Blowing up problem
Blowing up problem
My model is blowing and I don't know why. I tried to change the time step but the only thing it does is to delay the blowing up.
I need help on this one
517 0 08:37:00 7.672425E-03 5.298350E+02 5.298427E+02 1.803663E+12
(071,101,01) 2.688424E-02 1.100356E-02 3.424691E+00 1.221882E+00
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Elapsed CPU time (seconds):
Thread # 0 CPU: 307.121
Thread # 2 CPU: 307.120
Thread # 1 CPU: 307.121
Total: 921.362
Nonlinear model elapsed time profile, Grid: 01
Allocation and array initialization .............. 1.369 ( 0.1486 %)
Ocean state initialization ....................... 0.098 ( 0.0106 %)
Reading of input data ............................ 0.131 ( 0.0142 %)
Processing of input data ......................... 7.868 ( 0.8540 %)
Computation of vertical boundary conditions ...... 0.437 ( 0.0474 %)
Computation of global information integrals ...... 11.426 ( 1.2401 %)
Writing of output data ........................... 8.178 ( 0.8876 %)
Model 2D kernel .................................. 292.704 (31.7686 %)
Tidal forcing .................................... 58.418 ( 6.3404 %)
2D/3D coupling, vertical metrics ................. 10.977 ( 1.1914 %)
Omega vertical velocity .......................... 10.351 ( 1.1235 %)
Equation of state for seawater ................... 14.234 ( 1.5449 %)
GLS vertical mixing parameterization ............. 259.034 (28.1143 %)
3D equations right-side terms .................... 1.966 ( 0.2134 %)
3D equations predictor step ...................... 54.138 ( 5.8759 %)
Pressure gradient ................................ 24.947 ( 2.7076 %)
Corrector time-step for 3D momentum .............. 32.397 ( 3.5162 %)
Corrector time-step for tracers .................. 35.871 ( 3.8933 %)
Total: 824.544 89.4919
All percentages are with respect to total time = 921.362
number of time records written in HISTORY file = 00000035
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_pair.h
ROMS/TOMS: DONE... Tuesday - November 3, 2015 - 4:42:37 PM
Total: 921.362
Re: Blowing up problem
This made it into the FAQ, where I wrote:
ROMS will check for extreme values of velocity and density at run time, including looking for NaN and Inf. If found, it will save a record to the restart file and die. If this happens early in the run, you might just try a shorter timestep. If it happens after many days/years of model time, you need to dig more deeply. Find out which field went bad and where in the domain it happened. The restart record can be viewed to look for this trouble. I've had runs go bad at the bottom with a bottom stress instability, at the top with a surface forcing problem, at the boundary with boundary condition issues. I've also had it go bad in the middle of the water column in no place special due to some other instability - it goes from fine to terrible in just a few timesteps. This last can often be run past with a shorter timestep, while the other problems call for more thoughtful responses.
Hello
I'm having the same problem the model blows up at start, i'm using this timing
NTIMES == 349020
DT == 120
NDTFAST == 20
NRST == 3600
NSTA == 60
NFLT == 30
NINFO == 60
NHIS == 720
NAVG == 3600
NDIA == 720
and get the same as mmichelet
720 1 00:00:00 2.197459E-08 1.847180E+04 1.847180E+04 3.649350E+15
(135,720,24) 0.000000E+00 1.688193E-03 0.000000E+00 4.603431E-02
DEF_HIS - creating history file, Grid 01: out/Leo_his.nc
DEF_AVG - creating average file, Grid 01: out/Leo_avg.nc
DEF_DIAGS - creating diagnostics file, Grid 01: out/Leo_dia.nc
DEF_STATION - creating stations file, Grid 01: out/Leo_sta.nc
DEF_FLOATS - creating floats file, Grid 01: out/Leo_flt.nc
780 1 02:00:00 NaN NaN NaN NaN
(140,180,01) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001
Shall i try a shorter DT & NDTFAST?
Thanks in advance
NTIMES == 349020
DT == 120
NDTFAST == 20
NRST == 3600
NSTA == 60
NFLT == 30
NINFO == 60
NHIS == 720
NAVG == 3600
NDIA == 720
Thanks in advance
Outpl67.txt
- (41.7 KiB) Downloaded 642 times
leo.in
- (117.69 KiB) Downloaded 608 times
For you I would change NINFO to 1 and try again. Perhaps you'll see what's going bad before it gets all the way to NaN. Still, what I said above goes for you too.
I still have some trouble with that, the thing is the running is fine, the results are good, and the velocity suddenly blow up
Any idea why it does that?
