Running problem
nmichelet
Running problem
#1 Unread post by nmichelet »
Hello everyone,
I am currently trying to run a model with only tidal forcing.
The problem is that my results for the free surface or u and v are equal to zero everywhere.
Can you help me please, here is my .in file and my .h file
.in file
! Application title.
TITLE = Iroise Sea Tidal Configuration
! C-preprocessing Flag.
MyAppCPP = IROISE
VARNAME = /home/nicolas/roms/trunk/ROMS/External/varinfo.dat
! Number of nested grids.
Ngrids = 1
NestLayers = 1
GridsInLayer = 1
! these parameters correctly.
Lm == 98 ! Number of I-direction INTERIOR RHO-points
Mm == 98 ! Number of J-direction INTERIOR RHO-points
NtileI == 1 ! I-direction partition
NtileJ == 1 ! J-direction partition
! for each boundary segment per nested grid for each state variable.
! Each tracer variable requires [1:4,1:NAT+NPT,Ngrids] values. Otherwise,
! [1:4,1:Ngrids] values are expected for other variables. The boundary
! order is: 1=west, 2=south, 3=east, and 4=north. That is, anticlockwise
! starting at the western boundary.
! The keyword is case insensitive and usually has three characters. However,
! it is possible to have compound keywords, if applicable. For example, the
! keyword "RadNud" implies radiation boundary condition with nudging. This
! combination is usually used in active/passive radiation conditions.
! Cha Chapman_implicit (free-surface)
! Che Chapman_explicit (free-surface)
! Cla Clamped
! Clo Closed
! Fla Flather (2D momentum) _____N_____ j=Mm
! Gra Gradient | 4 |
! Nes Nested (refinement) | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics (2D momentum) 2 j=1
! Shc Shchepetkin (2D momentum) i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
! LBC(isFsur) == Per Clo Per Clo ! free-surface
! LBC(isUbar) == Per Clo Per Clo ! 2D U-momentum
! LBC(isVbar) == Per Clo Per Clo ! 2D V-momentum
! LBC(isUvel) == Per Clo Per Clo ! 3D U-momentum
! LBC(isVvel) == Per Clo Per Clo ! 3D V-momentum
! LBC(isMtke) == Per Clo Per Clo ! mixing TKE
! LBC(isTvar) == Per Clo Per Clo \ ! temperature
! Per Clo Per Clo ! salinity
! conditions keywords.
!ad_LBC(isFsur) == Per Clo Per Clo ! free-surface
!ad_LBC(isUbar) == Per Clo Per Clo ! 2D U-momentum
!ad_LBC(isVbar) == Per Clo Per Clo ! 2D U-momentum
!ad_LBC(isUvel) == Per Clo Per Clo ! 3D U-momentum
!ad_LBC(isVvel) == Per Clo Per Clo ! 3D V-momentum
!ad_LBC(isMtke) == Per Clo Per Clo ! mixing TKE
!ad_LBC(isTvar) == Per Clo Per Clo \ ! temperature
! conservation, except if tidal forcing is enabled. [1:Ngrids].
! VolCons(west) == F ! western boundary
! VolCons(east) == F ! eastern boundary
! VolCons(south) == F ! southern boundary
! VolCons(north) == F ! northern boundary
!ad_VolCons(west) == F ! western boundary
!ad_VolCons(east) == F ! eastern boundary
!ad_VolCons(south) == F ! southern boundary
!ad_VolCons(north) == F ! northern boundary
! Time-Stepping parameters.
NTIMES == 12
DT == 10.0d0
NDTFAST == 100
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
! Input/Output parameters.
NRREC == 0
LcycleRST == T
NRST == 288
NSTA == 1
NFLT == 1
NINFO == 1
LDEFOUT == T
NHIS == 72
NDEFHIS == 0
NTSAVG == 1
NAVG == 72
NDEFAVG == 0
NTSDIA == 1
NDIA == 72
NDEFDIA == 0
LcycleTLM == F
NTLM == 72
NDEFTLM == 0
LcycleADJ == F
NADJ == 72
NDEFADJ == 0
NSFF == 72
NOBC == 72
! GST output and check pointing restart parameters.
