-.in file is the follow:
! Application title.
TITLE = Okhotsk Sea, 10 km resolution
! C-preprocessing Flag.
MyAppCPP = SAKHALIN3
VARNAME = ../roms3/ROMS/External/varinfo.dat
! Number of nested grids.
Ngrids = 1
! these parameters correctly.
Lm == 119 ! Number of I-direction INTERIOR RHO-points
Mm == 468 ! Number of J-direction INTERIOR RHO-points
N == 32 ! Number of vertical levels
NtileI == 6 ! I-direction partition
NtileJ == 16 ! J-direction partition
! for each boundary segment per nested grid for each state variable.
! Each tracer variable requires [1:4,1:NAT+NPT,Ngrids] values. Otherwise,
! [1:4,1:Ngrids] values are expected for other variables. The boundary
! order is: 1=west, 2=south, 3=east, and 4=north. That is, anticlockwise
! starting at the western boundary.
! The keyword is case insensitive and usually has three characters. However,
! it is possible to have compound keywords, if applicable. For example, the
! keyword "RadNud" implies radiation boundary condition with nudging. This
! combination is usually used in active/passive radiation conditions.
! Cha Chapman
! Cla Clamped
! Clo Closed
! Gra Gradient | 4 |
! Nes Nested | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics 2 j=1
! i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Cha Cha Cha Cha ! free-surface
LBC(isUbar) == Fla Fla Fla Fla ! 2D U-momentum
LBC(isVbar) == Fla Fla Fla Fla ! 2D V-momentum
LBC(isUvel) == Cla Cla Cla Cla ! 3D U-momentum
LBC(isVvel) == Cla Cla Cla Cla ! 3D V-momentum
LBC(isMtke) == Gra Gra Gra Gra ! mixing TKE
LBC(isTvar) == Cla Cla Cla Cla \ ! temperature
Cla Cla Cla Cla ! salinity
! conditions keywords.
ad_LBC(isFsur) == Cha Cha Cha Cha ! free-surface
ad_LBC(isUbar) == Fla Fla Fla Fla ! 2D U-momentum
ad_LBC(isVbar) == Fla Fla Fla Fla ! 2D U-momentum
ad_LBC(isUvel) == Gra Gra Gra Gra ! 3D U-momentum
ad_LBC(isVvel) == Gra Gra Gra Gra ! 3D V-momentum
ad_LBC(isMtke) == Gra Gra Gra Gra ! mixing TKE
ad_LBC(isTvar) == Gra Gra Gra Gra \ ! temperature
Gra Gra Gra Gra ! salinity
! conservation, except if tidal forcing enabled. [1:Ngrids].
VolCons(west) == T ! western boundary
VolCons(east) == T ! eastern boundary
VolCons(south) == T ! southern boundary
VolCons(north) == T ! northern boundary
ad_VolCons(west) == T ! western boundary
ad_VolCons(east) == T ! eastern boundary
ad_VolCons(south) == T ! southern boundary
ad_VolCons(north) == T ! northern boundary
! Time-Stepping parameters.
! NTIMES == 264960
! NTIMES == 259200
! NTIMES == 345600
! NTIMES == 89280
! NTIMES == 29760
! NTIMES == 57600
! NTIMES == 87360
! NTIMES == 116160
! NTIMES == 145920
! NTIMES == 174720
! NTIMES == 306720
! NTIMES == 217440
NTIMES == 2000
DT == 30.000d0
NDTFAST ==180
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
! Input/Output parameters.
NRREC == 0
LcycleRST == T
NRST == 100
NSTA == 1
NFLT == 40
NINFO == 1
LDEFOUT == T
NHIS == 100
NDEFHIS == 100
NTSAVG == 1
NAVG == 2880
NDEFAVG == 2880
NTSDIA == 1
NDIA == 432
NDEFDIA == 0
LcycleTLM == F
NTLM == 432
NDEFTLM == 0
LcycleADJ == F
NADJ == 432
NDEFADJ == 0
NSFF == 432
NOBC == 432
! GST output and check pointing restart parameters.
