problem in test case of upwelling(mod_netcdf.f90)
I am a first time user to install and run ROMS, when I attempt to compile the Upwelling case, I meet this and don't know what's going wrong.I set the build.bash just as the Tutorial(https://www.myroms.org/wiki/ROMS_UNSW2008),I have installed the intel compiler and use ifort. could you mind tell me how to deal with it ?
mod_netcdf.f90(19): error #7013: This module file was not generated by any release of this compiler. [NETCDF]
USE netcdf
mod_netcdf.f90(109): error #6592: This symbol must be a defined parameter, an enumerator, or an argument of an inquiry function that evaluates to a compile-time constant. [NF90_REAL]
integer, parameter :: NF_FOUT = nf90_real
mod_netcdf.f90(110): error #6592: This symbol must be a defined parameter, an enumerator, or an argument of an inquiry function that evaluates to a compile-time constant. [NF90_DOUBLE]
integer, parameter :: NF_FRST = nf90_double
mod_netcdf.f90(111): error #6592: This symbol must be a defined parameter, an enumerator, or an argument of an inquiry function that evaluates to a compile-time constant. [NF90_DOUBLE]
integer, parameter :: NF_TYPE = nf90_double
mod_netcdf.f90(117): error #6592: This symbol must be a defined parameter, an enumerator, or an argument of an inquiry function that evaluates to a compile-time constant. [NF90_64BIT_OFFSET]
integer :: CMODE = nf90_64bit_offset ! NetCDF 64-bit offset format
mod_netcdf.f90(117): error #6973: This is not a valid initialization expression. [NF90_64BIT_OFFSET]
mod_netcdf.f90(109): error #6404: This name does not have a type, and must have an explicit type. [NF90_REAL]
mod_netcdf.f90(110): error #6404: This name does not have a type, and must have an explicit type. [NF90_DOUBLE]
mod_netcdf.f90(117): error #6404: This name does not have a type, and must have an explicit type. [NF90_64BIT_OFFSET]
mod_netcdf.f90(212): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQUIRE]
status=nf90_inquire(ncid, n_dim, n_var, n_gatt, rec_id)
mod_netcdf.f90(214): error #6404: This name does not have a type, and must have an explicit type. [NF90_NOERR]
IF ((status.eq.nf90_noerr).and.(n_dim.le.Mdims)) THEN
mod_netcdf.f90(221): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQUIRE_DIMENSION]
status=nf90_inquire_dimension(ncid, dim_id(i), &
mod_netcdf.f90(706): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQUIRE]
status=nf90_inquire(my_ncid, n_dim, n_var, n_gatt, rec_id)
mod_netcdf.f90(715): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQUIRE_VARIABLE]
status=nf90_inquire_variable(my_ncid, var_id(i), &
mod_netcdf.f90(721): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQ_ATTNAME]
status=nf90_inq_attname(my_ncid, var_id(i), j, &
mod_netcdf.f90(809): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQUIRE_DIMENSION]
status=nf90_inquire_dimension(my_ncid, var_Dids(i), &
mod_netcdf.f90(825): error #6632: Keyword arguments are invalid without an explicit interface. [XTYPE]
& xtype = my_Atype, &
mod_netcdf.f90(826): error #6632: Keyword arguments are invalid without an explicit interface. [LEN]
& len = my_Alen)
mod_netcdf.f90(823): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQUIRE_ATTRIBUTE]
status=nf90_inquire_attribute(my_ncid, my_id, &
mod_netcdf.f90(829): error #6404: This name does not have a type, and must have an explicit type. [NF90_INT]
& (my_Atype.eq.NF90_INT)) THEN
mod_netcdf.f90(830): error #6404: This name does not have a type, and must have an explicit type. [NF90_GET_ATT]
status=nf90_get_att(my_ncid, my_id, &
mod_netcdf.f90(844): error #6404: This name does not have a type, and must have an explicit type. [NF90_FLOAT]
