Early blowing of model simulation
09CL6010
#1 Unread post by 09CL6010 »
I have created grid for North Indian Ocean, boundary and intial files from HYCOM daily data and forcing from ECMWF for ROMS (version 3.7). I started simulation with very basic C-preprocessing Options. But the model is blowing up after 21 time steps. Wheather this is a problem of model configuration or something else?? Any suggestions would be really helpful to me. Thanks in advance.
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/gfortran
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
SVN Revision : 755M
Local Root : /home/user/work/tags/trunk
Header Dir : /home/user/work/tests/bobh2
Header file : bob.h
Analytical Dir: /home/user/work/tests/bobh2
Resolution, Grid 01: 0287x0248x032, Parallel Threads: 1, Tiling: 001x001
522720 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
1440 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
288 nHIS Number of timesteps between the writing fields
into history file.
288 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
288 nAVG Number of timesteps between the writing of
288 ndefAVG Number of timesteps between creation of new
time-averaged file.
for tracer 02: salt
for turbulent energy.
5 lmd_Jwt Jerlov water type.
7.0000E+00 theta_s S-coordinate surface control parameter.
2.0000E+00 theta_b S-coordinate bottom control parameter.
250.000 Tcline S-coordinate surface/bottom layer width (m) used
1.000 dstart Time-stamp assigned to model initialization (days).
20050101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
2.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
2.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
2.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
2.0000E+01 obcfac Factor between passive and active
T Hout(idu3dE) Write out 3D U-wastward component at RHO-points.
T Hout(idv3dN) Write out 3D V-northward component at RHO-points.
T Hout(idUbms) Write out bottom U-momentum stress.
T Hout(idVbms) Write out bottom V-momentum stress.
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idVvis) Write out vertical viscosity: AKv.
T Hout(idTdif) Write out vertical diffusion: AKt(itemp).
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
Output Restart File: ./out/rst_bob.nc
Prefix for History Files: ./out/his_bob
Prefix for Averages Files: ./out/avg_bob
Input Grid File: ./in/nio_grid.nc
Input Nonlinear Initial File: ./in/nio_initial.nc
Input Forcing File 01: ./in/bob_sms_era.nc
Input Forcing File 02: ./in/bob_shflux_era.nc
Input Forcing File 03: ./in/bob_swflux_era.nc
Input Forcing File 04: ./in/bob_swrad_era.nc
Input Boundary File: ./in/nio_boundary.nc
Tile partition information for Grid 01: 0287x0248x0032 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 287 1 248 2277632
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 287.50 0.50 249.50 RHO-points
0 0.00 287.00 0.50 249.50 U-points
0 0.50 287.50 0.00 249.00 V-points
zeta 1 Chapman Imp Chapman Imp Chapman Imp Closed
ubar 1 Flather Flather Flather Closed
vbar 1 Flather Flather Flather Closed
u 1 Rad + Nud Rad + Nud Rad + Nud Closed
v 1 Rad + Nud Rad + Nud Rad + Nud Closed
temp 1 Rad + Nud Rad + Nud Rad + Nud Closed
salt 1 Rad + Nud Rad + Nud Rad + Nud Closed
tke 1 Gradient Gradient Gradient Closed
BOB Indian Ocean simulation 10 KM grid HYCOM daily obc ECMWF fluxes
LIMIT_BSTRESS Limit bottom stress to maintain bottom velocity direction.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
TS_C4HADVECTION Fourth-order centered horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_LDRAG Linear bottom stress.
Process Information:
Thread # 0 (pid= 2399) is active.
