about the initial file for the wet and dry case
jiangyuwu
Location: the state key lab of marine environment science, Xiamen,P.R.China
#1 Unread post by jiangyuwu »
The domain has large tidal flat area, shall I define the additional variables, e.g. WETDRY_MASK_* and the corresponding ZETA related with the critical water depth, in the initial file? Or shall I modify the code to run such case?
thanks very much
Re: about the initial file for the wet and dry case
Looking in get_state.F and checkvars.F, I see that the reading of the wet/dry masks only happens on PERFECT_RESTART:
# if defined WET_DRY   && defined PERFECT_RESTART
There is code to only read these things on restarts, not when nrrec is zero.
As for zeta, try it and see? I don't recall having to do anything special in my WET_DRY starts.