& ((my_Atype.eq.NF90_FLOAT ).or. &
mod_netcdf.f90(859): error #6404: This name does not have a type, and must have an explicit type. [NF90_CHAR]
ELSE IF (my_Atype.eq.NF90_CHAR) THEN
mod_netcdf.f90(982): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQ_VARID]
status=nf90_inq_varid(ncid, TRIM(myVarName), VarID)
mod_netcdf.f90(1066): error #6632: Keyword arguments are invalid without an explicit interface. [NAME]
& name = my_Vname, &
mod_netcdf.f90(1067): error #6632: Keyword arguments are invalid without an explicit interface. [NATTS]
& nAtts = my_natts)
mod_netcdf.f90(1065): error #6404: This name does not have a type, and must have an explicit type. [NF90_INQUIRE_VARIABLE]
status=nf90_inquire_variable(my_ncid, varid, &
mod_netcdf.f90(4515): catastrophic error: Too many errors, exiting
compilation aborted for mod_netcdf.f90 (code 1)
make: *** [/root/Projects/upwelling/Build/mod_netcdf.o] 错误 1
[root@centos upwelling]#
USE netcdf
& len = my_Alen)
& nAtts = my_natts)
Re: problem in test case of upwelling(mod_netcdf.f90)
I Customize the Build Script like that:
#export USE_MPI=on # distributed-memory parallelism
#export USE_MPIF90=on # compile with mpif90 script
#export which_MPI=mpich # compile with MPICH library
#export which_MPI=mpich2 # compile with MPICH2 library
#export which_MPI=openmpi # compile with OpenMPI library
#export USE_OpenMP=on # shared-memory parallelism
export FORT=ifort
#export FORT=gfortran
#export FORT=pgi
#export USE_DEBUG=on # use Fortran debugging flags
export USE_LARGE=on # activate 64-bit compilation
#export USE_NETCDF4=on # compile with NetCDF-4 library
#export USE_PARALLEL_IO=on # Parallel I/O with Netcdf-4/HDF5
export USE_MY_LIBS=on # use my library paths below
export FORT=ifort
#export FORT=pgi
You probably don't need USE_LARGE and you should be using USE_NETCDF4. However:
You need to have netcdf-fortran compiled with the same compiler you are using to build ROMS - the exact same version is most likely to be successful.mod_netcdf.f90(19): error #7013: This module file was not generated by any release of this compiler. [NETCDF]
USE netcdf
Thank you very much Kate,I reinstalled my Netcdf, the executable oceanS file is created successfully. But when I was going to run ROMS, another error happened :
[root@centos upwelling]# ./oceanS < ocean_upwelling.in
Monday - March 28, 2016 - 5:28:07 AM
MOD_NCPARAM - Unable to open variable information file:
ROMS/External/varinfo.dat
Default file is located in source directory.
You have the varinfo.dat file, but you don't have it in:
which is where you said it is in the ocean_upwelling.in file.ROMS/External/varinfo.dat
I changed the path in ocean_upwelling.in , tried it agian, lt looks like a success but a failure,oh.....
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
0 0 00:00:00 0.000000E+00 6.585677E+02 6.585677E+02 3.884376E+11
./oceanS: symbol lookup error: ./oceanS: undefined symbol: netcdf_mp_nf90_create_
Monday - March 28, 2016 - 6:15:09 AM
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /opt/intel/compilers_and_libraries_2016.2.181/linux/bin/intel64/ifort
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
SVN Revision : 783
Local Root : /root/MyDir
Header Dir : /root/Projects/upwelling
Header file : upwelling.h
Analytical Dir: /root/Projects/upwelling
Resolution, Grid 01: 0041x0080x016, Parallel Threads: 1, Tiling: 001x001
1440 ntimes Number of timesteps for 3-D equations.
288 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
into history file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
3.0000E+00 theta_s S-coordinate surface control parameter.