32 0.0000000 0.0000000 0.000 0.000 0.000 0.000
31 -0.0312500 -0.0001015 -1.805 -3.919 -7.249 -7.832
30 -0.0625000 -0.0004109 -3.613 -7.864 -14.926 -16.546
29 -0.0937500 -0.0009428 -5.425 -11.837 -23.060 -26.207
28 -0.1250000 -0.0017224 -7.241 -15.840 -31.703 -36.920
27 -0.1562500 -0.0027867 -9.063 -19.880 -40.931 -48.843
26 -0.1875000 -0.0041860 -10.890 -23.961 -50.848 -62.189
25 -0.2187500 -0.0059860 -12.724 -28.092 -61.589 -77.239
24 -0.2500000 -0.0082712 -14.566 -32.284 -73.326 -94.350
23 -0.2812500 -0.0111480 -16.419 -36.550 -86.280 -113.975
22 -0.3125000 -0.0147496 -18.284 -40.906 -100.723 -136.681
21 -0.3437500 -0.0192413 -20.165 -45.374 -116.996 -163.168
20 -0.3750000 -0.0248266 -22.064 -49.978 -135.517 -194.303
19 -0.4062500 -0.0317554 -23.987 -54.751 -156.799 -231.148
18 -0.4375000 -0.0403320 -25.938 -59.729 -181.467 -274.995
17 -0.4687500 -0.0509247 -27.925 -64.959 -210.280 -327.409
16 -0.5000000 -0.0639753 -29.953 -70.497 -244.145 -390.268
15 -0.5312500 -0.0800085 -32.034 -76.407 -284.140 -465.802
14 -0.5625000 -0.0996389 -34.176 -82.767 -331.528 -556.623
13 -0.5937500 -0.1235742 -36.394 -89.666 -387.765 -665.737
12 -0.6250000 -0.1526095 -38.699 -97.201 -454.484 -796.524
11 -0.6562500 -0.1876096 -41.108 -105.482 -533.463 -952.659
10 -0.6875000 -0.2294704 -43.635 -114.621 -626.543 -1137.949
9 -0.7187500 -0.2790515 -46.296 -124.725 -735.492 -1356.046
8 -0.7500000 -0.3370698 -49.103 -135.884 -861.782 -1609.998
7 -0.7812500 -0.4039469 -52.064 -148.150 -1006.280 -1901.595
6 -0.8125000 -0.4796058 -55.176 -161.513 -1168.828 -2230.512
5 -0.8437500 -0.5632305 -58.426 -175.873 -1347.749 -2593.279
4 -0.8750000 -0.6530234 -61.783 -191.003 -1539.347 -2982.258
3 -0.9062500 -0.7460330 -65.196 -206.535 -1737.557 -3384.908
2 -0.9375000 -0.8381633 -68.593 -221.958 -1933.960 -3783.820
1 -0.9687500 -0.9244936 -71.890 -236.655 -2118.442 -4158.085
0 -1.0000000 -1.0000000 -75.000 -250.000 -2280.677 -4486.353
12 0.0043042707117221 0.0335513677379153-0.0022367614257356 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864348 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001213 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565097 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906204 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716643 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402368 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399432 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712342 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524359 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729578 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236653 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893981 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886213 0.8237939964192927
27 0.0432936737565710 0.0230872677537126 0.3506756411451924 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772280 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880565 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256415 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325521 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348098 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479478 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213239 0.9738247715198165
36 0.0503158038019030 0.0080591141492892 0.8085423793232269 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497611 0.9930692679747334
39 0.0376397765791564 0.0033640675316746 0.9367177506289175 0.9964333355064080
40 0.0305543017255206 0.0021094083123694 0.9672720523544381 0.9985427438187774
41 0.0217382098544504 0.0010909315881854 0.9890102622088885 0.9996336754069628
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 8.45904839E+00 km
Maximum X-grid spacing, DXmax = 9.23851059E+00 km
Minimum Y-grid spacing, DYmin = 8.46654806E+00 km
Maximum Y-grid spacing, DYmax = 9.23803707E+00 km
Minimum Z-grid spacing, DZmin = 1.80464157E+00 m
Maximum Z-grid spacing, DZmax = 4.02649068E+02 m
Minimum barotropic Courant Number = 8.30461108E-03
Maximum barotropic Courant Number = 6.42329179E-02
Maximum Coriolis Courant Number = 3.37046112E-03
NLM: GET_STATE - Read state initial conditions, t = 1 00:00:00
