error about'couldnt find input file'
Discussion about tangent linear and adjoint models, variational data assimilation, and other related issues.
WY0116
#1 Unread post by WY0116 »
hi everyone,
I am a new leaner of Roms.I run the oceanM after,and I got the problem as flow:
Output Restart File: ./SCS_results/SCS_rst.nc
Prefix for History Files: ./SCS_results/SCS_his
Output Averages File: ./SCS_results/SCS_avg.nc
Input Grid File: ./SCS_forcing/SCS_BIG-grd.nc
Input Nonlinear Initial File: ./SCS_forcing/SCS_TIDE28-init.nc
READ_PHYPAR - could not find input file: ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
Elapsed CPU time (seconds):
ROMS/TOMS - I/O error ............... exit_flag: 4
ERROR: I/O related problem.
Job /public/lsf/7.0/linux2.6-glibc2.3-x86_64/bin/openmpi_wrapper ./oceanM ./ocean_SCS.in
anyone has ever got the same problem?
Any suggestions will be appreciated.
Re: error about'couldnt find input file'
The problem is in your ocean_SCS.in file. After listing the grid file, my job output lists the forcing files. What do you have for NFFILES? Did you keep the FRCNAME section? It's good to have NFFILES at least 1 and to have something for FRCNAME. There are times when ROMS wants a field from the forcing file even when you don't expect that and the error messages make more sense if you keep FRCNAME. Pointing to an existing file will trigger messages more like "can't file variable stflx in file myfile" (one hopes).
I hope you are trying to run the forward model before taking on the adjoint. Why is this message in the adjoint section?
WY0116
#3 Unread post by WY0116 »
kate wrote:The problem is in your ocean_SCS.in file. After listing the grid file, my job output lists the forcing files. What do you have for NFFILES? Did you keep the FRCNAME section? It's good to have NFFILES at least 1 and to have something for FRCNAME. There are times when ROMS wants a field from the forcing file even when you don't expect that and the error messages make more sense if you keep FRCNAME. Pointing to an existing file will trigger messages more like "can't file variable stflx in file myfile" (one hopes).
hi kate,
thanks for your reply.
I have
NFFILES == 1
FRCNAME == ./SCS_forcing/SCS_TIDE28-forc.nc
as NFFILES.
I tried to run the case by the old version(2008) of Roms,and it could run well. But the new version(2015) still doesn't work.Could you give me some more suggestions? The attchment is my ocean_SCS.in file.
Thanks again for your help.
ocean_SCS.in
(106.47 KiB) Downloaded 596 times
You have:
     FRCNAME == ./SCS_forcing/SCS_TIDE28-forc.nc                      ! forcing file 1, grid 1
Try getting rid of the comment after the filename.
Also, the date on your ocean.in file is 2013. You need to use a 2015 ocean.in with a 2015 ROMS. Your ocean.in has NBCFILES, which isn't in the trunk ROMS - are you using trunk ROMS?
WY0116
#5 Unread post by WY0116 »
kate wrote:You have:
Hi kate,
I deleted the comment '! forcing file 1, grid 1',and I I modified the newer ocean_SCS.in(the attachment).but it still doesn't work.
I got the code by 'svn checkout --username bruce https://www.myroms.org/svn/src/trunk src'. Is it a trunk version?
#6 Unread post by kate »
Yes, that is the trunk version of the code.
Are you still getting the same error? Do you have a file listed for each filename in an unmodified ocean.in or did you comment some out?
WY0116
#7 Unread post by WY0116 »
kate wrote:Yes, that is the trunk version of the code.
Yes,the error is still the same.I am sorry I forgot to attach my new ocean.in file.I cant find the file which listed the each filename in the ocean.in file. And I am puzzled that I could run the application upwelling well.
ocean_SCS.in
(117.5 KiB) Downloaded 563 times
WY0116
#8 Unread post by WY0116 »
Hi kate,
I use the 'svn update -r 700'just now.I guess the version has been downgraded to 2013.And it could run without error(I didnt modify the ocean.in file).I dont know the difference between the 2015 version and the old versions.While the 2015 version still has the error.
#9 Unread post by kate »
I think your problem is this combo:
  LtracerSrc == T T
!     SSFNAME == ocean_rivers.nc
You are saying that you want river sources for the tracers and yet you commented out the river filename.
WY0116
#10 Unread post by WY0116 »
kate wrote:I think your problem is this combo:
  LtracerSrc == T T
Hi kate,
I tried to change the LtracerSrc= F F and the errors occured as follow:
CHECKDEFS - cannot use obsolete option: SPLINES
See following trac ticket for details:
https://www.myroms.org/projects/src/ticket/681
please change header file accordingly.
Then my fellow shared his Rom3.7 to me. While with the same files(.in file and .h file),it could work. It makes me confused.
#11 Unread post by kate »
Oh, yeah, SPLINES. That changed pretty recently. It has become three options:
SPLINES_VVISC       use if splines reconstruction of vertical viscosity
SPLINES_VDIFF       use if splines reconstruction of vertical diffusion
RI_SPLINES          use if splines reconstruction for vertical sheer
