Hi ROMS users
I am running a simulation of Bay of Bengal to study it's circulation. I need to run a case where the wind forcing is switched off. If I do not define BULK_FLUXES, it is straightforward to switch the winds off by specifying 0 values for it in the stress files. I want to know if there is way in which I define BULK_FLUXES and switch the winds off.
Thanks.
bulk forcing
Re: bulk forcing
Sure, just #define ANA_WINDS and give it zero winds.
Re: bulk forcing
Thanks kate. But, would it not affect the calculation of other fluxes, since many of them depend on the Monin-Obukhov similarity parameters (e.g. Wstar)? I want only stresses to be zero while retaining all other surface forcings.
Re: bulk forcing
The easiest way to do that is to simply hack the bulk_flux routine. Put an #ifdef NO_STRESS (or whatever you like) around some code to zero out the stresses after they've been set, before the communications section at the bottom.
Re: bulk forcing
Thanks kate..!!
