NESTING GRID blow up first step NaN problem
- Location: Technical University of Cartagena,Murcia, Spain
Finally I have been able to prepare all the needed files for my nesting aplication, a very simple case, a coarse grid and one refined grid. I have used coarse2fine to generate the refined grid and contact.m to get the contact file. I have been able to compile the model and I am able to run the model. But.... we get a blow up at the first time step. I have tried different things in order to detect the problem.
1.) Use different time steps.
2.) Prepare new refined grids with different refined factor.
3.) Put the bathymetry homogeneus in all the domain.
4.) Place the refined grid far from the land mask.
5.) Check my initials files and forcing to be sure that I dont have NaN values on it.
6.) Check the *.rst files, but I couldn´t see nothing strange.
7.) In all the test done with different grid, the blow up always happen on the top-right corner of the refined grid.
But I always get the same error and I don´t know what to do more. Attached you will find my configuration files. I will be really grateful if someone could help me or give any clue.
Model output
Monday - August 10, 2015 - 8:35:45 PM
Mar Menor, Julio 2015
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran-4.7
Compiler command : /usr/bin/gfortran-4.7
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
SVN Revision : 772M
Local Root : /home/trabajo/modelos/ROMS
Header Dir : /home/trabajo/modelos/ROMS/real_cases/marmenor/anidamiento/marmenor_marmenor
Header file : marmenor.h
Analytical Dir: /home/trabajo/modelos/ROMS/real_cases/marmenor/anidamiento/marmenor_marmenor
Resolution, Grid 01: 0332x0332x010, Parallel Threads: 1, Tiling: 001x001
300 ntimes Number of timesteps for 3-D equations.
30.000 dt Timestep size (s) for 3-D equations.
15 ndtfast Number of timesteps for 2-D equations between
1 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1 nHIS Number of timesteps between the writing fields
into history file.
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
1.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
1.0000E-05 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
1.0000E-02 Akv_bak Background vertical mixing coefficient (m2/s)
0.0000E+00 Zob Bottom roughness (m).
1.0000E-01 theta_s S-coordinate surface control parameter.
1.0000E-01 theta_b S-coordinate bottom control parameter.
0.100 Tcline S-coordinate surface/bottom layer width (m) used
1026.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
15749.000 dstart Time-stamp assigned to model initialization (days).
19680523.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idVvis) Write out vertical viscosity: AKv.
T Hout(idTdif) Write out vertical diffusion: AKt(itemp).
T Hout(idSdif) Write out vertical diffusion: AKt(isalt).
Output Restart File: OUTPUT/marmenor_rst.nc
Output History File: OUTPUT/marmenor_his.nc
Input Grid File: INPUT/marmenor_grd.nc
Nesting grid connectivity File: INPUT/contact_mm_enc.nc
Input Nonlinear Initial File: INPUT/marmenor_ini.nc
Input Forcing File 01: INPUT/marmenor_frz.nc
Resolution, Grid 02: 0105x0180x010, Parallel Threads: 1, Tiling: 001x001
Physical Parameters, Grid: 02
100 ntimes Number of timesteps for 3-D equations.
10.000 dt Timestep size (s) for 3-D equations.
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
Output Restart File: OUTPUT/marmenorHR_rst.nc
Output History File: OUTPUT/marmenorHR_his.nc
Input Grid File: INPUT/marmenorHR_grd.nc
Input Nonlinear Initial File: INPUT/marmenorHR_ini.nc
Input Forcing File 01: INPUT/marmenorHR_frz.nc
Tile partition information for Grid 01: 0332x0332x0010 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 332 1 332 1102240
Tile partition information for Grid 02: 0105x0180x0010 tiling: 001x001
0 1 105 1 180 189000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 333.50 0.50 333.50 RHO-points
0 0.00 333.00 0.50 333.50 U-points
0 0.50 333.50 0.00 333.00 V-points
Tile minimum and maximum fractional coordinates for Grid 02:
0 -2.50 107.50 -2.50 182.50 RHO-points
0 -3.00 107.00 -2.50 182.50 U-points
0 -2.50 107.50 -3.00 182.00 V-points
zeta 1 Closed Closed Closed Closed
2 Nested Nested Nested Nested
ubar 1 Closed Closed Closed Closed
vbar 1 Closed Closed Closed Closed
u 1 Closed Closed Closed Closed
v 1 Closed Closed Closed Closed
temp 1 Closed Closed Closed Closed
salt 1 Closed Closed Closed Closed
Marmenor Mar Menor, Julio 2015
MASKING Land/Sea masking.
