I've been starting to play with ROMS 3.7 to eventually upgrade my ice shelf application from ROMS 3.4
Afte a few unsuccessful tests with small simple domains including an ice shelf I went back to the weddell test case.
The problem remains; the model blows up after a few time steps on huge zeta +/- 50m. Has anyone successfully run the weddell test case?
There are few other posts here that appear to have encountered similar problems (2013) but no replies.
One thing I noticed the Haney number seems quite big (45) but I've tried ice shelves with flat ocean bottom and tiny gradient zice (10cm/km) - to no avail. The problem of big zeta and subsequent velocities that cause the blow up remains.
any ideas?
Thank you
Stefan
jes@linux-flht:~/Modeling/ROMS_projects/025/simulations/wed_test> mpirun -np 1 oceanM ocean_weddell.in
Sunday - November 6, 2016 - 1:31:22 AM
Idealized Weddell Sea Shelf Application
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/lib64/mpi/gcc/openmpi/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 820M
Local Root : /home/jes/Modeling/ROMS_code/ROMS_V4
Header Dir : /home/jes/Modeling/ROMS_projects/025/simulations/wed_test
Header file : weddell.h
Analytical Dir: /home/jes/Modeling/ROMS_code/ROMS_V4/ROMS_jes/Functionals
Resolution, Grid 01: 0300x0010x030, Parallel Nodes: 1, Tiling: 001x001
8640 ntimes Number of timesteps for 3-D equations.
50.000 dt Timestep size (s) for 3-D equations.
864 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
864 nHIS Number of timesteps between the writing fields
into history file.
0 nQCK Number of timesteps between the writing fields
into quicksave file.
time-averaged data.
864 nAVG Number of timesteps between the writing of
for tracer 02: salt
1027.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
for tracer 02: salt
for 3D momentum.
-0.278 T0 Background potential temperature (C) constant.
34.649 S0 Background salinity (PSU) constant.
Output Restart File: /home/jes/Modeling/ROMS_projects/025/output/rst/025_rst_wed_01.nc
Output History File: /home/jes/Modeling/ROMS_projects/025/output/025_his_wed_01.nc
Output Averages File: /home/jes/Modeling/ROMS_projects/025/output/025_avg_wed_01.nc
Tile partition information for Grid 01: 0300x0010x0030 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 300 1 10 90000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 300.50 0.50 10.50 RHO-points
0 1.00 300.00 0.50 10.50 U-points
0 0.50 300.50 1.00 10.00 V-points
HaloSizeI(1) = 933
HaloSizeJ(1) = 72
TileSide(1) = 305
TileSize(1) = 5490
zeta 1 Chapman Imp Periodic Chapman Imp Periodic
ubar 1 Flather Periodic Flather Periodic
vbar 1 Flather Periodic Flather Periodic
u 1 Radiation Periodic Radiation Periodic
v 1 Radiation Periodic Radiation Periodic
temp 1 Radiation Periodic Radiation Periodic
salt 1 Radiation Periodic Radiation Periodic
WEDDELL Idealized Weddell Sea Shelf Application
ANA_GRID Analytical grid set-up.
ICESHELF Include Ice Shelf Cavities.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion.
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity.
TS_A4HADVECTION Fourth-order Akima horizontal advection of tracers.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 28748) is active.
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0099988 -4.916 -1.667 -23.039 -41.162
28 -0.0666667 -0.0200977 -9.865 -3.333 -46.292 -82.719
27 -0.1000000 -0.0303977 -14.879 -5.000 -69.975 -125.071
26 -0.1333333 -0.0410019 -19.992 -6.667 -94.308 -168.624
25 -0.1666667 -0.0520166 -25.239 -8.333 -119.519 -213.799
24 -0.2000000 -0.0635518 -30.654 -10.000 -145.842 -261.029
23 -0.2333333 -0.0757230 -36.277 -11.667 -173.525 -310.773
22 -0.2666667 -0.0886521 -42.145 -13.333 -202.827 -363.509
21 -0.3000000 -0.1024685 -48.302 -15.000 -234.026 -419.751
20 -0.3333333 -0.1173104 -54.793 -16.667 -267.418 -480.043
19 -0.3666667 -0.1333264 -61.664 -18.333 -303.319 -544.973
18 -0.4000000 -0.1506768 -68.970 -20.000 -342.072 -615.173
17 -0.4333333 -0.1695352 -76.766 -21.667 -384.048 -691.331
16 -0.4666667 -0.1900904 -85.113 -23.333 -429.651 -774.190
15 -0.5000000 -0.2125480 -94.078 -25.000 -479.321 -864.565
14 -0.5333333 -0.2371329 -103.735 -26.667 -533.538 -963.342
13 -0.5666667 -0.2640911 -114.163 -28.333 -592.828 -1071.493
12 -0.6000000 -0.2936925 -125.450 -30.000 -657.768 -1190.085
11 -0.6333333 -0.3262332 -137.692 -31.667 -728.990 -1320.288
10 -0.6666667 -0.3620389 -150.996 -33.333 -807.191 -1463.387
9 -0.7000000 -0.4014681 -165.477 -35.000 -893.138 -1620.799
8 -0.7333333 -0.4449152 -181.264 -36.667 -987.673 -1794.082
7 -0.7666667 -0.4928153 -198.498 -38.333 -1091.726 -1984.954
6 -0.8000000 -0.5456476 -217.335 -40.000 -1206.322 -2195.308