(Grid 01, File: nio_initial.nc, Rec=0001, Index=1)
- free-surface
(Min = 0.00000000E+00 Max = 7.27000058E-01)
(Min = -5.15692831E-01 Max = 3.95363075E-01)
(Min = -5.12753684E-01 Max = 4.60237403E-01)
- u-momentum component
(Min = -1.18300009E+00 Max = 7.77000010E-01)
- v-momentum component
(Min = -9.75000024E-01 Max = 9.53000069E-01)
- potential temperature
(Min = -2.23200035E+00 Max = 3.12929993E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.65000000E+01)
GET_2DFLD - surface u-momentum stress, t = 0 22:30:00
(Rec=0000008, Index=1, File: bob_sms_era.nc)
(Tmin= 0.0625 Tmax= 2190.9375)
(Min = -2.78011231E-04 Max = 1.99272034E-04)
GET_2DFLD - surface v-momentum stress, t = 0 22:30:00
(Min = -2.44697013E-04 Max = 1.37507575E-04)
GET_2DFLD - solar shortwave radiation flux, t = 0 22:30:00
(Rec=0000008, Index=1, File: bob_swrad_era.nc)
(Min = 0.00000000E+00 Max = 3.96908503E-07)
GET_2DFLD - surface net heat flux, t = 0 22:30:00
(Rec=0000008, Index=1, File: bob_shflux_era.nc)
(Min = -1.15957530E-04 Max = 2.91507719E-07)
GET_2DFLD - surface net freswater flux, (E-P), t = 0 22:30:00
(Rec=0000008, Index=1, File: bob_swflux_era.nc)
(Min = -4.77261066E-07 Max = 1.32811036E-07)
GET_NGFLD - free-surface western boundary condition, t = 1 00:00:00
(Rec=0000002, Index=2, File: nio_boundary.nc)
(Tmin= 0.0000 Tmax= 364.0000)
(Min = 0.00000000E+00 Max = 5.12000024E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 4.57000017E-01)
GET_NGFLD - free-surface southern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 4.77000028E-01)
GET_NGFLD - 2D u-momentum western boundary condition, t = 1 00:00:00
(Min = -4.06101435E-01 Max = 5.34295142E-02)
GET_NGFLD - 2D v-momentum western boundary condition, t = 1 00:00:00
(Min = -2.54630931E-02 Max = 4.60237414E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 1 00:00:00
(Min = -3.50891352E-02 Max = 2.02111024E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -3.29293194E-03 Max = 6.41376600E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 1 00:00:00
(Min = -9.11614746E-02 Max = 8.37161317E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -1.45010501E-01 Max = 7.72403330E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 1 00:00:00
(Min = -8.49000037E-01 Max = 4.97000009E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 1 00:00:00
(Min = -4.53000009E-01 Max = 6.06000006E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 1 00:00:00
(Min = -2.49000013E-01 Max = 4.30000015E-02)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -7.00000003E-02 Max = 1.27000004E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 1 00:00:00
(Min = -5.59000015E-01 Max = 4.12000030E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -5.39000034E-01 Max = 7.46000051E-01)
GET_NGFLD - temperature western boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 2.88720016E+01)
GET_NGFLD - salinity western boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 3.60429993E+01)
GET_NGFLD - temperature eastern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 2.95240002E+01)
GET_NGFLD - salinity eastern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 3.19790001E+01)
GET_NGFLD - temperature southern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 3.08530006E+01)
GET_NGFLD - salinity southern boundary condition, t = 1 00:00:00
(Min = 0.00000000E+00 Max = 3.60220032E+01)
Maximum grid stiffness ratios: rx0 = 1.962070E-01 (Beckmann and Haidvogel)
rx1 = 6.018224E+00 (Haney)
Initial basin volumes: TotVolume = 7.6097767360E+15 m3
MinVolume = 1.3172781943E+08 m3
MaxVolume = 3.4360845197E+10 m3
Max/Min = 2.6084729365E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00522720)
GET_2DFLD - surface u-momentum stress, t = 1 01:30:00
(Rec=0000009, Index=2, File: bob_sms_era.nc)
(Min = -3.85931555E-04 Max = 2.59847245E-04)
GET_2DFLD - surface v-momentum stress, t = 1 01:30:00
(Min = -2.98971634E-04 Max = 1.48163594E-04)
GET_2DFLD - solar shortwave radiation flux, t = 1 01:30:00
(Rec=0000009, Index=2, File: bob_swrad_era.nc)
(Min = 2.85486879E-06 Max = 8.06676692E-05)
GET_2DFLD - surface net heat flux, t = 1 01:30:00
(Rec=0000009, Index=2, File: bob_shflux_era.nc)