25.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
Output Diagnostics File: ocean_dia.nc
Tile partition information for Grid 01: 0041x0080x0016 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 41 1 80 52480
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -1.50 42.50 0.50 81.50 RHO-points
0 -2.00 42.00 0.50 81.50 U-points
0 -1.50 42.50 0.00 81.00 V-points
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
ANA_VMIX Analytical vertical mixing coefficients.
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms.
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion.
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_LDRAG Linear bottom stress.
Process Information:
Thread # 0 (pid= 23466) is active.
16 0.0000000 0.0000000 0.000 0.000 0.000 0.000
15 -0.0625000 -0.0019442 -0.809 -0.806 -1.348 -1.589
14 -0.1250000 -0.0078455 -1.668 -1.661 -2.966 -3.687
13 -0.1875000 -0.0179119 -2.580 -2.568 -4.867 -6.321
12 -0.2500000 -0.0324983 -3.549 -3.531 -7.077 -9.535
11 -0.3125000 -0.0521190 -4.581 -4.558 -9.630 -13.397
10 -0.3750000 -0.0774659 -5.686 -5.656 -12.573 -17.996
9 -0.4375000 -0.1094327 -6.875 -6.837 -15.967 -23.445
8 -0.5000000 -0.1491465 -8.162 -8.114 -19.889 -29.890
7 -0.5625000 -0.1980075 -9.564 -9.506 -24.435 -37.512
6 -0.6250000 -0.2577387 -11.104 -11.034 -29.721 -46.531
5 -0.6875000 -0.3304460 -12.808 -12.724 -35.892 -57.218
4 -0.7500000 -0.4186931 -14.709 -14.609 -43.121 -69.903
3 -0.8125000 -0.5255915 -16.846 -16.726 -51.622 -84.987
2 -0.8750000 -0.6549105 -19.266 -19.124 -61.651 -102.953
1 -0.9375000 -0.8112096 -22.028 -21.859 -73.518 -124.388
0 -1.0000000 -1.0000000 -25.200 -25.000 -87.600 -150.000
12 0.0043042707117221 0.0335513677379153-0.0022367614257356 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864348 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001213 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565097 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906204 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716643 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402368 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399432 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712342 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524359 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729578 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236653 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893981 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886213 0.8237939964192927
27 0.0432936737565710 0.0230872677537126 0.3506756411451924 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772280 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880565 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256415 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325521 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348098 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479478 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213239 0.9738247715198165
36 0.0503158038019030 0.0080591141492892 0.8085423793232269 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497611 0.9930692679747334
39 0.0376397765791564 0.0033640675316746 0.9367177506289175 0.9964333355064080
40 0.0305543017255206 0.0021094083123694 0.9672720523544381 0.9985427438187774
41 0.0217382098544504 0.0010909315881854 0.9890102622088885 0.9996336754069628
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 8.08965824E-01 m
Maximum Z-grid spacing, DZmax = 2.56123321E+01 m
Minimum barotropic Courant Number = 2.22358627E-01
Maximum barotropic Courant Number = 5.42494240E-01
Maximum Coriolis Courant Number = 2.47800000E-02
Maximum grid stiffness ratios: rx0 = 6.931666E-02 (Beckmann and Haidvogel)
rx1 = 8.661243E-01 (Haney)
Initial basin volumes: TotVolume = 3.8843755884E+11 m3
MinVolume = 8.4521383562E+05 m3
MaxVolume = 2.5612332106E+07 m3
Max/Min = 3.0302783777E+01
SVN Revision : 783
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
0 1 41 1 80 52480
Did you get a warning like that at the compile/linking phase too? It's probably missing the -lnetcdff in the link command.
hello kate
In order to avoid building C and fortran libraries respectively, I installed netcdf in version before 4.2 and run the upwelling case successfullly. With the purpose of getting the Cross-section plots,I installed a binary distribution of NCL6.1.2, which compiled against NETCDF-4.2. So I reinstalled netcdf in version 4.2.
