Grid cell volume
zanzigr
Grid cell volume
#1 Unread post by zanzigr »
Is there an easy way to find the grid cell volumes of an entire grid? I'm looking to find the volume of a water mass and this would make things very simple.
I'm not sure I completely understand the geometry involved, so I'm having a hard time figuring out how to calculate it. Surely the code has to do this somewhere...
Rebecca
The volume of a grid cell is (h+zeta)/(pm*pn). Look at how the diagnostic my_volume is computed for the entire domain in diag.F. In 3-D, the vertical sum of Hz should be equal to (h+zeta), as should z_w(N)-z_w(0).
zanzigr
#3 Unread post by zanzigr »
It seems to me that this computes the volume for the entire water column. How, then, does this get split between the different vertical levels?
In other words, if I want the volume at i=1, j=1 and N=12 (of 20), how do I find this?
The vertical delta z is Hz(i,j,k).
stef
#5 Unread post by stef »
Hi!
I still use version 2.2, and don't know if anything has changed in the new version.
In mod_grid.F there are some variables defined, three of them are:
Hz: Thickness of vertical rho-Points
Huon: Total u-Momentum Flux term: interpolated(Hz)*u*dy (dy is the same as 1/pn, at least for a rectilinear grid, I don't know anything about curvilinear setups)
Hvom: interpolated(Hz)*v*dx
The 'allocate' functions in that file allocate N vertical levels for each i,j for each one of those variables.
Roms uses a staggered grid (see http://marine.rutgers.edu/po/documentat ... =technique ).
Hz is, as documented in mod_grid, the thickness at rho points (thickness means cell hight). But due to the staggered grid, there is a different thickness at the neighbouring u and v points.
For example, take the Finite-Volume formulation for a tracer. Tracers are defined on rho-points, so the cell must be constructed in a way that it's center is a rho-point. Now the in- and outflow of the cell has to be calculated, to update the tracer. The in- and outflow has to be calculated on the cell boundaries, and in the case of a staggered grid, that's where the u- and v- points are located. To calculate the inflow per second, one has to multiply area*velocitynormal*tracer. Area is dx*Height or dy*Height, but one needs the hight at VELOCITY-points, not at rho points, so one has to linearly interpolate Hz between neighbouring rho-point-Heights (e.g, in set_massflux).
One problem in the above explanation is that cell heights are changing during a 3d-timestep, and if I understood correctly, the massflux for calculating tracer-flux is averaged in fast barotropic time to the middle of the flux-period. That means, in the equation for tracer-update you will find the following cell-heights:
one in the middle of the cell at time n to calculate the old volume of the grid cell.
one in the middle of the cell at time n+1, to calculate new volume.
one at each boundary at time n+1/2, for the inflow-area.
The second of the above is also calculated with the barotropic time steps, but with different weights as the third.
See the Shchepetkin-McWilliams 2005 paper for more info.
For the momentum equations, things are similar, I think, exept that now the cell boundaries coincide with rho points, so no need to interpolate the cellheights.
The above is all simplified, but what I want to say is that one has to take care at what time and at what location to define the height.
I hope I could help you, I spent some weeks to find out what I just wrote (and even now i don't know if it's right or not... :wink: )
--Stefan
stef
#6 Unread post by stef »
I think that what I wrote above only makes sense for 2nd order centered advection, both for velocity and tracers.
AlexisEspinosa
Re: Grid cell volume
#7 Unread post by AlexisEspinosa »
Can Hz be saved in the history files?
Or is set_depth function the only way to obtain it for postprocessing?
Many thanks.
Alexis
#8 Unread post by kate »
One could add the writing of Hz to def_his.F and wrt_his.F. You'd also have to invent an id tag for it, put it in varinfo.dat and read it where they get read. Also check the Hout(idHz) in read_phypar.F. You can grep for one like idDano to see how it's done. Note that Hernan believes the id tags should all be six characters long, so perhaps idHzee or idHzed? :roll:
Most of us have postprocessing tools that know how to compute Hz, be it Matlab or whatever. Or one colleague asks me to write a static file of the z_rho, z_w appropriate for zeta=0 which I do with a Python script.
