Can ROMS read in albedo field from external files?
LeaF_7
#1 Unread post by LeaF_7 »
I wonder if I can map albedo values (from MODIS) to ROMS grid, is there a way to read in the albedo value when the model runs?
Thanks in advance for any suggestions.
Fan
Re: Can ROMS read in albedo field from external files?
The ROMS trunk code does not read albedo, but my branch does. Check out the ALBEDO_FILE option.
LeaF_7
#3 Unread post by LeaF_7 »
Thanks a lot, Kate.
I am currently working with your branch, will try to find out how to use it.
Thanks again!
Fan
LeaF_7
#4 Unread post by LeaF_7 »
Sorry Kate, I think i still need you help on how to use ALBEDO_FILE.
Should I provide it as a forcing file? Is it able to use a constant albedo field or the file need to be like the forcing files with time index?
Thanks a lot!
#5 Unread post by kate »
ALBEDO_FILE is looking for a forcing file. I have only ever used it with the MERRA albedo, which is a function of time and space. I believe forcing fields can have files with only one record, which eliminates the time interpolation, though I haven't tried it.
If what you want is a really simple (uniform?) field, you can use ANA_ALBEDO instead.
LeaF_7
#6 Unread post by LeaF_7 »
Thanks again!
I am using the reflectance values from MODIS MYD09A1, and mapping them to my model grid.
I am modelling the Yellow Sea with Solar radiation from ERA-interim(0.75 degree resolution).
Coastal region is always being over heated, I was suggested to look into the albedo distribution as the sediment suspension in this region.
Great thanks for the help!
LeaF_7
#7 Unread post by LeaF_7 »
I tested the ALBEDO_FILE.
It just works as the forcing files, which need the time variable.
To use a temporal invariant field, just provide the albedo at starttime and endtime (2 time index). I guess ROMS will do a linear interpolation to the albedo value.
m.hadfield
Forcing files require a time variable, but that can be given the attribute "calendar" with the value "none", in which case only a single value is required and will be applied to all times.
I assume Kate's albedo files work the same way, and if they don't it wouldn't be hard to fix the code so they do.