LmultiGST = F ! one eigenvector per file
Ritz_tol = 1.0d-15
TNU2 == 0.0d0 0.0d0 ! m2/s
TNU4 == 2*0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
VISC2 == 5.0d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
! Logical switches (TRUE/FALSE) to increase/decrease horizontal viscosity
! and/or diffusivity in specific areas of the application domain (like
! sponge areas) for the desired application grid.
LuvSponge == F ! horizontal momentum
LtracerSponge == F F ! temperature, salinity, inert
AKT_BAK == 1.0d-6 1.0d-6 ! m2/s
AKV_BAK == 1.0d-5 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
GLS_P == 3.0d0 ! K-epsilon
GLS_M == 1.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_CMU0 == 0.5477d0
GLS_C1 == 1.44d0
GLS_C2 == 1.92d0
GLS_C3M == -0.4d0
GLS_C3P == 1.0d0
GLS_SIGK == 1.0d0
GLS_SIGP == 1.30d0
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.02d0 ! m
Zos == 0.02d0 ! m
BLK_ZQ == 10.0d0 ! air humidity
BLK_ZT == 10.0d0 ! air temperature
BLK_ZW == 10.0d0 ! winds
! Minimum depth for wetting and drying.
DCRIT == 0.10d0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
! Set vertical, terrain-following coordinates transformation equation and
! stretching function (see below for details), [1:Ngrids].
Vtransform == 2 ! transformation equation
Vstretching == 1 ! stretching function
! Vertical S-coordinates parameters (see below for details), [1:Ngrids].
THETA_S == 3.0d0 ! surface stretching parameter
THETA_B == 0.0d0 ! bottom stretching parameter
TCLINE == 0.0d0 ! critical depth (m)
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
! NetCDF units attribute.
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 0.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 2*0.0d0 ! days
ZNUDG == 0.0d0 ! days
M2NUDG == 0.0d0 ! days
M3NUDG == 0.0d0 ! days
OBCFAC == 0.0d0 ! nondimensional
R0 == 1027.0d0 ! kg/m3
T0 == 14.0d0 ! Celsius
S0 == 35.0d0 ! nondimensional
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 0.0d0 ! nondimensional
GAMMA2 == 1.0d0
! Logical switches (TRUE/FALSE) to activate horizontal momentum transport
! point Sources/Sinks (like river runoff transport) and mass point
! Sources/Sinks (like volume vertical influx), [1:Ngrids].
LuvSrc == F ! horizontal momentum transport
LtracerSrc == F F ! temperature, salinity, inert
! Logical switches (TRUE/FALSE) to read and process climatology fields.
! See glossary below for details.
LsshCLM == F ! sea-surface height
Lm2CLM == F ! 2D momentum
Lm3CLM == F ! 3D momentum
! Logical switches (TRUE/FALSE) to nudge the desired climatology field(s).
! If not analytical climatology fields, users need to turn ON the logical
! switches above to process the fields from the climatology NetCDF file
! that are needed for nudging. See glossary below for details.
LnudgeM2CLM == F ! 2D momentum
DstrS == 0.0d0 ! starting day
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 1 ! ending level
Lstate(isFsur) == F ! free-surface
Lstate(isTvar) == F F ! NT tracers
! Logical switches (TRUE/FALSE) to specify the state variables for
! which Forcing Singular Vectors or Stochastic Optimals is required.
Fstate(isFsur) == F ! free-surface
Fstate(isUstr) == T ! surface U-stress
Fstate(isVstr) == T ! surface V-stress
! Stochastic Optimals time decorrelation scale (days) assumed for
! red noise processes.
SO_decay == 2.0d0 ! days
! Stochastic Optimals surface forcing standard deviation for
! dimensionalization.
