first run upwelling problem
When I tried to run upwelling and followed the tutorial, after i typed ./oceanG < ocean_upwelling.in > out.text, the out.text shows an error, how can i solved this problem?
REASON: No error
"out.text" 69L, 11105C
REASON: No error
Re: first run upwelling problem
Did you try and fail to attach the full output? I can't tell what went wrong from what you provided so far. There's probably an error message above the "Input error ... exit_flag: 2" line."out.text" 69L, 11105C
Hi kate,
I think there is something wrong in compiling.Wehn I used makefile to compile, there is warning.
makefile:234: INCLUDING FILE Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
/share/apps/bin/mpif90 -heap-arrays -fp-model precise -ip -O3 Build/esmf_roms.o Build/master.o Build/ocean_control.o Build/ocean_coupler.o Build/propagator.o Build/roms_export.o Build/roms_import.o -o oceanM Build/libUTIL.a Build/libNLM.a Build/libNLM_bio.a Build/libNLM_sed.a Build/libANA.a Build/libUTIL.a Build/libMODS.a -L/home/zhou/netcdf/lib -lnetcdf
/opt/intel/Compiler/11.1/064/lib/intel64/libimf.so: warning: warning: feupdateenv is not implemented and will always fail
rm -f -r /home/zhou/make_macros.mk
When you get an error like this, you can always do a web search. You might even get something useful:
I had this problem in the past. The problem is the you are linking against the Intel math library only. The Intel math library (libimf) has optimized replacements for many of the routines in the system math library (libm). However, the Intel math library does not provide replacements for all functions.
The solution is simple. Always link against both math libraries: libimf libm
Thanks Kate,
So where should I make the change of the linking according to your solution,makefile? Can u give me the exact sentence in makefile about the linking intel library.
Xiaohui
Xiaohui
Here's what I see when linking with intel:
I don't get the warning you saw. Can you run with your executable? You got a warning, not an error, so all might be well.
/opt/scyld/openmpi/1.10.4/intel/bin/mpif90 -heap-arrays -fp-model precise -ip -O3 /center/w/kate/Build_CGOA/roms_import.o /center/w/kate/Build_CGOA/propagator.o /center/w/kate/Build_CGOA/master.o /center/w/kate/Build_CGOA/roms_export.o /center/w/kate/Build_CGOA/ocean_coupler.o /center/w/kate/Build_CGOA/esmf_roms.o /center/w/kate/Build_CGOA/ocean_control.o -o oceanM /center/w/kate/Build_CGOA/libMODS.a /center/w/kate/Build_CGOA/libNLM.a /center/w/kate/Build_CGOA/libNLM_bio.a /center/w/kate/Build_CGOA/libNLM_sed.a /center/w/kate/Build_CGOA/libANA.a /center/w/kate/Build_CGOA/libUTIL.a /center/w/kate/Build_CGOA/libMODS.a -L/usr/local/pkg/data/netCDF-Fortran/4.4.4-pic-intel-2016b/lib -lnetcdff -L/usr/local/pkg/compiler/icc/2016.3.210-GCC-5.4.0-2.26/lib/intel64 -L/usr/local/pkg/numlib/imkl/11.3.3.210-pic-iompi-2016b/lib -L/usr/local/pkg/numlib/imkl/11.3.3.210-pic-iompi-2016b/mkl/lib/intel64 -L/usr/local/pkg/numlib/imkl/11.3.3.210-pic-iompi-2016b/lib -L/usr/local/pkg/data/netCDF/4.4.1-pic-intel-2016b/lib64 -lnetcdf -lnetcdf -liomp5 -lpthread
564.415u 39.328s 3:15.07 309.4% 0+0k 108608+217632io 8pf+0w
Hi Kate
I tried to execute. there is an error in out.text as :
Tuesday - February 14, 2017 - 7:45:47 PM
MOD_NCPARAM - Unable to open variable information file:
ROMS/External/varinfo.dat
Default file is located in source directory.