NESTING Nesting grids: Composite and Refinement.
NONLINEAR Nonlinear Model.
!ONE_WAY Two-way nesting in refinement grids.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Thread # 0 (pid= 18001) is active.
10 0.0000000 0.0000000 0.000 0.000 0.000 0.000
9 -0.1000000 -0.0998397 -0.050 -0.010 -2.203 -4.356
8 -0.2000000 -0.1996963 -0.100 -0.020 -4.407 -8.713
7 -0.3000000 -0.2995770 -0.150 -0.030 -6.611 -13.072
6 -0.4000000 -0.3994885 -0.200 -0.040 -8.815 -17.431
5 -0.5000000 -0.4994381 -0.250 -0.050 -11.021 -21.792
4 -0.6000000 -0.5994326 -0.300 -0.060 -13.227 -26.155
3 -0.7000000 -0.6994790 -0.350 -0.070 -15.435 -30.520
2 -0.8000000 -0.7995844 -0.400 -0.080 -17.644 -34.888
1 -0.9000000 -0.8997557 -0.450 -0.090 -19.855 -39.259
0 -1.0000000 -1.0000000 -0.500 -0.100 -22.067 -43.633
Vertical S-coordinate System, Grid 02:
9 -0.1000000 -0.0998397 -0.566 -0.010 -0.603 -0.639
8 -0.2000000 -0.1996963 -1.133 -0.020 -1.205 -1.278
7 -0.3000000 -0.2995770 -1.700 -0.030 -1.808 -1.917
6 -0.4000000 -0.3994885 -2.266 -0.040 -2.412 -2.557
5 -0.5000000 -0.4994381 -2.833 -0.050 -3.015 -3.196
4 -0.6000000 -0.5994326 -3.401 -0.060 -3.619 -3.836
3 -0.7000000 -0.6994790 -3.968 -0.070 -4.222 -4.477
2 -0.8000000 -0.7995844 -4.536 -0.080 -4.827 -5.117
1 -0.9000000 -0.8997557 -5.105 -0.090 -5.431 -5.758
0 -1.0000000 -1.0000000 -5.673 -0.100 -6.036 -6.400
Time Splitting Weights for Grid 01: ndtfast = 15 nfast = 22
1-0.0006740978872509 0.0666666666666667-0.0006740978872509 0.0666666666666667
2-0.0001913161153518 0.0667116065258167-0.0008654140026027 0.1333782731924834
3 0.0014472038369421 0.0667243609335069 0.0005817898343395 0.2001026341259903
4 0.0042370228855824 0.0666278806777107 0.0048188127199218 0.2667305148037010
5 0.0081665994120431 0.0663454124853385 0.0129854121319649 0.3330759272890396
6 0.0132119623624627 0.0658009725245357 0.0261973744944276 0.3988768998135752
7 0.0193298623751124 0.0649201750337048 0.0455272368695400 0.4637970748472801
8 0.0264494009361902 0.0636315175420307 0.0719766378057303 0.5274285923893107
9 0.0344621375639418 0.0618682241462847 0.1064387753696720 0.5892968165355954
10 0.0432106750211074 0.0595707483086885 0.1496494503907794 0.6488675648442840
11 0.0524757225556949 0.0566900366406147 0.2021251729464743 0.7055576014848987
12 0.0619616371700794 0.0531916551369017 0.2640868101165537 0.7587492566218004
13 0.0712804429184289 0.0490608793255631 0.3353672530349826 0.8078101359473635
14 0.0799343282324558 0.0443088497976678 0.4153015812674384 0.8521189857450313
15 0.0872966212754959 0.0389798945821708 0.5025982025429343 0.8910988803272021
16 0.0925912433249121 0.0331601198304711 0.5951894458678464 0.9242590001576731
17 0.0948706401828253 0.0269873702754769 0.6900600860506717 0.9512463704331501
18 0.0929921916151718 0.0206626609299552 0.7830522776658435 0.9719090313631054
19 0.0855930988190858 0.0144631814889438 0.8686453764849293 0.9863722128520491
20 0.0710637499186094 0.0087569749010047 0.9397091264035388 0.9951291877530538
21 0.0475195634887281 0.0040193915730974 0.9872286898922669 0.9991485793261512
22 0.0127713101077333 0.0008514206738489 1.0000000000000002 1.0000000000000000
ndtfast, nfast = 15 22 nfast/ndtfast = 1.46667
1.000000000000 1.070450639131 0.535225319565 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.09467
Time Splitting Weights for Grid 02: ndtfast = 15 nfast = 22
Minimum X-grid spacing, DXmin = 5.13006381E-02 km
Maximum X-grid spacing, DXmax = 5.90138925E-02 km
Minimum Y-grid spacing, DYmin = 6.31138901E-02 km
Maximum Y-grid spacing, DYmax = 6.76060742E-02 km
Minimum Z-grid spacing, DZmin = 4.99358728E-02 m
Maximum Z-grid spacing, DZmax = 4.37394549E+00 m
