I tried to use the atmospheric flux results from one of my previous runs to activate a new simulation. I had checked the shflux, swrad, sustr, svstr from either of my new run and my old run, they are fully equal. I can't check the EminusP with swflux, because the new run did not output it.
However, the conversion from EminusP to swflux is
swflux (cm day-1) = EminusP (m s-1) * 100/86400.
Since the all of the atmospheric forcing to the new simulation is from old run, sustr and svstr are in u and v coordinate.
This is my header file
/* Model Configuration Options */
# define SOLVE3D
# undef CURVGRID
# define MASKING
# define SPLINES
# undef DIAGNOSTICS_UV
# undef DIAGNOSTICS_TS
# define AVERAGES
# undef RST_SINGLE
# undef QCORRECTION
# define SCORRECTION
# define MODIFY_SALT_TNUDG
# undef SRELAXATION
# undef SPONGE
/* Pressure Gradient Algorithm */
# define DJ_GRADPS
/* Tracer Equation Options */
# undef T_PASSIVE
# define SALINITY
# define NONLIN_EOS
/* Tracer advection */
# undef TS_MPDATA /* Reduces checkerboard pattern compared to C4HADVECTION */
# define TS_A4HADVECTION /* Hernan's Recomendation */
# define TS_A4VADVECTION /* Hernan's Recomendation */
/* Tracer horizontal mixing */
# define DIFF_GRID
# define TS_DIF2
# define MIX_GEO_TS
/* Momemtum horizontal mixing */
# define VISC_GRID
# define MIX_S_UV
# define UV_VIS2
/* Momentum Equation Options */
# define UV_ADV
# define UV_COR
# define UV_QDRAG
/* turbulence mixing scheme */
# define LMD_MIXING /* KPP turned on */
# ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
# define LMD_BKPP
# define LMD_NONLOCAL
# undef MY25_MIXING /* MY25 turned off */
# ifdef MY25_MIXING
# undef GLS_MIXING
# ifdef GLS_MIXING
# undef CANUTO_A
/* surface forcing */
# undef BULK_FLUXES /*# define BULK_FLUXES*/ /* original set up */
# ifdef BULK_FLUXES
# define LONGWAVE_OUT
# define EMINUSP
# define SOLAR_SOURCE
# undef DIURNAL_SRFLUX
# else
# define ANA_SSFLUX
# define ANA_SMFLUX
# define ANA_STFLUX
/* define River flows */
# undef UV_PSOURCE
# undef TS_PSOURCE
/* Select Biological model option */
# undef RIVER_BIOLOGY
# undef NPZD_POWELL
# ifdef NPZD_POWELL
# define ANA_SPFLUX
# define ANA_BPFLUX
# undef CONST_PAR
# define SPITZ
/*define boundary conditon */
# define RADIATION_2D
/* bottom surface ANA Flux */
# define ANA_BSFLUX
# define ANA_BTFLUX
/* define water mass relaxation */
# undef TCLIMATOLOGY
# undef TCLM_NUDGING
/* Jaisons Modifications */
# undef RELATIVE_WIND
/* Memory Management */
# undef INLINE_2DIO
https://www.dropbox.com/s/xddyd8zkt4szj ... M.png?dl=0
![Image](https://www.dropbox.com/s/xddyd8zkt4szjhe/Screen%20Shot%202016-06-21%20at%2012.36.59%20PM.png?dl=0)
It turns out, If I let model has a longer run, I can see the sea surface temperature is reaching to 80 degree Celsius. Could anyone give me suggestions how to solve this abnormal warming?