Actually, there is the file varinfo.dat in ROMS\External .
here is my batch file for job sumission
work_dir=/home/zhou/Projects/upwelling
cd $work_dir
mpirun -np 32 oceanM ../../MyDir/ROMS/External/ocean_upwelling.in > out.text
I only changed the Mt_HEADER_DIR in makefile, my makefile is
ROMS_APPLICATION ?= UPWELLING
# If application header files is not located in "ROMS/Include",
# provide an alternate directory FULL PATH.
MY_HEADER_DIR ?= /home/zhou/MyDir/ROMS/Include
Can u tell me which part is wrong
cd $work_dir
You didn't tell it the correct path to this file in the ocean_upwelling.in file. If you didn't change the path, it is "ROMS/External/varinfo.dat" from the current directory.MOD_NCPARAM - Unable to open variable information file:
From this:
I assume that you are not in the parent ROMS directory. You should create a ROMS directory where you are now, create an External subdirectory, then copy the varinfo.dat to that directory.mpirun -np 32 oceanM ../../MyDir/ROMS/External/ocean_upwelling.in > out.text
Hi Kate,
Thanks a lot.
But there is another error in out.text.
Compiler system : ifort
Compiler command : /share/apps/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script :
SVN Revision : 825M
Local Root : /home/zhou/MyDir
Header Dir : /home/zhou/MyDir/ROMS/Include
Header file : upwelling.h
Analytical Dir: /home/zhou/MyDir/ROMS/Functionals
Resolution, Grid 01: 0041x0080x016, Parallel Nodes: 32, Tiling: 001x001
ROMS/TOMS: Wrong choice of domain 01 partition or number of parallel threads.
NtileI * NtileJ must be equal to the number of parallel nodes.
Change -np value to mpirun or
change domain partition in input script.
Elapsed CPU time (seconds):
ROMS/TOMS - Partition error ......... exit_flag: 6
ERROR: Illegal domain partition.
33,0-1 Bot
Thanks a lot.
Input Script :
SVN Revision : 825M
33,0-1 Bot
Hi Kate
according to the out.text, I have changed the np in bash script. But the problem still occure.
here is my bash:
cd $work_dir
mpirun -np 8 oceanM ocean_upwelling.in > out.text
#pbsnodes -a
##PBS -l nodes=compute-0-19:ppn=16+compute-0-18:ppn=16
#nodes=2:ppn=16
Here is the out.text
Using username "zhou".
Resolution, Grid 01: 0041x0080x016, Parallel Nodes: 8, Tiling: 001x001
39,1 Bot
Can u help me solve this problem?
here is my bash:
cd $work_dir
#pbsnodes -a
#nodes=2:ppn=16
39,1 Bot
You have NtileI = 1 and NtileJ = 1 in the input file. You need to change one or both so that NtileI * NtileJ = 8. Or ask for 1 processor in your job script. UPWELLING is so small I usually don't even compile it with the parallel option.Parallel Nodes: 8, Tiling: 001x001
Hi Kate,
I think I got the output now. I really appreciate your help.
Thank you a lot.
Thank you a lot.
Hi Kate,
why my time step (parameter :ocean_time) in ocean_his.nc file is 0, according to the results, it should be 288 time steps, but i did not change any code in input file.
my result of temp in ocean_his.nc:
temp
Dimensions: xi_rho,eta_rho,s_rho,ocean_time
Datatype: single
Attributes:
long_name = 'potential temperature'
units = 'Celsius'
time = 'ocean_time'
grid = 'grid'
location = 'face'
coordinates = 'x_rho y_rho s_rho ocean_time'
field = 'temperature, scalar, series'
Can u help me solve the problem?
temp
Datatype: single
Attributes:
units = 'Celsius'
time = 'ocean_time'
grid = 'grid'
location = 'face'
The question is, how many steps did you run for and how often did you tell it to save history files? It would have written a history record at time zero, but you only have one in that file. Is it the only history file? Did ROMS crash before getting to step 288? I can't tell.