(Min = -4.12584367E-05 Max = 2.30275818E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 1 01:30:00
(Rec=0000009, Index=2, File: bob_swflux_era.nc)
(Min = -3.01331672E-07 Max = 1.19216983E-07)
GET_NGFLD - free-surface western boundary condition, t = 2 00:00:00
(Rec=0000003, Index=1, File: nio_boundary.nc)
(Min = 0.00000000E+00 Max = 4.99000013E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 4.05000031E-01)
GET_NGFLD - free-surface southern boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 4.54000026E-01)
GET_NGFLD - 2D u-momentum western boundary condition, t = 2 00:00:00
(Min = -3.78326416E-01 Max = 5.61754405E-02)
GET_NGFLD - 2D v-momentum western boundary condition, t = 2 00:00:00
(Min = -7.94725865E-02 Max = 3.72756958E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 2 00:00:00
(Min = -4.32398543E-02 Max = 1.46310069E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 7.72477016E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 2 00:00:00
(Min = -1.09961316E-01 Max = 8.95321369E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 2 00:00:00
(Min = -1.35742590E-01 Max = 8.50378126E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 2 00:00:00
(Min = -9.37000036E-01 Max = 4.79000032E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 2 00:00:00
(Min = -3.12000006E-01 Max = 4.87000018E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 2 00:00:00
(Min = -1.58000007E-01 Max = 4.60000038E-02)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 2 00:00:00
(Min = -1.40000004E-02 Max = 1.44000009E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 2 00:00:00
(Min = -8.55000019E-01 Max = 3.27000022E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 2 00:00:00
(Min = -4.97000009E-01 Max = 8.88000071E-01)
GET_NGFLD - temperature western boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 2.88680000E+01)
GET_NGFLD - salinity western boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 3.59599991E+01)
GET_NGFLD - temperature eastern boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 2.93870010E+01)
GET_NGFLD - salinity eastern boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 3.19920006E+01)
GET_NGFLD - temperature southern boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 3.03069992E+01)
GET_NGFLD - salinity southern boundary condition, t = 2 00:00:00
(Min = 0.00000000E+00 Max = 3.63619995E+01)
0 1 00:00:00 4.478275E-03 1.504438E+04 1.504438E+04 7.778290E+15
(184,032,31) 5.090955E-03 4.816599E-03 0.000000E+00 1.221553E+00
DEF_HIS - creating history file, Grid 01: ./out/his_bob_0001.nc
1 1 00:01:00 5.679666E-03 1.504431E+04 1.504431E+04 7.778289E+15
(060,142,17) 6.748350E-04 2.566448E-03 3.438974E-02 1.581672E+00
2 1 00:02:00 9.010987E-03 1.504289E+04 1.504290E+04 7.778290E+15
(205,016,32) 1.423695E-03 6.142699E-04 6.573668E-01 3.000813E+00
3 1 00:03:00 1.170062E-02 1.504258E+04 1.504259E+04 7.778291E+15
(205,014,32) 3.307558E-04 2.571483E-03 4.784019E-01 3.537794E+00
4 1 00:04:00 1.660126E-02 1.504237E+04 1.504239E+04 7.778293E+15
(206,014,32) 5.248648E-04 9.366620E-04 5.655860E-01 4.286101E+00
5 1 00:05:00 2.486249E-02 1.504220E+04 1.504222E+04 7.778295E+15
(207,015,32) 1.300270E-03 1.109080E-03 5.432551E-01 2.688875E+00
6 1 00:06:00 3.647173E-02 1.504204E+04 1.504208E+04 7.778299E+15
(208,015,32) 1.842162E-03 9.927156E-04 4.996502E-01 3.477994E+00
7 1 00:07:00 5.135169E-02 1.504187E+04 1.504192E+04 7.778302E+15
(209,015,32) 7.008302E-04 8.492815E-04 3.922878E-01 4.431803E+00
8 1 00:08:00 6.949861E-02 1.504168E+04 1.504175E+04 7.778307E+15
(208,004,19) 5.925429E-03 2.077240E-03 3.394516E-01 5.375570E+00
9 1 00:09:00 8.970888E-02 1.504147E+04 1.504156E+04 7.778312E+15
(208,004,20) 6.477176E-03 2.515493E-03 4.406115E-01 6.301034E+00
10 1 00:10:00 1.118580E-01 1.504124E+04 1.504135E+04 7.778317E+15
(208,004,19) 7.500007E-03 2.392687E-03 4.837994E-01 7.191229E+00
11 1 00:11:00 1.349221E-01 1.504099E+04 1.504113E+04 7.778324E+15
(208,004,20) 7.932112E-03 2.824831E-03 5.980603E-01 8.234773E+00
12 1 00:12:00 1.579938E-01 1.504071E+04 1.504087E+04 7.778332E+15
(208,004,20) 8.373143E-03 2.918280E-03 6.997225E-01 9.291995E+00
13 1 00:13:00 1.814429E-01 1.504040E+04 1.504058E+04 7.778341E+15