5 -0.8333333 -0.6039409 -237.947 -41.667 -1332.590 -2427.233
4 -0.8666667 -0.6682787 -260.524 -43.333 -1471.779 -2683.034
3 -0.9000000 -0.7393048 -285.274 -45.000 -1625.264 -2965.254
2 -0.9333333 -0.8177301 -312.429 -46.667 -1794.565 -3276.701
1 -0.9666667 -0.9043396 -342.244 -48.333 -1981.359 -3620.475
0 -1.0000000 -1.0000000 -375.000 -50.000 -2187.500 -4000.000
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651644 0.0501156998674241-0.0034654566136460 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792859
6 0.0029141799764308 0.0501428056118168 0.0000580677400949 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865133 0.0497264335364439 0.0139401130576348 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767398 0.4496985103876601
10 0.0161716623600090 0.0486998273761630 0.0421751148367488 0.4983983377638231
11 0.0207585511322367 0.0478912442581626 0.0629336659689855 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430846 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924699 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366961 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873358 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240974 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194839 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038023 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834592 0.9445203630883545
23 0.0746596950216179 0.0177785909158270 0.7190878767050771 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669231 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836255 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321975 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447905
28 0.0292219798521905 0.0017718319739095 0.9937853403740003 0.9996892670187000
29 0.0062146596259993 0.0003107329813000 0.9999999999999997 1.0000000000000000
ndtfast, nfast = 20 29 nfast/ndtfast = 1.45000
Minimum X-grid spacing, DXmin = 4.00000000E+00 km
Maximum X-grid spacing, DXmax = 4.00000000E+00 km
Minimum Y-grid spacing, DYmin = 4.00000000E+00 km
Maximum Y-grid spacing, DYmax = 4.00000000E+00 km
Minimum Z-grid spacing, DZmin = 2.31760771E-01 m
Maximum Z-grid spacing, DZmax = 3.79525219E+02 m
Minimum barotropic Courant Number = 5.36099192E-02
Maximum barotropic Courant Number = 1.75089263E-01
Maximum Coriolis Courant Number = 7.06854566E-03
Maximum grid stiffness ratios: rx0 = 5.934862E-02 (Beckmann and Haidvogel)
rx1 = 4.355871E+01 (Haney)
Initial basin volumes: TotVolume = 9.7173030207E+13 m3
MinVolume = 3.7081723434E+06 m3
MaxVolume = 6.0724035051E+09 m3
Max/Min = 1.6375731608E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00008640)
0 0 00:00:00 0.000000E+00 1.656305E+04 1.656305E+04 9.717303E+13
(000,00,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: /home/jes/Modeling/ROMS_projects/025/output/025_his_wed_01.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
DEF_AVG - creating average file, Grid 01: /home/jes/Modeling/ROMS_projects/025/output/025_avg_wed_01.nc
1 0 00:00:50 3.508325E-02 1.656297E+04 1.656301E+04 9.717303E+13
(005,01,01) 7.497819E-02 2.190022E-04 0.000000E+00 6.707515E+00
2 0 00:01:40 2.431575E-01 1.656276E+04 1.656300E+04 9.717303E+13
(020,01,30) 3.778368E-02 3.884554E-04 6.096451E+00 3.196035E+01
WRT_RST - wrote re-start fields (Index=1,1) in record = 0000001
Elapsed CPU time (seconds):
Node # 0 CPU: 0.143
Total: 0.143
Nonlinear model elapsed time profile, Grid: 01
Allocation and array initialization .............. 0.016 (11.1888 %)
Ocean state initialization ....................... 0.016 (11.1888 %)
Processing of output time averaged data .......... 0.002 ( 1.3986 %)
Computation of global information integrals ...... 0.003 ( 2.0979 %)
Writing of output data ........................... 0.017 (11.8881 %)
Model 2D kernel .................................. 0.023 (16.0839 %)
2D/3D coupling, vertical metrics ................. 0.003 ( 2.0979 %)
Omega vertical velocity .......................... 0.001 ( 0.6993 %)
Equation of state for seawater ................... 0.009 ( 6.2937 %)
3D equations right-side terms .................... 0.008 ( 5.5944 %)
3D equations predictor step ...................... 0.011 ( 7.6923 %)
Pressure gradient ................................ 0.007 ( 4.8951 %)
Corrector time-step for 3D momentum .............. 0.011 ( 7.6923 %)
Corrector time-step for tracers .................. 0.011 ( 7.6923 %)
Total: 0.138 96.5035
Message Passage: data gathering .................. 0.007 ( 4.8951 %)
Total: 0.007 4.8951
All percentages are with respect to total time = 0.143
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_grid.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Sunday - November 6, 2016 - 1:31:22 AM