SO_sdev(isFsur) == 1.0d0 ! free-surface
SO_sdev(isUstr) == 1.0d0 ! surface U-stress
SO_sdev(isVstr) == 1.0d0 ! surface V-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 ! NT surface tracers flux
! HISTORY output file.
Hout(idUvel) == F ! u 3D U-velocity
Hout(idVvel) == F ! v 3D V-velocity
Hout(idWvel) == F ! w 3D W-velocity
Hout(idOvel) == F ! omega omega vertical velocity
Hout(idUbar) == F ! ubar 2D U-velocity
Hout(idVbar) == F ! vbar 2D V-velocity
Hout(idBath) == F ! bath time-dependent bathymetry
Hout(idTvar) == F F ! temp, salt temperature and salinity
! tracers other than biological and sediment tracers. An inert passive tracer
! is one that it is only advected and diffused. Other processes are ignored.
! These tracers include, for example, dyes, pollutants, oil spills, etc.
! NPT values are expected. However, these switches can be activated using
! compact parameter specification.
Hout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of exposed sediment
! layer properties into HISTORY output file. Currently, MBOTP properties
! are expected for the bottom boundary layer and/or sediment models:
! idBott( 1=isd50) grain_diameter mean grain diameter
! idBott( 2=idens) grain_density mean grain density
! idBott( 3=iwsed) settling_vel mean settling velocity
! idBott( 4=itauc) erosion_stress critical erosion stress
! idBott( 5=irlen) ripple_length ripple length
! idBott( 6=irhgt) ripple_height ripple height
! idBott( 7=ibwav) bed_wave_amp wave excursion amplitude
! idBott( 8=izdef) Zo_def default bottom roughness
! idBott( 9=izapp) Zo_app apparent bottom roughness
! idBott(10=izNik) Zo_Nik Nikuradse bottom roughness
! idBott(11=izbio) Zo_bio biological bottom roughness
! idBott(12=izbfm) Zo_bedform bed form bottom roughness
! idBott(13=izbld) Zo_bedload bed load bottom roughness
! idBott(14=izwbl) Zo_wbl wave bottom roughness
! idBott(15=iactv) active_layer_thickness active layer thickness
! idBott(16=ishgt) saltation saltation height
! 1 1 1 1 1 1 1
! 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
Hout(idBott) == F F F F F F F F F F F F F F F F
! Logical switches (TRUE/FALSE) to activate writing of time-averaged
! fields into AVERAGE output file.
Aout(idUvel) == F ! u 3D U-velocity
Aout(idVvel) == F ! v 3D V-velocity
Aout(idWvel) == F ! w 3D W-velocity
Aout(idOvel) == F ! omega omega vertical velocity
Aout(idUbar) == F ! ubar 2D U-velocity
Aout(idVbar) == F ! vbar 2D V-velocity
Aout(idTvar) == F F ! temp, salt temperature and salinity
Aout(idu3dD) == T ! u_detided detided 3D U-velocity
Aout(idv3dD) == T ! v_detided detided 3D V-velocity
Aout(idu2dD) == T ! ubar_detided detided 2D U-velocity
Aout(idv2dD) == T ! vbar_detided detided 2D V-velocity
Aout(idFsuD) == T ! zeta_detided detided free-surface
Aout(idTTav) == F F ! temp_2, ... quadratic <t*t> tracer terms
Aout(idUTav) == F F ! u_temp, ... quadratic <u*t> tracer terms
Aout(idVTav) == F F ! v_temp, ... quadratic <v*t> tracer terms
Aout(iHUTav) == F F ! Huon_temp, ... tracer volume flux, <Huon*t>
Aout(iHVTav) == F F ! Hvom_temp, ... tracer volume flux, <Hvom*t>
! tracers other than biological and sediment tracers into the AVERAGE file.
Aout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of time-averaged,
! 2D momentum (ubar,vbar) diagnostic terms into DIAGNOSTIC output file.
