Compile's problem with build.bash (Upwelling)
rivano10
#1 Unread post by rivano10 »
Hi forum (im new in ROMS).
Im trying to run the build.bash (Upwelling) to compile ROMS and it doesn't work. I changed some directories and commment out options but i don't know how fix it.
I am getting the error like this:
/home/gino/src/Projects/upwelling/Build/mod_netcdf.f90:222: referencia a `__netcdf_MOD_nf90_inquire_dimension' sin definir
make: *** [/home/gino/src/Projects/upwelling/oceanG] Error 1
I would be grateful, if anybody point can out the possible causes of the above error?
Re: Compile's problem with build.bash (Upwelling)
You can start by checking the FAQ. Does that help?
