NEMURO reports wrong parameter values
jpm
#1 Unread post by jpm »
There is a bug in the NEMURO code that causes 3 of the parameters to be reported incorrectly. These parameters get read in correctly but are written to the log file incorrectly. So this is a relatively minor bug, yet it can be quite confusing to the user.
The incorrect lines in "ROMS/Nonlinear/Biology/nemuro_inp.h" (with line numbers):
725:            WRITE (out,80) AlphaZS(ng), 'AlphaZL',                      &
748:            WRITE (out,70) VP2N0(ng), 'VO2S0',                          &
759:            WRITE (out,80) KP2N(ng), 'KD2N',                            &
Jann Paul Mattern, Ocean Sciences Department, UCSC
Re: NEMURO reports wrong parameter values
Good catch, thanks for reporting! You can also enter these into the ROMS Trac system if you like.
