Hi what does inflow for nudging time scale mean??
kobl1201
#1 Unread post by kobl1201 »
Hi
OBCFAC is the radio of inflow and outflow nudging time scale.
Here, I wonder the meaning of inflow and outflow for nudgiinh time scale.
Inflow means data of climatology and outflow means the data calculated in model???
IF i set obcfac =5 to obcfac = 10, what does it mean??
Re: Hi what does inflow for nudging time scale mean??
Say TNUDG=200, that means the nudging (if on) will be a timescale of 200 days if the flow is going out. Then an OBCFAC=10 will mean that the inflow nudging timescale will be ten times shorter, or 20 days.
kobl1201
#3 Unread post by kobl1201 »
Thanks Kate.
Here, inflow and outflow mean current in the boundary ???
Is it right??
Sort of. The model computes the wave speed (and direction) at each grid point and uses that to determine if things are "inflow" or "outflow". Look at say u3dbc_im.F:
                dUdt=u(Istr+1,j,k,nstp)-u(Istr+1,j,k,nout)
                dUdx=u(Istr+1,j,k,nout)-u(Istr+2,j,k,nout)
                  IF ((dUdt*dUdx).lt.0.0_r8) THEN
                    tau=obc_in
                  ELSE
                    tau=obc_out