Minimum barotropic Courant Number = 1.07019289E-01
Maximum barotropic Courant Number = 9.96831808E-01
Maximum Coriolis Courant Number = 2.68255786E-03
Metrics information for Grid 02:
Minimum X-grid spacing, DXmin = 1.73342850E-02 km
Maximum X-grid spacing, DXmax = 1.74328026E-02 km
Minimum Y-grid spacing, DYmin = 2.23989981E-02 km
Maximum Y-grid spacing, DYmax = 2.24492431E-02 km
Minimum Z-grid spacing, DZmin = 5.61013281E-01 m
Maximum Z-grid spacing, DZmax = 6.41510173E-01 m
Minimum barotropic Courant Number = 3.60408169E-01
Maximum barotropic Courant Number = 3.84596320E-01
Maximum Coriolis Courant Number = 8.92822667E-04
Refined Nested Grid(s) Information:
Refined Donor Refined Timestep Refined
Grid Grid Scale Ratio Timesteps
02 01 03 3.00000 03
WARNING: Usually the number of Refined Timesteps must be the same
as the Refined Scale for numerical stability.
NLM: GET_STATE - Read state initial conditions, t = 15749 00:00:00
(Grid 01, File: marmenor_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 1.50000000E+01 Max = 1.50000000E+01)
- salinity
(Min = 3.70000000E+01 Max = 3.70000000E+01)
(Grid 02, File: marmenorHR_ini.nc, Rec=0001, Index=1)
- free-surface
- salinity
GET_2DFLD - surface u-momentum stress, t = 15748 00:00:00
(Rec=0000001, Index=1, File: marmenor_frz.nc)
(Tmin= 15748.0000 Tmax= 15766.0000)
GET_2DFLD - surface v-momentum stress, t = 15748 00:00:00
GET_2DFLD - surface net heat flux, t = 15748 00:00:00
GET_2DFLD - surface net freswater flux, (E-P), t = 15748 00:00:00
(Rec=0000001, Index=1, File: marmenorHR_frz.nc)
Maximum grid stiffness ratios: rx0 = 9.458743E-01 (Beckmann and Haidvogel)
rx1 = 1.792598E+01 (Haney)
Initial basin volumes: TotVolume = 2.8554180914E+09 m3
MinVolume = 1.7297458432E+02 m3
MaxVolume = 1.5143647000E+04 m3
Max/Min = 8.7548393654E+01
Basin information for Grid 02:
Maximum grid stiffness ratios: rx0 = 1.883611E-03 (Beckmann and Haidvogel)
rx1 = 3.569831E-02 (Haney)
Initial basin volumes: TotVolume = 4.5499995884E+07 m3
MinVolume = 2.2132154882E+02 m3
MaxVolume = 2.5004607741E+02 m3
Max/Min = 1.1297864069E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00000300)
NL ROMS/TOMS: started time-stepping: (Grid: 02 TimeSteps: 00000001 - 00000100)
GET_2DFLD - surface u-momentum stress, t = 15766 00:00:00
(Rec=0000002, Index=2, File: marmenor_frz.nc)
GET_2DFLD - surface v-momentum stress, t = 15766 00:00:00
GET_2DFLD - surface net heat flux, t = 15766 00:00:00
GET_2DFLD - surface net freswater flux, (E-P), t = 15766 00:00:00
STEP Day HH:MM:SS KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME Grid
0 15749 00:00:00 0.000000E+00 1.032857E+02 1.032857E+02 2.921251E+09 01
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: OUTPUT/marmenor_his.nc
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000001 01
(Rec=0000002, Index=2, File: marmenorHR_frz.nc)
0 15749 00:00:00 0.000000E+00 3.046833E+01 3.046833E+01 4.550000E+07 02
DEF_HIS - creating history file, Grid 02: OUTPUT/marmenorHR_his.nc
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000001 02
1 15749 00:00:10 NaN NaN NaN NaN 02
(105,180,01) NaN NaN NaN 0.000000E+00
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001 01
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001 02
Elapsed CPU time (seconds):
Thread # 0 CPU: 2.772
Total: 2.772
Allocation and array initialization .............. 0.232 ( 8.3694 %)
Ocean state initialization ....................... 0.048 ( 1.7316 %)
Reading of input data ............................ 0.016 ( 0.5772 %)
Computation of global information integrals ...... 0.024 ( 0.8658 %)
Writing of output data ........................... 0.340 (12.2655 %)