Hi Kate
in the ocean_upwelling.in file, i set :
! Time-Stepping parameters.
! NTIMES Total number time-steps in current run. If 3D configuration,
! NTIMES is the total of baroclinic time-steps. If only 2D
! configuration, NTIMES is the total of barotropic time-steps.
NTIMES == 1440
DT == 300.0d0
NDTFAST == 30
Output history, quicksave, average, and diagnostic files parameters.
LDEFOUT == T
LDEFOUT == T
NHIS == 1
NDEFHIS == 0
NQCK == 0
NDEFQCK == 0
NTSAVG == 1
NAVG == 72
NDEFAVG == 0
NTSDIA == 1
NDIA == 72
NDEFDIA == 0
LDEFOUT == T;
Becasue NHIS is the Number of time-steps between writing fields into HISTORY file. If I set 1, so it should have 1440 time points. I did not change anything other in the original ocean_upwelling.in file. Bu the output file (ocean_his.nc) shows thatthe parameter
temp
What is the problem?
NTIMES == 1440
DT == 300.0d0
NDTFAST == 30
LDEFOUT == T
LDEFOUT == T
NHIS == 1
NDEFHIS == 0
NQCK == 0
NDEFQCK == 0
NTSAVG == 1
NAVG == 72
NDEFAVG == 0
NTSDIA == 1
NDIA == 72
NDEFDIA == 0
LDEFOUT == T;
temp
Did ROMS run for 1440 steps? It should have printed to the output every time it called WRT_HIS. Did you look at the standard output file?
Hi Kate
I don't know what happened. It should be run for 1440 times. I did not change anything. Is there any standard output files?
Hi Kate,
This is y out.text
1440 ntimes Number of timesteps for 3-D equations.
288 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
into history file.
into quicksave file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
to standard output.
into history file.
time-averaged data.
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
3.0000E+00 theta_s S-coordinate surface control parameter.
This is y out.text
to standard output.
into history file.
time-averaged data.
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
Standard output is where all the print statements go. It writes to the screen if you run interactively. With NINFO=1 I get information every timestep, like this:
Yes, I'm trying to debug something with frequent history files.
0 39446 00:00:00 1.889733E-03 1.959613E+04 1.959613E+04 4.096830E+15
(097,191,50) 2.114777E-02 8.108576E-03 0.000000E+00 8.530640E-01
DEF_HIS - creating history file, Grid 01: nwgoa_his_00001.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
DEF_STATION - creating stations file, Grid 01: nwgoa_sta.nc
1 39446 00:02:00 1.883119E-03 1.960669E+04 1.960669E+04 4.094599E+15
(300,101,01) 0.000000E+00 0.000000E+00 4.309511E+00 8.466840E-01
2 39446 00:04:00 1.874179E-03 1.960664E+04 1.960664E+04 4.094586E+15
(234,202,50) 3.103330E-03 6.650405E-03 7.207450E-01 8.402656E-01
3 39446 00:06:00 1.867679E-03 1.960659E+04 1.960659E+04 4.094574E+15
(234,202,50) 3.489571E-03 7.511304E-03 7.519809E-01 8.343320E-01
4 39446 00:08:00 1.862443E-03 1.960654E+04 1.960654E+04 4.094562E+15
(241,190,50) 1.114989E-05 1.756952E-05 8.244364E-01 8.280427E-01
5 39446 00:10:00 1.858217E-03 1.960649E+04 1.960649E+04 4.094550E+15