Dout(M2rate) == T ! ubar_accel, ... acceleration
! 3D momentum (u,v) diagnostic terms into DIAGNOSTIC output file.
Dout(M3rate) == T ! u_accel, ... acceleration
! active (temperature and salinity) and passive (inert) tracer diagnostic
! terms into DIAGNOSTIC output file: [1:NAT+NPT,Ngrids].
Dout(iTrate) == T T ! temp_rate, ... time rate of change
NUSER = 0
USER = 0.d0
! NetCDF-4/HDF5 compression parameters for output files.
NC_SHUFFLE = 1 ! if non-zero, turn on shuffle filter
GRDNAME == grid.nc
ININAME == roms_ini.nc
ITLNAME == ocean_itl.nc
IRPNAME == ocean_irp.nc
IADNAME == ocean_iad.nc
FWDNAME == ocean_fwd.nc
ADSNAME == ocean_ads.nc
! Nesting grids connectivity data: contact points information. This
! NetCDF file is special and complex. It is currently generated using
! the script "matlab/grid/contact.m" from the Matlab repository.
NGCNAME = ocean_ngc.nc
! Input lateral boundary conditions and climatology file names. The
! USER has the option to split input data time records into several
! NetCDF files (see prologue instructions above). If so, use a single
! line per entry with a vertical bar (|) symbol after each entry,
! except the last one.
BRYNAME == roms_bry.nc
CLMNAME == roms_clm.nc
! Input climatology nudging coefficients file name.
NUDNAME == ocean_nud.nc
! Input Sources/Sinks forcing (like river runoff) file name.
SSFNAME == ocean_rivers.nc
! Input forcing NetCDF file name(s). The USER has the option to enter
! several file names for each nested grid. For example, the USER may
! have different files for wind products, heat fluxes, tides, etc.
! The model will scan the file list and will read the needed data from
! the first file in the list containing the forcing field. Therefore,
! the order of the file names is very important. If using multiple forcing
! files per grid, first enter all the file names for grid 1, then grid 2,
! and so on. It is also possible to split input data time records into
! several NetCDF files (see prologue instructions above). Use a single line
! per entry with a continuation (\) or vertical bar (|) symbol after each
! entry, except the last one.
NFFILES == 1 ! number of unique forcing files
FRCNAME == roms_frc.nc ! forcing file 1, grid 1
GSTNAME == ocean_gst.nc
RSTNAME == ocean_rst.nc
HISNAME == ocean_his.nc
TLMNAME == ocean_tlm.nc
TLFNAME == ocean_tlf.nc
ADJNAME == ocean_adj.nc
AVGNAME == ocean_avg.nc
DIANAME == ocean_dia.nc
STANAME == ocean_sta.nc
FLTNAME == ocean_flt.nc
! Input ASCII parameter filenames.
APARNAM = ROMS/External/s4dvar.in
BPARNAM = ROMS/External/bio_Fennel.in
.h file
** svn $Id: latte_c.h 342 2007-06-06 18:50:48Z zhang $
** Copyright (c) 2002-2007 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Lagrangian Transport and Transformation Experiment