(208,004,19) 9.094129E-03 2.785616E-03 7.939590E-01 1.028169E+01
14 1 00:14:00 2.038397E-01 1.504004E+04 1.504025E+04 7.778351E+15
(208,004,19) 9.538619E-03 2.795495E-03 9.074866E-01 1.127502E+01
15 1 00:15:00 2.234117E-01 1.503964E+04 1.503986E+04 7.778362E+15
(208,004,19) 9.730678E-03 2.704653E-03 1.036599E+00 1.218363E+01
16 1 00:16:00 2.416807E-01 1.503921E+04 1.503945E+04 7.778375E+15
(208,004,19) 9.589061E-03 2.514530E-03 1.191844E+00 1.275301E+01
17 1 00:17:00 2.587744E-01 1.503876E+04 1.503902E+04 7.778388E+15
(208,004,19) 9.189085E-03 2.225087E-03 1.337852E+00 1.357701E+01
18 1 00:18:00 2.773618E-01 1.503831E+04 1.503859E+04 7.778401E+15
(208,004,19) 8.428397E-03 1.800376E-03 1.524178E+00 1.479481E+01
19 1 00:19:00 2.964281E-01 1.503787E+04 1.503816E+04 7.778415E+15
(208,004,19) 7.286367E-03 1.021140E-03 1.712949E+00 1.656331E+01
20 1 00:20:00 3.155707E-01 1.503745E+04 1.503776E+04 7.778430E+15
(208,004,18) 5.375559E-03 1.905486E-04 1.903025E+00 1.831610E+01
21 1 00:21:00 3.349368E-01 1.503765E+04 1.503799E+04 7.778445E+15
(208,004,19) 5.552737E-03 5.508380E-04 2.088523E+00 1.962397E+01
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Elapsed CPU time (seconds):
Thread # 0 CPU: 61.831
Total: 61.831
Allocation and array initialization .............. 0.326 ( 0.5272 %)
Ocean state initialization ....................... 0.074 ( 0.1204 %)
Reading of input data ............................ 0.370 ( 0.5988 %)
Processing of input data ......................... 0.050 ( 0.0804 %)
Processing of output time averaged data .......... 0.747 ( 1.2085 %)
Computation of vertical boundary conditions ...... 0.019 ( 0.0310 %)
Computation of global information integrals ...... 0.667 ( 1.0793 %)
Writing of output data ........................... 0.540 ( 0.8728 %)
Model 2D kernel .................................. 16.932 (27.3840 %)
2D/3D coupling, vertical metrics ................. 0.713 ( 1.1530 %)
Omega vertical velocity .......................... 0.470 ( 0.7604 %)
Equation of state for seawater ................... 1.233 ( 1.9934 %)
GLS vertical mixing parameterization ............. 21.703 (35.0996 %)
3D equations right-side terms .................... 3.312 ( 5.3573 %)
3D equations predictor step ...................... 5.842 ( 9.4475 %)
Pressure gradient ................................ 2.191 ( 3.5439 %)
Corrector time-step for 3D momentum .............. 2.414 ( 3.9036 %)
Corrector time-step for tracers .................. 3.022 ( 4.8883 %)
Total: 60.625 98.0494
All percentages are with respect to total time = 61.831
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Sunday - January 24, 2016 - 11:55:33 AM
Re: Early blowing of model simulation
This is my stock response when I don't immediately see anything in your output: https://www.myroms.org/wiki/Frequently_ ... _in_diag.F
smchen
#3 Unread post by smchen »
For my case, the first option to be tuned is the time step size. But your size is small enough (60s) and, considering your timesteps, reducing time step size is costly in computation.
Two suggestions you can try. If you have very shallow water depth at some places, try turning on WET_DRY. Then, if you find instability pattern in the velocity or scalar fields, try adding horizontal mixing (UV_VIS2 or TS_DIF2 or both). Instability pattern looks like regular, non-natural texture in the horizontal plane view. Horizontal mixing can damp these instabilities, but the sensitivity test of the mixing coefficients should be carried out to make sure the horizontal mixing not removing too much fine scale features.
--Shi-Ming
susonic
#4 Unread post by susonic »
My suggestions are
1.Try different horizontal advection scheme (say U3 instead of C4)
2.Try quadratic drag instead of linear drag(UV_QDRAG instead of UV_LDRAG)
3.Try different vertical turbulent scheme(say LMD or MY2.5 instead of GLS)
-JH
Joonho Lee
#5 Unread post by kate »
You probably do need more lateral smoothing, as provided by the U3 advection and/or the UV_VIS2. However, the first thing you should learn to do is look at the restart file to see what the fields are looking like. I use ncview to get a quick and dirty look at things.
