Test case compile
bperfect
Test case compile
#1 Unread post by bperfect »
I'm trying to run one of the template cases, and I'm running into what seems to be a classic library linking error:
/usr/bin/gfortran -frepack-arrays -O3 -ffast-math
/home/bperfect/roms/roms_templates/seamount/Build/libANA.a /home/bperfect/roms/roms_templates/seamount/Build/libUTIL.a /home/bperfect/roms/roms_templates/seamount/Build/libMODS.a -L/usr/local/lib -lnetcdf
/home/bperfect/roms/roms_templates/seamount/Build/libUTIL.a(close_io.o): In function `close_out_':
close_io.f90:(.text+0x106e): undefined reference to `__netcdf_MOD_nf90_strerror'
Followed by a ton of errors.
The wiki tells me that I appear to be missing a -lnetdcff flag on the final line before the error. The problem is that there isn't any direction on how to make that flag appear. I've played around in the basic build.bash file that came with ROMS, but to no avail. When I change around the system variables within that default build file to reflect the locations of my own installations, I get the same failure, but without either the -L/usr/local/lib or -lnetcdf flag.
My nc-config is as follows:
bperfect@fourier:seamount $ nc-config --all
This netCDF 4.4.0 has been built with the following features:
  --cc        -> gcc
  --cflags    ->  -I/usr/local/include -I/usr/local/include
  --libs      ->
  --has-c++   -> no
  --cxx       ->
  --has-c++4  -> no
  --cxx4      ->
  --fc        ->
  --fflags    ->
  --flibs     ->
  --has-f90   -> no
  --has-dap   -> no
  --has-nc2   -> yes
  --has-nc4   -> yes
  --has-hdf5  -> yes
  --has-hdf4  -> no
  --has-pnetcdf-> no
  --prefix    -> /usr/local
  --includedir-> /usr/local/include
  --version   -> netCDF 4.4.0
It seems to me the the --libs flag should have something, but again, I have no idea how to make that happen.
As far as the installation goes, I've installed and tested, to the best of my knowledge, everything that ROMS requires.
Any wisdom on how to fix this?
Re: Test case compile
--has-f90 -> no
You need to have netcdf-fortran as well as the C netcdf library. It became a separate package since some of the ROMS documentation was written.
bperfect
#3 Unread post by bperfect »
I have the netcdf fortran library installed as well (perhaps something is configured incorrectly?)
bperfect@fourier:Downloads $ nf-config --all
This netCDF-Fortran 4.4.3 has been built with the following features:
  --cc        -> gcc
  --fc        -> gfortran
  --fflags    -> -I/usr/local/include
  --flibs     -> -L/usr/local/lib -lnetcdff -L/usr/local/lib -lnetcdf -lnetcdf
  --has-f90   -> no
  --has-f03   -> yes
  --has-nc2   -> yes
  --has-nc4   -> yes
  --version   -> netCDF-Fortran 4.4.3
Simply change "nc-config" to "nf-config" in the the appropriate Compilers/xxx file.
Note - I don't know why installing the Fortran part doesn't always update nc-config, but I have experienced that too.