(234,202,50) 3.828630E-03 7.610422E-03 8.369061E-01 8.212624E-01
6 39446 00:12:00 1.854687E-03 1.960645E+04 1.960645E+04 4.094538E+15
(234,202,50) 3.678040E-03 6.916985E-03 8.404064E-01 8.152598E-01
7 39446 00:14:00 1.851558E-03 1.960641E+04 1.960641E+04 4.094527E+15
(300,101,50) 1.038696E-04 1.412139E-04 9.076163E-01 8.100066E-01
8 39446 00:16:00 1.848700E-03 1.960637E+04 1.960637E+04 4.094516E+15
(300,101,06) 4.073273E-08 4.073281E-08 6.778341E-01 8.051808E-01
9 39446 00:18:00 1.846233E-03 1.960633E+04 1.960633E+04 4.094506E+15
(298,025,50) 1.776752E-03 1.061148E-03 5.463311E-01 8.006113E-01
10 39446 00:20:00 1.844143E-03 1.960629E+04 1.960630E+04 4.094496E+15
(284,003,50) 3.917988E-04 4.038878E-03 5.455851E-01 7.961011E-01
DEF_HIS - creating history file, Grid 01: nwgoa_his_00002.nc
This is the whole out.text, it seems same as the standard one, I don't know what's wrong
Friday - February 17, 2017 - 2:28:05 PM
Operating system : Linux
CPU/hardware : x86_64
Input Script :
SVN Revision : 825M
Resolution, Grid 01: 0041x0080x016, Parallel Nodes: 8, Tiling: 008x001
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
25.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
Output Diagnostics File: ocean_dia.nc
Tile partition information for Grid 01: 0041x0080x0016 tiling: 008x001
tile Istr Iend Jstr Jend Npts
0 1 3 1 80 3840
1 4 9 1 80 7680
2 10 15 1 80 7680
3 16 21 1 80 7680
4 22 27 1 80 7680
5 28 33 1 80 7680
6 34 39 1 80 7680
7 40 41 1 80 2560
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 3.50 0.50 80.50 RHO-points
1 3.50 9.50 0.50 80.50 RHO-points
2 9.50 15.50 0.50 80.50 RHO-points
3 15.50 21.50 0.50 80.50 RHO-points
4 21.50 27.50 0.50 80.50 RHO-points
5 27.50 33.50 0.50 80.50 RHO-points
6 33.50 39.50 0.50 80.50 RHO-points
7 39.50 41.50 0.50 80.50 RHO-points
0 1.00 3.50 0.50 80.50 U-points
1 3.50 9.50 0.50 80.50 U-points
2 9.50 15.50 0.50 80.50 U-points
3 15.50 21.50 0.50 80.50 U-points
4 21.50 27.50 0.50 80.50 U-points
5 27.50 33.50 0.50 80.50 U-points
6 33.50 39.50 0.50 80.50 U-points
7 39.50 41.00 0.50 80.50 U-points
0 0.50 3.50 1.00 80.00 V-points
1 3.50 9.50 1.00 80.00 V-points
2 9.50 15.50 1.00 80.00 V-points
3 15.50 21.50 1.00 80.00 V-points
4 21.50 27.50 1.00 80.00 V-points
5 27.50 33.50 1.00 80.00 V-points
6 33.50 39.50 1.00 80.00 V-points
7 39.50 41.50 1.00 80.00 V-points
HaloSizeI(1) = 54
HaloSizeJ(1) = 273
TileSide(1) = 85
TileSize(1) = 1020
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
ANA_VMIX Analytical vertical mixing coefficients.
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms.
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion.
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_LDRAG Linear bottom stress.
Process Information:
Node # 0 (pid= 32601) is active.
Node # 4 (pid= 32605) is active.
Node # 7 (pid= 32608) is active.
Node # 6 (pid= 32607) is active.
Node # 2 (pid= 32603) is active.
Node # 3 (pid= 32604) is active.
Node # 5 (pid= 32606) is active.
Node # 1 (pid= 32602) is active.
