ROMS - 1D Model issue with Make all command make Error: 127
i am getting Error 127 during the make all command or any make command individually. i have posted the error message and the directory files list below. please help me resolve the error.
rony@rony-Ideapad-Z570:/media/rony/New Volume/Rony Important/IIT BBS ( Climate Science)/Final Year Project and Phd/Final Year Project/ROMS 1D/Roms_1d$ make all
fpp -I/usr/local/include -P -free cross_matrix.F > cross_matrix.i
/bin/sh: fpp: command not found
Makedefs:8: recipe for target 'cross_matrix.o' failed
make: *** [cross_matrix.o] Error 127
rony@rony-Ideapad-Z570:/media/rony/New Volume/Rony Important/IIT BBS ( Climate Science)/Final Year Project and Phd/Final Year Project/ROMS 1D/Roms_1d$ ls
alfabeta.F cross_matrix.F get_grid.m main.F Makedefs.sgi mixing.h plot.F set_color.F step3d.F
biology.F cross_matrix.i grid.h main.i Makedefs.sun mpc.F plot_t.m set_forces.F step3dS.F
bulk_flux.F diag_hflux.m lmd_kpp.F make_clim.m Make.depend o2sat.F README setup_grid.F taux.cdf
check_grid.m find_station.m lmd_swfrac.F Makedefs Makefile ocean3d.h rho_eos.F setup_initial.F
clim.data forces.data lmd_vmix.F Makedefs.linux make_forcing.m param.h romstools_param.m sst_skin.F
cppdefs.h forces.h lmd_wscale.F Makedefs.mac Make.README plot_all.m scalars.h start.m
Re: ROMS - 1D Model issue with Make all command make Error:
Your problem is right here:
Like the previous post, you are asking for help with CROCO tools on a forum that's for helping with a different code. Did you read the README file there?/bin/sh: fpp: command not found
yes i have read the read me file there .. i think i need to build the make file again using
ln -s Makedefs.linux Makedefs ..
but i need to run the program Makedefs.machine as mentioned in the Make.README file
HOW TO MAKE Makefile WORK:
1. On a particular machine, for example a Sun, establish symbolic
link:
ln -s Makedefs.sun Makedefs
(If the file for the paricular type of machine is not available
create it, using one of the existing "Makedefs.machine" files
as a template. Define appropriate compiler options.)
i think if i change the compiler options to gcc or g++ which are available in my linux, but i ned the make.machine fileif u can help me providing the make.machine file where i could change my path .. or if i m thinking it in wrong direction please help me with this ..
can you please provide me the link of the post you were mentioning
We are using roms1d. I've attached the version we use which compiles ok in a Linux machine (Ubuntu)
Hope this helps,
Hope this helps,
- Roms1d.tar.gz
- (413.33 KiB) Downloaded 461 times
Andres Sepulveda
Geophysics Department
University of Concepcion
Hello Andreas ,
Thanks for sharing the Roms 1d files .. i have checked the file are you using the ifort compiler - like are you using the inter parallel studio XE for the ifort compiler ???
Please check the bold lines in the code
# Header makefile: Sparc/Sun/Ultra version.
# (1) General machine independent rules and definitions
.SUFFIXES: .o .f .i .F
.F.o:
$(CPP) -P $(CPPFLAGS) $*.F > $*.i
mpc $*.i > $*.f
rm $*.i
$(CFT) -c $(FFLAGS) $*.f
rm $*.f
.F.f:
mpc $*.i > $*.f
rm $*.i
.f.o:
.F:
$(CFT) -o $@ $(FFLAGS) $(LDFLAGS) $<
.f:
# Machine dependent definitions for a Sun machine
# CPP Name of the C preprocessor
# CPPFLAGS Flags to the C preprocessor
# CFT Name of the fortran compiler to use
# FFLAGS Flags to the fortran compiler
# LDR Program to load the objects into an executable
# LDFLAGS Flags to the loader
# CDFLIB Path to netCDF library,
SHELL = /bin/sh
CC = cc
[b]CPP = fpp -I/usr/local/include
CFT = ifort
LDR = ifort[/b]
CPPFLAGS = -free
FFLAGS = -O3 -w90 -w95 -cm -r8 -i4
LDFLAGS =
LIBNCAR = -L/usr/local/src/ncarg\
-lncarg -lncarg_gks -lncarg_c -lX11 -lXext -lX11 -lm
error is resolved after installing intel parallel studio xe 2017 ..
and other 32bit library component for ubuntu.
Hi, I have come across the same problem, is it working for you now after installing intel parallel studio xe 2017?bikirandas wrote:error is resolved after installing intel parallel studio xe 2017 ..
