problem with mpirun
cwinant
problem with mpirun
#1 Unread post by cwinant »
After moving my Roms files to a different disk, I am geeting the following message at eexecution time:
cdw@Meursault:/HOME/cdw/Roms/Projects/t24si$ mpirun -np 8 ./oceanM<tidebasinforcing.in
[proxy:0:0@Meursault] HYD_pmcd_pmip_control_cmd_cb (pm/pmiserv/pmip_cb.c:938): process reading stdin too slowly; can't keep up
[proxy:0:0@Meursault] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status
[proxy:0:0@Meursault] main (pm/pmiserv/pmip.c:206): demux engine error waiting for event
[mpiexec@Meursault] control_cb (pm/pmiserv/pmiserv_cb.c:200): assert (!closed) failed
[mpiexec@Meursault] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status
[mpiexec@Meursault] HYD_pmci_wait_for_completion (pm/pmiserv/pmiserv_pmci.c:198): error waiting for event
[mpiexec@Meursault] main (ui/mpich/mpiexec.c:336): process manager error waiting for completion
Re: problem with mpirun
Do you have a computer expert you can ask? These are system errors, not ROMS errors. Can you go back to the prior disk?
cwinant
#3 Unread post by cwinant »
I guess these are mpi errors, although this thread claims they are user application errors.
jivica
#4 Unread post by jivica »
not sure if you made typo but when running with MPI you do not use "<" to feed in .in file
this is wrong: mpirun -np 8 ./oceanM<tidebasinforcing.in
and should be: mpirun -np 8 ./oceanM tidebasinforcing.in > log &
Cheers
I.
cwinant
#5 Unread post by cwinant »
That was exactly the problem I copied the syntax straight over from my serial runs.... Yhanks so much