Model 2D kernel .................................. 0.788 (28.4271 %)
2D/3D coupling, vertical metrics ................. 0.040 ( 1.4430 %)
Omega vertical velocity .......................... 0.020 ( 0.7215 %)
Equation of state for seawater ................... 0.020 ( 0.7215 %)
3D equations right-side terms .................... 0.076 ( 2.7417 %)
3D equations predictor step ...................... 0.092 ( 3.3189 %)
Pressure gradient ................................ 0.056 ( 2.0202 %)
Harmonic stress tensor, S-surfaces ............... 0.044 ( 1.5873 %)
Corrector time-step for 3D momentum .............. 0.076 ( 2.7417 %)
Corrector time-step for tracers .................. 0.080 ( 2.8860 %)
Total: 1.952 70.4185
All percentages are with respect to total time = 2.772
Total: 2.772
Ocean state initialization ....................... 0.036 ( 1.2987 %)
Reading of input data ............................ 0.004 ( 0.1443 %)
Computation of global information integrals ...... 0.036 ( 1.2987 %)
Writing of output data ........................... 0.060 ( 2.1645 %)
Model 2D kernel .................................. 0.132 ( 4.7619 %)
2D/3D coupling, vertical metrics ................. 0.008 ( 0.2886 %)
Omega vertical velocity .......................... 0.004 ( 0.1443 %)
Equation of state for seawater ................... 0.012 ( 0.4329 %)
3D equations right-side terms .................... 0.016 ( 0.5772 %)
3D equations predictor step ...................... 0.020 ( 0.7215 %)
Pressure gradient ................................ 0.008 ( 0.2886 %)
Harmonic stress tensor, S-surfaces ............... 0.004 ( 0.1443 %)
Corrector time-step for 3D momentum .............. 0.012 ( 0.4329 %)
Corrector time-step for tracers .................. 0.016 ( 0.5772 %)
Total: 0.600 21.6450
ROMS/TOMS - Output NetCDF summary for Grid 02:
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Monday - August 10, 2015 - 8:35:47 PM
Thanks a lot in advance.
-Francisco
Model output
SVN Revision : 772M
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
02 01 03 3.00000 03
- free-surface
- salinity
- free-surface
- salinity
Total: 2.772
Total: 2.772
-Francisco
marmenor.h
- My *.h file
- (666 Bytes) Downloaded 643 times
marmenor.in
- My *.in file
- (76.8 KiB) Downloaded 608 times
Re: NESTING GRID blow up first step NaN problem
Getting a NaN that early in the run is probably something like a configuration problem, not a timestepping instability. Before everything was IEEE floating point standards, a job would die at the first divide by zero. That's what you want it to do now - check your compiler options for such a thing and recompile with that flag. Something about a floating point trap. You probably want to compile with USE_DEBUG on and ask for bounds checking and so forth. Then if you can get it to die, it might give you useful info about which file, which line caused the problem.
Dear Kate,
THANKS !!!
a lot for your answer. I am going to start to follow your instruction and I will inform about the results obtained.
-Francisco
THANKS !!!
-Francisco
Dear Kate,
You were right, after some test, set the debugging mode, activate the floating point for gfortran and set the initial conditions analytical, finally has been able to detect the problem, although I haven´t been able to resolve it. The results obtained in my test point out to the NDTFAST as the responsable of the problem, changes in his value give different results but always with an error.
I will keep on trying to resolve it but if anybody have any idea, it will be really welcome.
The error:
Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.