** coarse grid resolution.
** Application flag: MANCHE
** Input script: ocean_manche.in
#define NLM_DRIVER
#undef DIAGNOSTICS_TS
#undef DIAGNOSTICS_UV
#undef UV_LOGDRAG
#define WET_DRY
#define DIFF_3DCOEF
#define VISC_3DCOEF
#undef TS_SMAGORINSKY use to turn ON or OFF Smagorinsky-like diffusion
#define UV_SMAGORINSKY
#define MIX_GEO_TS
#define TS_MPDATA
#undef TS_U3HADVECTION
#undef TS_SVADVECTION
#undef SALINITY
#undef AVERAGES
#undef STATIONS
#undef SPLINES
#define OUT_DOUBLE
#undef UV_PSOURCE
#undef TS_PSOURCE
#define GLS_MIXING
#ifdef GLS_MIXING
# undef CANUTO_A
#define ANA_INITIAL
#undef BULK_FLUXES
#undef ANA_WINDS
#undef ANA_TAIR
#undef ANA_PAIR
#define ANA_SRFLUX
#undef ANA_HUMIDITY
#define LONGWAVE
#define ANA_RAIN
#define ANA_CLOUD
/* Open boundary condition settings */
#define NORTH_FSCLAMPED
#define NORTH_M2REDUCED
#define NORTH_M3GRADIENT
#define NORTH_TGRADIENT
#define WEST_FSCLAMPED
#define WEST_M2REDUCED
#define WEST_M3GRADIENT
#define WEST_TGRADIENT
#define EAST_WALL
#define SOUTH_WALL
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
#undef M3CLM_NUDGING
#define ANA_FSOBC
#undef ANA_M2OBC
/* define UV_TIDES to specify boundary tidal currents from data e.g. ADCIRC */
/* undef UV_TIDES to compute tidal currents using reduced physics */
#define SSH_TIDES /* read tidal SSH from file */
#undef UV_TIDES /* read tidal U and V from file */
#ifdef SSH_TIDES
# define ADD_FSOBC
# define FSOBC_REDUCED
#ifdef UV_TIDES
# undef FSOBC_REDUCED /* boundary pg is calculated using bounday zeta */
# define ADD_M2OBC
#define ANA_BPFLUX /* needed when sediment and bulk fluxes are on */
#define ANA_SPFLUX /* needed when sediment and bulk fluxes are on */
#define UV_LDRAG
Re: Running problem
What the heck version is this? You've got cpp boundary options from 2007 and a newer ocean.in with the LBC stuff all commented out. You need to have it all be from one consistent version, ideally a new one so we have a clue.
nmichelet
Re: Running problem
#3 Unread post by nmichelet »
I am using the 3.7 version of ROMS.
I change what you said but it still gives me the same results, here is the .h file
Can you tell me if something is wrong?
** Application flag: IROISE
** Input script: roms.in
#define NLM_DRIVER
#undef UV_LOGDRAG
#define WET_DRY
#define DIFF_3DCOEF
#define VISC_3DCOEF
#define MIX_GEO_TS
#define TS_MPDATA
#undef SALINITY
#undef AVERAGES
#undef STATIONS
#undef SPLINES
#define OUT_DOUBLE
#undef UV_PSOURCE
#undef TS_PSOURCE
#define GLS_MIXING
#ifdef GLS_MIXING
# undef CANUTO_A
#define ANA_INITIAL
#undef ANA_WINDS
#undef ANA_TAIR
#undef ANA_PAIR
#define ANA_SRFLUX
#undef ANA_HUMIDITY
#define LONGWAVE
#define ANA_RAIN
#define ANA_CLOUD
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
#define ANA_FSOBC
#undef ANA_M2OBC
#define ADD_FSOBC
#define ADD_M2OBC
#define UV_TIDES /* read tidal U and V from file */
#ifdef SSH_TIDES
# define ADD_FSOBC
#ifdef UV_TIDES
# define ADD_M2OBC
#define UV_LDRAG
mjfconan
Re: Running problem
#4 Unread post by mjfconan »
I met a similar problem. Maybe it can give you a small hint or nothing :o .
My fault was giving a wrong time unit in boundary file, says the 'units' attribute of "zeta_time". viewtopic.php?f=19&t=3450&hilit=time+unit
Re: Running problem
#5 Unread post by kate »
These will all be ignored in ROMS 2015, but shouldn't hurt anything:
#define EAST_WALL
#define SOUTH_WALL
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
You do need to set the LBC options in ocean.in.
You seem to have consistent tides options, so I don't know. I tend to solve these issues with a debugger - that's what they're for.
nmichelet
Re: Running problem
#6 Unread post by nmichelet »
Thanks for your reply, I solved the problem.
It was a problem with the boundary condition and the cppkeys I used
Thanks for your help
