vertical mixing scheme
chenyingjian12
#1 Unread post by chenyingjian12 »
I am modelling the ocean response under the Katrina forcing. But the ocean cooling effect seems exaggerated no matter what method I use (eg. KPP, GLS or MY25). Also I have check the Akv and AKt. I found that the vertical profile flutuate at some points even I use #SPLINES_VDIFF and #SPLINES_VVSIC. So I want to know whether there is a solution of this problem. Thanks for your reply!
