Hi~ i have question about sponge layer
kobl1201
#1 Unread post by kobl1201 »
Hello~
i want to apply sponge layer. Therefore, i change ana_sponge.h and then applied hear file.
and then i think i will turn on switch about sponge layer.
Which one should i turn on??
When i turned on the switch, which is LuvSponge and LtracerSponge, but the model didn't run.
Please help me~
Re: Hi~ i have question about sponge layer
Did you turn on ANA_SPONGE and recompile? How did the model not run? Did it give you some error messages?
kobl1201
#3 Unread post by kobl1201 »
Hi Kate~
i compile Ana_sponge.
The model didn't give message. just stop the model like this.
** Omit ***
ndtfast, nfast = 40 56 nfast/ndtfast = 1.40000
1.000000000000 1.039265571007 0.519632785503 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.21300
Minimum X-grid spacing, DXmin = 1.19947258E+00 km
Maximum X-grid spacing, DXmax = 1.25659681E+00 km
Minimum Y-grid spacing, DYmin = 1.19974708E+00 km
Maximum Y-grid spacing, DYmax = 1.25650836E+00 km
Minimum Z-grid spacing, DZmin = 1.21951220E-01 m
Maximum Z-grid spacing, DZmax = 2.15106297E+02 m
Minimum barotropic Courant Number = 3.94115797E-03
Maximum barotropic Courant Number = 1.02664661E-01
Maximum Coriolis Courant Number = 1.83076144E-03
At that time the model stopped.
The next thing in my model output is the report from GET_STATE, followed by reports from get_idata and get_data. Are you expecting it to read anything from files, like initial conditions, boundary conditions or forcing?
If reading from a file fails, you should be getting a report on that too.
kobl1201
#5 Unread post by kobl1201 »
Hi kate
when i turn off LuvSponge, the model run.
but if i turn on the LuvSponge, the model stop above.
the problem is also same reason, which you told me???
thank you~
#6 Unread post by kate »
I don't know why it stopped. I don't use the sponge options. I would have to watch it in a debugger to see what happened.