*not an expert response*
have you tried compiling with lower optimization? i've experienced seemingly random blowups with some combinations of fortran&mpi using -O3 while -O2 ran just fine.
Hello j.throutlocust
Could you please remind me, where in the compilation procces the optimization -O3, -O2 is handle?
I'll try that
Any way I attach here my *.txt run with the NINFO == 1
Any help will be welcome
I'll try that
Outpl67_120s.txt
- (42.16 KiB) Downloaded 784 times
I didn't realize it was blowing up on timestep 4. That's a candidate for using a shorter timestep, especially considering this:
The compilation flags are set in one of the files in the Compilers directory. For me, it's one of Linux-gfortran.mk, Linux-pgi.mk or Linux-ifort.mk, depending on which compiler I use. Do you know which one you are using?
Maximum barotropic Courant Number = 7.51904786E-01
Hello Kate
I´m using linux-gfortran
Thanks for your replay, how small or big the Courant number shall be?
try checking out discussion archives, eg. viewtopic.php?f=14&t=3203Thanks for your replay, how small or big the Courant number shall be?
also
i've never used wet/dry or tides. i'm failure sure that depths and lateral spacing equal to zero are problematicMinimum X-grid spacing, DXmin = 0.00000000E+00 km
Maximum X-grid spacing, DXmax = 2.50567216E+00 km
Minimum Y-grid spacing, DYmin = 0.00000000E+00 km
Maximum Y-grid spacing, DYmax = 2.64336073E+00 km
Minimum Z-grid spacing, DZmin = 0.00000000E+00 m
Maximum Z-grid spacing, DZmax = 5.83204037E+02 m
Hello to All
I'm having problems running the model, it blows up at the very start, as says inhere before I have change the DT=120 & NDTFAST=20 to DT=90 & NDTFAST=15 and get the same.
For DT=120 & NDTFAST=20, Cw seems to be the problem on the top (surface)
0 0 00:00:00 7.629983E-04 1.709507E+04 1.709507E+04 1.829035E+15
(024,496,24) 1.495936E-02 1.956801E-02 0.000000E+00 5.645270E-01
1 0 00:02:00 7.660043E-04 1.709522E+04 1.709522E+04 1.829017E+15
(190,147,02) 1.004694E-02 4.771787E-03 8.541715E-02 5.603352E-01
2 0 00:04:00 8.229286E-04 1.709520E+04 1.709520E+04 1.829014E+15
(249,001,24) 8.591022E-04 2.043021E-02 5.998961E-01 7.098817E-01
3 0 00:06:00 1.128838E-03 1.709518E+04 1.709519E+04 1.829010E+15
(249,002,24) 4.047536E-03 1.839679E-02 6.097147E-01 1.268815E+00
4 0 00:08:00 1.430059E-03 1.709515E+04 1.709515E+04 1.829006E+15
(249,003,24) 8.117144E-03 1.679275E-02 8.162755E-01 1.704026E+00
5 0 00:10:00 2.073490E-03 1.709511E+04 1.709511E+04 1.829002E+15
(249,004,24) 8.083570E-03 1.482645E-02 1.148147E+00 2.648130E+00
6 0 00:12:00 3.054326E-03 1.709507E+04 1.709507E+04 1.828998E+15
(145,487,24) 2.971580E-02 8.389082E-03 1.578579E+00 3.648552E+00
7 0 00:14:00 4.518798E-03 1.709502E+04 1.709503E+04 1.828993E+15
(202,282,24) 1.536393E-02 4.071418E-03 1.639278E+00 4.859915E+00
8 0 00:16:00 6.838625E-03 1.709498E+04 1.709499E+04 1.828989E+15
(144,488,24) 4.343268E-02 1.757173E-02 1.848257E+00 6.189621E+00
9 0 00:18:00 1.071863E-02 1.709494E+04 1.709495E+04 1.828985E+15
(145,487,24) 3.864271E-02 1.181540E-02 2.988795E+00 7.086973E+00
10 0 00:20:00 1.765047E-02 1.709490E+04 1.709492E+04 1.828981E+15
(036,495,05) 2.379341E-01 5.427742E-02 4.292391E+00 1.496650E+01
11 0 00:22:00 7.740497E-02 1.713411E+04 1.713419E+04 1.828976E+15