16 0.0000000 0.0000000 0.000 0.000 0.000 0.000
15 -0.0625000 -0.0019442 -0.809 -0.806 -1.348 -1.589
14 -0.1250000 -0.0078455 -1.668 -1.661 -2.966 -3.687
13 -0.1875000 -0.0179119 -2.580 -2.568 -4.867 -6.321
12 -0.2500000 -0.0324983 -3.549 -3.531 -7.077 -9.535
11 -0.3125000 -0.0521190 -4.581 -4.558 -9.630 -13.397
10 -0.3750000 -0.0774659 -5.686 -5.656 -12.573 -17.996
9 -0.4375000 -0.1094327 -6.875 -6.837 -15.967 -23.445
8 -0.5000000 -0.1491465 -8.162 -8.114 -19.889 -29.890
7 -0.5625000 -0.1980075 -9.564 -9.506 -24.435 -37.512
6 -0.6250000 -0.2577387 -11.104 -11.034 -29.721 -46.531
5 -0.6875000 -0.3304460 -12.808 -12.724 -35.892 -57.218
4 -0.7500000 -0.4186931 -14.709 -14.609 -43.121 -69.903
3 -0.8125000 -0.5255915 -16.846 -16.726 -51.622 -84.987
2 -0.8750000 -0.6549105 -19.266 -19.124 -61.651 -102.953
1 -0.9375000 -0.8112096 -22.028 -21.859 -73.518 -124.388
0 -1.0000000 -1.0000000 -25.200 -25.000 -87.600 -150.000
12 0.0043042707117221 0.0335513677379153-0.0022367614257356 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864348 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001213 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565097 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906204 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716643 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402368 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399432 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712342 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524359 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729578 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236653 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893981 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886213 0.8237939964192927
27 0.0432936737565710 0.0230872677537126 0.3506756411451924 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772280 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880565 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256415 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325521 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348098 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479478 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213239 0.9738247715198165
36 0.0503158038019030 0.0080591141492892 0.8085423793232269 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497611 0.9930692679747334
39 0.0376397765791564 0.0033640675316746 0.9367177506289175 0.9964333355064080
40 0.0305543017255206 0.0021094083123694 0.9672720523544381 0.9985427438187774
41 0.0217382098544504 0.0010909315881854 0.9890102622088885 0.9996336754069628
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 8.08965824E-01 m
Maximum Z-grid spacing, DZmax = 2.56123321E+01 m
Minimum barotropic Courant Number = 2.22358627E-01
Maximum barotropic Courant Number = 5.42494240E-01
Maximum Coriolis Courant Number = 2.47800000E-02
Maximum grid stiffness ratios: rx0 = 6.931666E-02 (Beckmann and Haidvogel)
rx1 = 8.661243E-01 (Haney)
Initial basin volumes: TotVolume = 3.8843755884E+11 m3
MinVolume = 8.4521383562E+05 m3
MaxVolume = 2.5612332106E+07 m3
Max/Min = 3.0302783777E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
0 0 00:00:00 0.000000E+00 6.585677E+02 6.585677E+02 3.884376E+11
DEF_AVG - creating average file, Grid 01: ocean_avg.nc
DEF_DIAGS - creating diagnostics file, Grid 01: ocean_dia.nc
1 0 00:05:00 6.479408E-13 6.585677E+02 6.585677E+02 3.884376E+11
(01,01,01) 1.069435E-09 1.950204E-06 0.000000E+00 9.216783E-06
2 0 00:10:00 9.293195E-12 6.585677E+02 6.585677E+02 3.884376E+11
(01,02,08) 6.735167E-08 1.785829E-06 1.433648E-05 3.660353E-05
Input Script :
SVN Revision : 825M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
0 1 3 1 80 3840
1 4 9 1 80 7680
2 10 15 1 80 7680
3 16 21 1 80 7680
4 22 27 1 80 7680
5 28 33 1 80 7680