[root@centox upwelling]# nf-config --all
This netCDF-Fortran 4.2 has been built with the following features:
--cc -> icc
--cflags -> -I/usr/local/include -I/usr/local/include
--libs -> -L/usr/local/lib -L/usr/local/lib -lnetcdf -lnetcdf
--fc -> ifort
--fflags -> -O3 -xHost -ip -no-prec-div -static-intel -I/usr/local/include
--flibs -> -L/usr/local/lib -lnetcdff -L/usr/local/lib -lnetcdf -lnetcdf
--has-f90 -> yes
--has-nc2 -> yes
--has-nc4 -> yes
--prefix -> /usr/local
--includedir-> /usr/local/include
--version -> netCDF-Fortran 4.2
[root@centox upwelling]# nc-config --all
This netCDF 4.2 has been built with the following features:
--cc -> icc
--libs -> -L/usr/local/lib -lnetcdf
--cxx -> @CXX@
--has-c++ -> @HAS_CXX@
--fc -> @FC@
--fflags -> @FFLAGS@ @MOD_FLAG@/usr/local/include
--flibs -> -L/usr/local/lib @NC_FLIBS@
--has-f77 -> @HAS_F77@
--has-f90 -> @HAS_F90@
--has-dap -> yes
--has-nc2 -> yes
--has-nc4 -> yes
--has-hdf5 -> yes
--has-hdf4 -> no
--has-pnetcdf-> no
--has-szlib ->
--version -> netCDF 4.2
export FORT=ifort
#export FORT=pgi
#export USE_LARGE=on # activate 64-bit compilation
if [ -n "${USE_MY_LIBS:+1}" ]; then
case "$FORT" in
ifort )
export ESMF_OS=Linux
export ESMF_COMPILER=ifort
export ESMF_BOPT=O
export ESMF_ABI=64
export ESMF_COMM=mpich
export ESMF_SITE=default
export ARPACK_LIBDIR=/opt/intelsoft/serial/ARPACK
if [ -n "${USE_MPI:+1}" ]; then
if [ "${which_MPI}" = "mpich" ]; then
export ESMF_DIR=/opt/intelsoft/mpich/esmf
export MCT_INCDIR=/opt/intelsoft/mpich/mct/include
export MCT_LIBDIR=/opt/intelsoft/mpich/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/mpich/PARPACK
elif [ "${which_MPI}" = "mpich2" ]; then
export ESMF_DIR=/opt/intelsoft/mpich2/esmf
export MCT_INCDIR=/opt/intelsoft/mpich2/mct/include
export MCT_LIBDIR=/opt/intelsoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/mpich2/PARPACK
elif [ "${which_MPI}" = "openmpi" ]; then
export ESMF_DIR=/opt/intelsoft/openmpi/esmf
export MCT_INCDIR=/opt/intelsoft/openmpi/mct/include
export MCT_LIBDIR=/opt/intelsoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/openmpi/PARPACK
fi
fi
if [ -n "${USE_NETCDF4:+1}" ]; then
if [ -n "${USE_PARALLEL_IO:+1}" ] && [ -n "${USE_MPI:+1}" ]; then
export NC_CONFIG=/opt/intelsoft/mpich/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/intelsoft/mpich/netcdf4/include
export NC_CONFIG=/opt/intelsoft/mpich2/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/intelsoft/mpich2/netcdf4/include
export NC_CONFIG=/opt/intelsoft/openmpi/netcdf4/bin/nc-config
export NETCDF_INCDIR=/opt/intelsoft/openmpi/netcdf4/include
fi
else
export NC_CONFIG=/usr/local/bin/nc-config
fi
else
fi
I got error like this
ifort: error #10005: unable to open argument file 'NC_FLIBS@'
make: *** [/root/Projects/upwelling/oceanS] 错误 1
--cc -> icc
--fc -> ifort
--has-f90 -> yes
--has-nc2 -> yes
--has-nc4 -> yes
--cc -> icc
--cxx -> @CXX@
--fc -> @FC@
--has-dap -> yes
--has-nc2 -> yes
--has-nc4 -> yes
--has-hdf5 -> yes
--has-hdf4 -> no
--has-pnetcdf-> no
--has-szlib ->
export FORT=ifort
#export FORT=pgi
case "$FORT" in
ifort )
export ESMF_BOPT=O
export ESMF_ABI=64
fi
fi
fi
else
fi
else
fi
You can either fix your nc-config script or invoke your nf-config script instead during the ROMS build.--flibs -> -L/usr/local/lib @NC_FLIBS@
Hello Kate,kate wrote:Did you get a warning like that at the compile/linking phase too? It's probably missing the -lnetcdff in the link command.