(036,495,06) 8.083927E-01 5.499493E-01 7.429847E+00 8.646381E+01
WRT_RST - wrote re-start fields (Index=2,2) into time record = 0000001
As well as the DT=90 & NDTFAST=15
(024,496,24) 1.121952E-02 1.467601E-02 0.000000E+00 5.645270E-01
1 0 00:01:30 7.609989E-04 1.709522E+04 1.709522E+04 1.829018E+15
(190,147,02) 7.165161E-03 3.594490E-03 6.407607E-02 5.616428E-01
2 0 00:03:00 7.868065E-04 1.709520E+04 1.709520E+04 1.829015E+15
(249,001,24) 2.299166E-04 1.442612E-02 5.490264E-01 5.591896E-01
3 0 00:04:30 9.532306E-04 1.709520E+04 1.709520E+04 1.829013E+15
(249,002,24) 1.940113E-03 1.084835E-02 2.870952E-01 9.368728E-01
4 0 00:06:00 1.114391E-03 1.709518E+04 1.709519E+04 1.829010E+15
(249,002,24) 3.150762E-03 1.387032E-02 5.173575E-01 1.214382E+00
5 0 00:07:30 1.449336E-03 1.709516E+04 1.709516E+04 1.829007E+15
(249,003,24) 6.693739E-03 1.174276E-02 6.067252E-01 1.874076E+00
6 0 00:09:00 1.931803E-03 1.709513E+04 1.709513E+04 1.829004E+15
(249,003,24) 3.595443E-03 1.324369E-02 8.304611E-01 2.528241E+00
7 0 00:10:30 2.567905E-03 1.709510E+04 1.709510E+04 1.829001E+15
(145,487,24) 1.758485E-02 6.285132E-03 9.800466E-01 3.206420E+00
8 0 00:12:00 3.397174E-03 1.709506E+04 1.709507E+04 1.828998E+15
(145,487,24) 2.181912E-02 7.839011E-03 1.229455E+00 3.949442E+00
9 0 00:13:30 4.486488E-03 1.709503E+04 1.709503E+04 1.828994E+15
(202,282,24) 1.407477E-02 3.106545E-03 1.230775E+00 4.792613E+00
10 0 00:15:00 5.928210E-03 1.709500E+04 1.709500E+04 1.828991E+15
(144,488,24) 2.725591E-02 1.147215E-02 1.401741E+00 5.661016E+00
11 0 00:16:30 7.888896E-03 1.709497E+04 1.709497E+04 1.828988E+15
(145,487,24) 1.046769E-02 2.907613E-03 1.650414E+00 6.454720E+00
12 0 00:18:00 1.052264E-02 1.709494E+04 1.709495E+04 1.828985E+15
(145,487,24) 2.815872E-02 4.701853E-03 2.600716E+00 7.127135E+00
13 0 00:19:30 1.390535E-02 1.709490E+04 1.709492E+04 1.828982E+15
(036,495,07) 2.175534E-01 2.647289E-02 2.881235E+00 7.665643E+00
14 0 00:21:00 1.933889E-02 1.709487E+04 1.709489E+04 1.828979E+15
(033,492,08) 2.404581E-01 3.163855E-02 4.130301E+00 2.457876E+01
I'm using now the daily HYCOM data for the boundaries and CCMP (6 hr) for wind forcing, my boundary structure is like this:
! 1 2 3 4
LBC(isFsur) == Che Che Clo Che ! free-surface
LBC(isUbar) == Shc Shc Clo Shc ! 2D U-momentum
LBC(isVbar) == Shc Shc Clo Shc ! 2D V-momentum
LBC(isUvel) == RadNud RadNud Clo RadNud ! 3D U-momentum
LBC(isVvel) == RadNud RadNud Clo RadNud ! 3D V-momentum
LBC(isMtke) == Gra Gra Clo Gra ! mixing TKE
LBC(isTvar) == RadNud RadNud Clo RadNud \ ! temperature
RadNud RadNud Clo RadNud ! salinity
and also change
! internally, [1:Ngrids].
TNUDG == 2*360.0d0 ! days
ZNUDG == 360.0d0 ! days
M2NUDG == 360.0d0 ! days
M3NUDG == 360.0d0 ! days
OBCFAC == 120.0d0 ! nondimensional
As suggested by Kate in
viewtopic.php?f=23&t=3975&p=16072&hilit ... yer#p16072
Thanks in advance to All
Have a nice day
! 1 2 3 4
and also change
Have a nice day
You need to look at the fields in that restart file that it so nicely saved for you. We don't have enough information from the text output to know what's really going on. The model doesn't report whether it's a density problem or a velocity problem - you need to figure that out. Is it trouble at the surface or a lateral boundary or something else?