6 34 39 1 80 7680
7 40 41 1 80 2560
HaloSizeI(1) = 54
HaloSizeJ(1) = 273
TileSide(1) = 85
TileSize(1) = 1020
It just ended like that? There should be more. When ROMS dies or finishes cleanly it lets you know:
36 39446 01:12:00 1.812177E-03 1.960581E+04 1.960581E+04 4.094320E+15
(245,180,50) 5.393447E-04 2.809401E-03 1.611229E+00 8.123321E-01
DIAG temperature trouble -53.2869692686739 1
WRT_RST - wrote re-start fields (Index=1,1) in record = 0000001
Node # 0 CPU: 305.040
Node # 9 CPU: 684.506
Node # 12 CPU: 686.090
Node # 2 CPU: 685.977
Total: 32545.970
Nonlinear ocean model elapsed time profile, Grid: 01
Allocation and array initialization .............. 31.997 ( 0.0983 %)
Ocean state initialization ....................... 8.595 ( 0.0264 %)
Reading of input data ............................ 19989.176 (61.4183 %)
Processing of input data ......................... 256.178 ( 0.7871 %)
Processing of output time averaged data .......... 22.410 ( 0.0689 %)
Computation of vertical boundary conditions ...... 0.273 ( 0.0008 %)
Computation of global information integrals ...... 27.175 ( 0.0835 %)
Writing of output data ........................... 3911.487 (12.0183 %)
Model 2D kernel .................................. 121.796 ( 0.3742 %)
Tidal forcing .................................... 18.102 ( 0.0556 %)
2D/3D coupling, vertical metrics ................. 17.178 ( 0.0528 %)
Omega vertical velocity .......................... 9.799 ( 0.0301 %)
Equation of state for seawater ................... 25.302 ( 0.0777 %)
Biological module, source/sink terms ............. 1064.812 ( 3.2717 %)
Atmosphere-Ocean bulk flux parameterization ...... 2.326 ( 0.0071 %)
KPP vertical mixing parameterization ............. 40.724 ( 0.1251 %)
3D equations right-side terms .................... 15.291 ( 0.0470 %)
3D equations predictor step ...................... 301.170 ( 0.9254 %)
Pressure gradient ................................ 8.416 ( 0.0259 %)
Harmonic stress tensor, S-surfaces ............... 8.002 ( 0.0246 %)
Corrector time-step for 3D momentum .............. 23.092 ( 0.0710 %)
Corrector time-step for tracers .................. 323.810 ( 0.9949 %)
Total: 26227.112 80.5848
yes, my out.text just look like this, it lost something
Hi Kate,
there is some fault happened.
Image PC Routine Line Source
oceanM 00000000004EF245 Unknown Unknown Unknown
oceanM 00000000004E3E53 Unknown Unknown Unknown
oceanM 00000000004C4A92 Unknown Unknown Unknown
oceanM 00000000004249EC Unknown Unknown Unknown
oceanM 000000000042480B Unknown Unknown Unknown
oceanM 000000000042465C Unknown Unknown Unknown
libc.so.6 0000003083A1D994 Unknown Unknown Unknown
oceanM 0000000000424569 Unknown Unknown Unknown
What is that?
What is that?
Try again with just one or four processors? Remember to change NtileI.
I left off the end of the ROMS report before:
number of time records written in STATION file = 00000002
Analytical header files used:
Apps_master/NGOA/ana_drag.h
ROMS/Functionals/ana_btflux.h
Apps_master/NGOA/ana_nudgcoef.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Thursday - February 16, 2017 - 10:22:11 PM
As for the seg fault, recompile with USE_DEBUG=on and see if it gives more information.
Hi Kate
I think maybe it is because of this warning,
/share/apps/bin/mpif90 -heap-arrays -fp-model precise -g -check bounds -traceback -check uninit -warn interfaces,nouncalled -gen-interfaces Build/esmf_roms.o Build/master.o Build/ocean_control.o Build/ocean_coupler.o Build/propagator.o Build/roms_export.o Build/roms_import.o -o oceanG Build/libUTIL.a Build/libNLM.a Build/libNLM_bio.a Build/libNLM_sed.a Build/libANA.a Build/libUTIL.a Build/libMODS.a -L/home/zhou/netcdf/lib -lnetcdf
Even u told me what is this problem, but I don't know which file and where should i change it
Well, maybe, maybe not. You still need to recompile with USE_DEBUG=on and rerun it.