I am facing the same problem, when I running oceanS for upwelling case:
oceanS: symbol lookup error: oceanS: undefined symbol: __netcdf_MOD_nf90_create
/usr/bin/ld: warning: libhdf5_hl.so.100, needed by /opt/junk/netcdf4/lib/libnetcdf.so, may conflict with libhdf5_hl.so.8
/usr/bin/ld: warning: libhdf5.so.103, needed by /opt/junk/netcdf4/lib/libnetcdf.so, may conflict with libhdf5.so.8
Thanks for your help!
Best regards
Yifan
My hdf libraries are a few years old but are version 10.0.x, but that probably has nothing to do with this at all. Do you get a linking error from NetCDF rather than HDF?
Thanks for your reply, Kate!kate wrote:My hdf libraries are a few years old but are version 10.0.x, but that probably has nothing to do with this at all. Do you get a linking error from NetCDF rather than HDF?
When I run oceanS, I did get a error message about netcdf:
oceanS: error while loading shared libraries: libnetcdf.so.15: cannot open shared object file: No such file or directory
export LD_LIBARRY_PATH=${LD_LIBARAY_PATH}:/opt/junk/netcdf4/lib
Another possible information may be useful is that I hacked nf-config a little bit, since the whole netcdf folder has been moved and the nf-config point to old path. I edited nf-config to point to right folder. Before I edit the nf-config, I got error:
/usr/bin/ld: cannot find -lnetcdff
collect2: ld returned 1 exit status
make: *** [/home/ywang/roms/Projects/Upwelling/oceanS] Error 1
prefix=/opt/junk/netcdff
exec_prefix=${prefix}
libdir=${exec_prefix}/lib
includedir=${prefix}/include
cc="gcc"
fc="gfortran"
cflags=" -I${includedir} -I/opt/netcdf4/include"
fflags="-I${includedir}"
has_dap="yes"
has_nc2="yes"
has_nc4="yes"
has_f90="no"
has_f03="yes"
#flibs="-L${libdir} -lnetcdff -L/opt/junk/netcdf4/lib -lnetcdf -lnetcdf -lhdf5_hl -lhdf5 -lsz -lcurl -lm "
flibs="-L${libdir} -lnetcdff -L/opt/junk/netcdf4/lib -lnetcdf -lnetcdf -lhdf5_hl -lhdf5 -lsz -lcurl "
The reason I remove the '-lm' from flibs is that I guess it may related with matlab, while I found the library file libhdf5_hl.so.8, causing conflict, comes from a matlab library folder.... Actually I have no idea what -lm is.
Best regards
Yifan
-lm is a math library, not matlab.
Maybe try putting your junk directory at the front of LD_LIBRARY_PATH instead.
Thank you Kate,kate wrote:-lm is a math library, not matlab.
It seems the warning messages didn't bother me anymore.
I found I didn't add the netcdf-fortran library folder into LD_LIBRARY_PATH, so I put netcdf and netcdf-fortran library folders at the front of LD_LIBRARY_PATH in .bash_profile and re-compile the build.bash. The oceanS came out with the same warning messages. However, the good thing is that there is no problem of running oceanS right. now. Thank you!
Best regards
Yifan
