.50 81.50 16.50 24.50 RHO-points
10 81.50 122.50 16.50 24.50 RHO-points
11 122.50 162.50 16.50 24.50 RHO-points
12 0.50 40.50 24.50 32.50 RHO-points
13 40.50 81.50 24.50 32.50 RHO-points
14 81.50 122.50 24.50 32.50 RHO-points
15 122.50 162.50 24.50 32.50 RHO-points
0 1.00 40.50 0.50 8.50 U-points
1 40.50 81.50 0.50 8.50 U-points
2 81.50 122.50 0.50 8.50 U-points
3 122.50 162.00 0.50 8.50 U-points
4 1.00 40.50 8.50 16.50 U-points
5 40.50 81.50 8.50 16.50 U-points
6 81.50 122.50 8.50 16.50 U-points
7 122.50 162.00 8.50 16.50 U-points
8 1.00 40.50 16.50 24.50 U-points
9 40.50 81.50 16.50 24.50 U-points
10 81.50 122.50 16.50 24.50 U-points
11 122.50 162.00 16.50 24.50 U-points
12 1.00 40.50 24.50 32.50 U-points
13 40.50 81.50 24.50 32.50 U-points
14 81.50 122.50 24.50 32.50 U-points
15 122.50 162.00 24.50 32.50 U-points
0 0.50 40.50 1.00 8.50 V-points
1 40.50 81.50 1.00 8.50 V-points
2 81.50 122.50 1.00 8.50 V-points
3 122.50 162.50 1.00 8.50 V-points
4 0.50 40.50 8.50 16.50 V-points
5 40.50 81.50 8.50 16.50 V-points
6 81.50 122.50 8.50 16.50 V-points
7 122.50 162.50 8.50 16.50 V-points
8 0.50 40.50 16.50 24.50 V-points
9 40.50 81.50 16.50 24.50 V-points
10 81.50 122.50 16.50 24.50 V-points
11 122.50 162.50 16.50 24.50 V-points
12 0.50 40.50 24.50 32.00 V-points
13 40.50 81.50 24.50 32.00 V-points
14 81.50 122.50 24.50 32.00 V-points
15 122.50 162.50 24.50 32.00 V-points
HaloSizeI(1) = 220
HaloSizeJ(1) = 92
TileSide(1) = 49
TileSize(1) = 833
Sediment Parameters, Grid: 01
Size Sd50 Csed Srho Wsed Erate poros
Class (mm) (kg/m3) (kg/m3) (mm/s) (kg/m2/s) (nondim)
1 1.0000E-03 0.0000E+00 2.6500E+03 5.0000E-02 1.0000E-03 8.0000E-01
tau_ce tau_cd nl_tnu2 nl_tnu4 Akt_bak Tnudg
(N/m2) (N/m2) (m2/s) (m4/s) (m2/s) (day)
1 4.5000E-02 4.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+00
New bed layer formed when deposition exceeds 0.1000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.0000E+00 (m).
Rate coefficient for bed load transport = 0.5000E-01
F LtracerSponge(04Turning OFF sponge on tracer 04: mud_01
F LtracerSrc(04) Turning OFF point sources/Sink on tracer 04: mud_01
F LtracerCLM(04) Turning OFF processing of climatology tracer 04: mud_01
F LnudgeTCLM(04) Turning OFF nudging of climatology tracer 04: mud_01
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idSbed) Write out BED property 01: bed_thickness
T Hout(idSbed) Write out BED property 02: bed_age
T Hout(idSbed) Write out BED property 03: bed_porosity
T Aout(idTvar) Write out averaged sediment01: mud_01
T Dout(iTrate) Write out rate of change of tracer 04: mud_01
T Dout(iThadv) Write out horizontal advection, tracer 04: mud_01
T Dout(iTxadv) Write out horizontal X-advection, tracer 04: mud_01
T Dout(iTyadv) Write out horizontal Y-advection, tracer 04: mud_01
T Dout(iTvadv) Write out vertical advection, tracer 04: mud_01
T Dout(iThdif) Write out horizontal diffusion, tracer 04: mud_01
T Dout(iTxdif) Write out horizontal X-diffusion, tracer 04: mud_01
T Dout(iTydif) Write out horizontal Y-diffusion, tracer 04: mud_01
T Dout(iTvdif) Write out vertical diffusion, tracer 04: mud_01
zeta 1 Chapman Imp Periodic Closed Periodic
ubar 1 Flather Periodic Closed Periodic
vbar 1 Flather Periodic Closed Periodic
u 1 Gradient Periodic Closed Periodic
v 1 Gradient Periodic Closed Periodic
temp 1 Clamped Periodic Closed Periodic
salt 1 Clamped Periodic Closed Periodic
dye_01 1 Closed Periodic Closed Periodic
mud_01 1 Closed Closed Closed Closed
tke 1 Gradient Periodic Closed Periodic
ANA_BPFLUX Analytical bottom passive tracers fluxes.
ANA_DQDSST Analytical surface heat flux sensitivity to SST.
ANA_M3OBC Analytical 3D momentum boundary conditions.
ANA_PASSIVE Analytical initial conditions for inert tracers.
ANA_SEDIMENT Analytical sediment initial conditions.
ANA_SPFLUX Analytical surface passive tracer fluxes.
ANA_SST Analytical sea surface temperature, SST.
ANA_TOBC Analytical tracers boundary conditions.
ANA_WWAVE Analytical wind induced waves.
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms.
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
NONLINEAR Nonlinear Model.
QCORRECTION Surface net heat flux correction.
SALINITY Using salinity.