Kate
I still got the same output and out.text after i recompiled makefile and USE_DEBUG=on.
You need to run oceanG, not oceanM. It's this output which should change:
hi Kate
I used oceanG to run it.
cd $work_dir
mpirun -np 8 oceanG ocean_upwelling.in > out.text
Then the out.text is
Friday - February 17, 2017 - 3:38:23 PM
Input Script :
SVN Revision : 825M
to standard output.
1 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
0 1 3 1 80 3840
1 4 9 1 80 7680
2 10 15 1 80 7680
3 16 21 1 80 7680
4 22 27 1 80 7680
5 28 33 1 80 7680
6 34 39 1 80 7680
7 40 41 1 80 2560
HaloSizeI(1) = 54
HaloSizeJ(1) = 273
TileSide(1) = 85
TileSize(1) = 1020
Node # 0 (pid= 2681) is active.
Node # 7 (pid= 2688) is active.
Node # 3 (pid= 2684) is active.
Node # 4 (pid= 2685) is active.
Node # 6 (pid= 2687) is active.
Node # 1 (pid= 2682) is active.
Node # 2 (pid= 2683) is active.
Node # 5 (pid= 2686) is active.
WRT_HIS - wrote history fields (Index=1,2) in record = 0000002
cd $work_dir
Input Script :
SVN Revision : 825M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
0 1 3 1 80 3840
1 4 9 1 80 7680
2 10 15 1 80 7680
3 16 21 1 80 7680
4 22 27 1 80 7680
5 28 33 1 80 7680
6 34 39 1 80 7680
7 40 41 1 80 2560
HaloSizeI(1) = 54
HaloSizeJ(1) = 273
TileSide(1) = 85
TileSize(1) = 1020
This is the fault information
oceanG 00000000004C4A92 Unknown Unknown Unknown
oceanG 00000000004249EC Unknown Unknown Unknown
oceanG 000000000042480B Unknown Unknown Unknown
oceanG 000000000042465C Unknown Unknown Unknown
libc.so.6 00000033A1E1D994 Unknown Unknown Unknown
oceanG 0000000000424569 Unknown Unknown Unknown
oceanG 00000000004EF245 Unknown Unknown Unknown
oceanG 00000000004E3E53 Unknown Unknown Unknown
mpirun has exited due to process rank 7 with PID 2688 on
node compute-0-4.local exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
That should be giving you line number information. I would try turning off USE_MPI and running in serial mode.
You didn't delete the build directory, did you?
I managed to produce the sort of output you get with USE_DEBUG=on:The next thing to do is go to the build directory and look at say line 186 of set_data.f90 there. Oops, problem with the #ifdefs back in set_data.F in the source tree.
forrtl: severe (408): fort: (3): Subscript #1 of the array TINTRP has value 0 which is less than the lower bound of 1
oceanG 0000000002C36CD6 Unknown Unknown Unknown
oceanG 00000000021F4A4C set_2dfld_mod_mp_ 132 set_2dfld.f90
oceanG 0000000000BC0539 set_data_tile_ 186 set_data.f90
oceanG 0000000000BADEFF set_data_ 48 set_data.f90
oceanG 0000000000930071 main3d_ 128 main3d.f90
oceanG 000000000040CD11 ocean_control_mod 173 ocean_control.f90
oceanG 000000000040BB05 MAIN__ 108 master.f90
oceanG 000000000040B50E Unknown Unknown Unknown
libc.so.6 00007F15D7037D1D Unknown Unknown Unknown
oceanG 000000000040B3E9 Unknown Unknown Unknown
Hi Kate
I didn't remove the Build Directory. I found the set_data.f90 So what should I do to correct it?
No, no, that was an example of what went wrong for me on some private code that isn't working yet. Your problem is something else again entirely. We need your line numbers and file names to know what your problem is.
