Optimum number of CPU-s to be used?
jayasankar
#1 Unread post by jayasankar »
Is there a thumb rule or an expression for the optimum number of CPUs to be used for a ROMS simulation?
Re: Optimum number of CPU-s to be used?
It depends on so many variables. It's best just to do some tests on your own problem using different numbers of cores. It mostly depends on your grid - too many cores and communications dominate the run time, too few and you don't fit into cache.
