Hi, when i run the ROMS model, the model blow up
kobl1201
#1 Unread post by kobl1201 »
Hi
When I run the ROMS model, the model, blew up after running about 1 hours.
The resolution is 1/72 and 41 vertical layers.
Now i have simulated East sea area.
However, when i set VISC2 = 5000, the model ran until the end.
I thought the VISC2(=5000) is too big. It is not reasonable number.
How can i do for running ROMS model.
Please give me some command and help.
thank you guy.
Re: Hi, when i run the ROMS model, the model blow up
When the model blew up, did you investigate where in the domain it blew up? Which field went bad first? We have no idea what went wrong.
I assume that by 1/72 you mean degrees latitude, longitude? Units would be helpful. Also plots of the troubles.