SEDIMENT Cohesive and noncohesive sediments.
SED_DENS Include density of suspended sediment in equation of state.
SUSPLOAD Activate suspended sediment transport.
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion.
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_UB Internal computation of bottom orbital velocity.
SSW_CALC_ZNOT Internal computation of bottom roughness.
T_PASSIVE Advecting and diffusing inert passive tracer.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_SADVECTION Parabolic splines vertical advection of momentum.
Process Information:
Node # 0 (pid= 23267) is active.
Node # 1 (pid= 23268) is active.
Node # 2 (pid= 23269) is active.
Node # 3 (pid= 23270) is active.
Node # 4 (pid= 23271) is active.
Node # 5 (pid= 23272) is active.
Node # 6 (pid= 23273) is active.
Node # 7 (pid= 23274) is active.
Node # 8 (pid= 23275) is active.
Node # 9 (pid= 23276) is active.
Node # 10 (pid= 23277) is active.
Node # 11 (pid= 23278) is active.
Node # 12 (pid= 23279) is active.
Node # 13 (pid= 23281) is active.
Node # 14 (pid= 23282) is active.
Node # 15 (pid= 23283) is active.
32 0.0000000 0.0000000 0.000 0.000 0.000 0.000
31 -0.0312500 -0.0006162 -0.943 -0.398 -1.273 -1.584
30 -0.0625000 -0.0024694 -2.312 -0.812 -3.578 -4.807
29 -0.0937500 -0.0055732 -4.110 -1.242 -6.927 -9.688
28 -0.1250000 -0.0099501 -6.346 -1.687 -11.338 -16.257
27 -0.1562500 -0.0156320 -9.030 -2.149 -16.837 -24.555
26 -0.1875000 -0.0226598 -12.177 -2.627 -23.459 -34.637
25 -0.2187500 -0.0310838 -15.804 -3.123 -31.246 -46.569
24 -0.2500000 -0.0409634 -19.931 -3.637 -40.247 -60.431
23 -0.2812500 -0.0523675 -24.582 -4.170 -50.520 -76.314
22 -0.3125000 -0.0653746 -29.784 -4.723 -62.131 -94.321
21 -0.3437500 -0.0800722 -35.567 -5.298 -75.152 -114.569
20 -0.3750000 -0.0965575 -41.965 -5.894 -89.664 -137.187
19 -0.4062500 -0.1149368 -49.013 -6.515 -105.756 -162.315
18 -0.4375000 -0.1353252 -56.752 -7.160 -123.525 -190.105
17 -0.4687500 -0.1578467 -65.224 -7.832 -143.072 -220.724
16 -0.5000000 -0.1826330 -74.475 -8.533 -164.510 -254.344
15 -0.5312500 -0.2098233 -84.552 -9.263 -187.953 -291.150
14 -0.5625000 -0.2395630 -95.505 -10.026 -213.523 -331.336
13 -0.5937500 -0.2720024 -107.386 -10.822 -241.345 -375.099
12 -0.6250000 -0.3072950 -120.248 -11.654 -271.547 -422.645
11 -0.6562500 -0.3455957 -134.143 -12.523 -304.259 -474.178
10 -0.6875000 -0.3870577 -149.125 -13.432 -339.608 -529.901
9 -0.7187500 -0.4318298 -165.245 -14.382 -377.719 -590.011
8 -0.7500000 -0.4800524 -182.551 -15.376 -418.708 -654.695
7 -0.7812500 -0.5318532 -201.087 -16.414 -462.683 -724.121
6 -0.8125000 -0.5873421 -220.890 -17.498 -509.734 -798.436
5 -0.8437500 -0.6466051 -241.990 -18.629 -559.934 -877.753
4 -0.8750000 -0.7096981 -264.407 -19.809 -613.329 -962.147
3 -0.9062500 -0.7766394 -288.147 -21.036 -669.935 -1051.641
2 -0.9375000 -0.8474014 -313.199 -22.311 -729.728 -1146.200
1 -0.9687500 -0.9219029 -339.537 -23.633 -792.641 -1245.715
0 -1.0000000 -1.0000000 -367.111 -25.000 -858.553 -1349.996
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
21 0.0256737146312910 0.0297153720153352 0.1342125541712341 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524357 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236651 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893979 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886211 0.8237939964192927
27 0.0432936737565711 0.0230872677537126 0.3506756411451922 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772278 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880562 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442381 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256412 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325517 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348094 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479473 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213234 0.9738247715198165
36 0.0503158038019031 0.0080591141492892 0.8085423793232265 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079418 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497606 0.9930692679747335
39 0.0376397765791564 0.0033640675316746 0.9367177506289170 0.9964333355064081
40 0.0305543017255206 0.0021094083123694 0.9672720523544377 0.9985427438187775
41 0.0217382098544505 0.0010909315881854 0.9890102622088881 0.9996336754069629
42 0.0109897377911119 0.0003663245930371 1.0000000000000000 1.0000000000000000
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 9.43240458E-01 m
Maximum Z-grid spacing, DZmax = 1.04280828E+02 m
Minimum barotropic Courant Number = 4.24344299E-02
Maximum barotropic Courant Number = 8.13740028E-02
Maximum Coriolis Courant Number = 1.54650000E-03
Maximum grid stiffness ratios: rx0 = 3.725851E-02 (Beckmann and Haidvogel)
rx1 = 9.521232E-01 (Haney)
Initial basin volumes: TotVolume = 5.7839568336E+12 m3
MinVolume = 9.4324045808E+05 m3
MaxVolume = 1.0428079379E+08 m3
Max/Min = 1.1055589579E+02