LmultiGST = F ! one eigenvector per file
Ritz_tol = 1.0d-15
TNU2 == 6.0d0 8.0d0 2.0d0 20.0d0 ! m2/s
TNU4 == 8.0d+7 10.0d+7 2.0d+7 2.0d+8 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
VISC2 == 200.0d0 25.0d0 5.0d0 ! m2/s
VISC4 == 15.0d+8 20.0d+7 4.0d+7 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
AKT_BAK == 10.0d-6 1.0d-6 ! m2/s
AKV_BAK == 10.0d-5 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 2000.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
GLS_P == 3.0d0 ! K-epsilon
GLS_M == 1.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_CMU0 == 0.5477d0
GLS_C1 == 1.44d0
GLS_C2 == 1.92d0
GLS_C3M == -0.4d0
GLS_C3P == 1.0d0
GLS_SIGK == 1.0d0
GLS_SIGP == 1.30d0
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.02d0 ! m
Zos == 0.02d0 ! m
BLK_ZQ == 10.0d0 ! air humidity
BLK_ZT == 10.0d0 ! air temperature
BLK_ZW == 10.0d0 ! winds
! Minimum depth for wetting and drying.
DCRIT == 0.10d0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
! Set vertical, terrain-following coordinates transformation equation and
! stretching function (see below for details), [1:Ngrids].
Vtransform == 1 ! transformation equation
Vstretching == 1 ! stretching function
! Vertical S-coordinates parameters (see below for details), [1:Ngrids].
THETA_S == 3.0d0 ! surface stretching parameter
THETA_B == 0.4d0 ! bottom stretching parameter
TCLINE == 10.0d0 ! critical depth (m)
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
! NetCDF units attribute.
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 20130101.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 60.0d0 50.0d0 ! days
ZNUDG == 60.0d0 ! days
M2NUDG == 60.0d0 ! days
M3NUDG == 60.0d0 ! days
OBCFAC == 0.0d0 ! nondimensional
R0 == 1027.0d0 ! kg/m3
T0 == 10.0d0 ! Celsius
S0 == 35.0d0 ! PSU
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 7.6d-4 ! 1/PSU
GAMMA2 == 1.0d0
! Logical switches (TRUE/FALSE) to specify which variables to process for
! tracers climatology: [1:NAT+NPT,Ngrids]. See glossary below for details.
LtracerCLM == T T ! temperature, salinity, inert
! Logical switches (TRUE/FALSE) to specify which variables to consider on
! tracers point Sources/Sinks (like river runoff): [1:NAT+NPT,Ngrids].
! See glossary below for details.
LtracerSrc == F F ! temperature, salinity, inert
DstrS == 0.0d0 ! starting day
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 1 ! ending level
Lstate(isFsur) == F ! free-surface
Lstate(isTvar) == F F ! NT tracers
! Logical switches (TRUE/FALSE) to specify the state variables for
! which Forcing Singular Vectors or Stochastic Optimals is required.
Fstate(isFsur) == F ! free-surface
Fstate(isUstr) == T ! surface U-stress
Fstate(isVstr) == T ! surface V-stress
! Stochastic Optimals time decorrelation scale (days) assumed for
! red noise processes.
SO_decay == 2.0d0 ! days
! Stochastic Optimals surface forcing standard deviation for
! dimensionalization.
SO_sdev(isFsur) == 1.0d0 ! free-surface
SO_sdev(isUstr) == 1.0d0 ! surface U-stress
SO_sdev(isVstr) == 1.0d0 ! surface V-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 ! NT surface tracers flux
! HISTORY output file.
Hout(idUvel) == T ! u 3D U-velocity
Hout(idWvel) == F ! w 3D W-velocity
Hout(idOvel) == F ! omega omega vertical velocity
! tracers other than biological and sediment tracers. An inert passive tracer
! is one that it is only advected and diffused. Other processes are ignored.
! These tracers include, for example, dyes, pollutants, oil spills, etc.
! NPT values are expected. However, these switches can be activated using
! compact parameter specification.
Hout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of exposed sediment
! layer properties into HISTORY output file. Currently, MBOTP properties
! are expected for the bottom boundary layer and/or sediment models:
! idBott( 1=isd50) grain_diameter mean grain diameter
! idBott( 2=idens) grain_density mean grain density
! idBott( 3=iwsed) settling_vel mean settling velocity
! idBott( 4=itauc) erosion_stres critical erosion stress
! idBott( 5=irlen) ripple_length ripple length
! idBott( 6=irhgt) ripple_height ripple height
! idBott( 7=ibwav) bed_wave_amp wave excursion amplitude
! idBott( 8=izdef) Zo_def default bottom roughness
! idBott( 9=izapp) Zo_app apparent bottom roughness
! idBott(10=izNik) Zo_Nik Nikuradse bottom roughness
! idBott(11=izbio) Zo_bio biological bottom roughness
! idBott(12=izbfm) Zo_bedform bed form bottom roughness
! idBott(13=izbld) Zo_bedload bed load bottom roughness
! idBott(14=izwbl) Zo_wbl wave bottom roughness
! idBott(15=iactv) active_layer_thickness active layer thickness
! idBott(16=ishgt) saltation saltation height
! 1 1 1 1 1 1 1
! 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
Hout(idBott) == T T T T T T T T T F F F F F F F
! Logical switches (TRUE/FALSE) to activate writing of time-averaged
! fields into AVERAGE output file.
Aout(idUvel) == T ! u 3D U-velocity
Aout(idv2dD) == F ! vbar_detided detided 2D V-velocity
! tracers other than biological and sediment tracers into the AVERAGE file.
Aout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of time-averaged,
! 2D momentum (ubar,vbar) diagnostic terms into DIAGNOSTIC output file.
Dout(M2rate) == T ! ubar_accel, ... acceleration
! 3D momentum (u,v) diagnostic terms into DIAGNOSTIC output file.
Dout(M3rate) == T ! u_accel, ... acceleration
! active (temperature and salinity) and passive (inert) tracer diagnostic
! terms into DIAGNOSTIC output file: [1:NAT+NPT,Ngrids].
Dout(iTrate) == T T ! temp_rate, ... time rate of change
NUSER = 0
USER = 0.d0
! NetCDF-4/HDF5 compression parameters for output files.
NC_SHUFFLE = 1 ! if non-zero, turn on shuffle filter
GRDNAME == data_s/roms_grd.nc
! ININAME == result_s/SAH_rst.nc
! ININAME == result_s/SAH_his_0010.nc
ININAME == data_s/initial_2013_01.nc
ITLNAME == NATL_itl.nc
IRPNAME == NATL_irp.nc
IADNAME == NATL_iad.nc
FWDNAME == NATL_fwd.nc
ADSNAME == NATL_ads.nc
! Nesting grids connectivity data: contact points information. This
! NetCDF file is special and complex. It is currently generated using
! the script "matlab/grid/contact.m" from the Matlab repository.
NGCNAME = sw06f_ngc.nc
! Input lateral boundary conditions and climatology file names. The
! USER has the option to split input data time records into several
! NetCDF files (see prologue instructions above). If so, use a single
! line per entry with a vertical bar (|) symbol after each entry,
! except the last one.
BRYNAME == data_s/bound_2013_01.nc
CLMNAME == result_s/SAH_his_0001.nc
! Input climatology nudging coefficients file name.
NUDNAME == sw06f_nud.nc
! Input Sources/Sinks forcing (like river runoff) file name.
SSFNAME == sw06f_rivers.nc
! Input forcing NetCDF file name(s). The USER has the option to enter
! several file names for each nested grid. For example, the USER may
! have different files for wind products, heat fluxes, rivers, tides,
! etc. The model will scan the file list and will read the needed data
! from the first file in the list containing the forcing field. Therefore,
! the order of the file names is very important. If using multiple forcing
! files per grid, first enter all the file names for grid 1, then grid 2,
! and so on. It is also possible to split input data time records into
! several NetCDF files (see prologue instructions above). Use a single line
! per entry with a continuation (\) or vertical bar (|) symbol after each
! entry, except the last one.
NFFILES == 1 ! number of unique forcing files
FRCNAME == data_s/force_2013_01.nc ! forcing file 1, grid 1
! data_s/force_2013_02.nc |
! data_s/force_2013_03.nc |
! data_s/force_2013_04.nc |
! data_s/force_2013_05.nc
! data_s/tide2.nc
! NFFILES == 9 ! number of forcing files
! FRCNAME == data/force_Pair_2008_08.nc\
! data/force_Qair_2008_08.nc\
! data/force_Tair_2008_08.nc\
! data/force_Uwind_2008_08.nc\
! data/force_Vwind_2008_08.nc\
! data/force_cloud_2008_08.nc\
! data/force_lwrad_2008_08.nc\
! data/force_rain_2008_08.nc\
! data/force_swrad_2008_08.nc
GSTNAME == result_s/SAH_gst.nc
RSTNAME == result_s/SAH_rst.nc
HISNAME == result_s/SAH_his.nc
TLMNAME == result_s/SAH_tlm.nc
TLFNAME == result_s/SAH_tlf.nc
ADJNAME == result_s/SAH_adj.nc
AVGNAME == result_s/SAH_avg.nc
DIANAME == result_s/SAH_dia.nc
STANAME == result_s/SAH_sta.nc
FLTNAME == result_s/SAH_flt.nc
! Input ASCII parameter filenames.
APARNAM = ../roms3/External/s4dvar.in
SPOSNAM = ../roms3/External/stations.in
FPOSNAM = ../roms3/External/floats.in
BPARNAM = ../roms3/External/bio_Fennel.in
SPARNAM = ../roms3/External/sediment.in
USRNAME = ../roms3/External/MyFile.da
what its happen?