Backtrace for this error:
#0 0x2ACD2BB0F667
#1 0x2ACD2BB0FC34
#2 0x2ACD2C50A1DF
#3 0x659C46 in __step2d_mod_MOD_step2d_tile at step2d.f90:457
#4 0x68C160 in __step2d_mod_MOD_step2d at step2d.f90:101
#5 0x4D4B81 in main3d_ at main3d.f90:335
#6 0x403B21 in __ocean_control_mod_MOD_roms_run at ocean_control.f90:160
#7 0x403134 in ocean at master.f90:86
Excepción de coma flotant
The error:
#0 0x2ACD2BB0F667
#1 0x2ACD2BB0FC34
#2 0x2ACD2C50A1DF
Have you run the parent grid stand-alone without nesting to check that the basic set-up is stable? That's a basic sanity check on configuration.
Beyond that, a few things I notice in your list of CPP options and the logfile...
You have #defined UV_VIS2 but have the parameter nl_visc2=0 in both grids. So there is no explicit horizontal viscosity applied to help smooth things out. But this should only be a problem later once the run starts.
I don't see an option defined to activate vertical mixing / turbulence closure. I'm not sure what ROMS defaults to in that case, but it may be that the vertical divergence of the horizontal momentum flux (surface stress) goes entirely into the first s-coordinate level.
In that regard, your choice of theta_s, theta_b values in the s-coord stretching leads to a very thin surface layer (0.5 cm) at your minimum depth. See the info in the logfile under ...
(Also, read the notes in ocean.in about Vtransform and Vstretching. We encourage different choices there).
Dear John,
First of all, thanks a lot for your help. I really appreciate it a lot.
I tested the parent and the grid alone, and they run without problems.
Although I tried different values of theta_s, theta_b.. without any advance, today I have tried it again. Reviewing the value in the logfile and I realized of something strange. The model read properly theta_b,theta_s, but I always get the same value for S-coord, Cs-curve,... For example
Configuration 1 (an extreme one)
THETA_S == 2*0.0d0 ! surface stretching parameter
THETA_B == 2*0.0d0 ! bottom stretching parameter
TCLINE == 2*0.0d0 ! critical depth (m)
Getting:
9 -0.1000000 -0.1000000 -0.050 -0.000 -2.207 -4.363
8 -0.2000000 -0.2000000 -0.100 -0.000 -4.413 -8.727
7 -0.3000000 -0.3000000 -0.150 -0.000 -6.620 -13.090
6 -0.4000000 -0.4000000 -0.200 -0.000 -8.827 -17.453
5 -0.5000000 -0.5000000 -0.250 -0.000 -11.033 -21.817
4 -0.6000000 -0.6000000 -0.300 -0.000 -13.240 -26.180
3 -0.7000000 -0.7000000 -0.350 -0.000 -15.447 -30.543
2 -0.8000000 -0.8000000 -0.400 -0.000 -17.653 -34.906
1 -0.9000000 -0.9000000 -0.450 -0.000 -19.860 -39.270
0 -1.0000000 -1.0000000 -0.500 -0.000 -22.067 -43.633
9 -0.1000000 -0.1000000 -0.567 -0.000 -0.604 -0.640
8 -0.2000000 -0.2000000 -1.135 -0.000 -1.207 -1.280
7 -0.3000000 -0.3000000 -1.702 -0.000 -1.811 -1.920
6 -0.4000000 -0.4000000 -2.269 -0.000 -2.415 -2.560
5 -0.5000000 -0.5000000 -2.837 -0.000 -3.018 -3.200
4 -0.6000000 -0.6000000 -3.404 -0.000 -3.622 -3.840
3 -0.7000000 -0.7000000 -3.971 -0.000 -4.226 -4.480
2 -0.8000000 -0.8000000 -4.539 -0.000 -4.829 -5.120
1 -0.9000000 -0.9000000 -5.106 -0.000 -5.433 -5.760
0 -1.0000000 -1.0000000 -5.673 -0.000 -6.036 -6.400
Configuration 2 (a more realistic one)
Vtransform == 2*1 ! transformation equation
Vstretching == 2*1 ! stretching function
! Vertical S-coordinates parameters (see below for details), [1:Ngrids].
THETA_S == 2*7.0d0 ! surface stretching parameter
THETA_B == 2*0.4d0 ! bottom stretching parameter
TCLINE == 2*2.0d0
The model read it properly:
7.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E-01 theta_b S-coordinate bottom control parameter.
2.000 Tcline S-coordinate surface/bottom layer width (m) used
But again, I get:
10 0.0000000 -0.0000000 0.000 0.000 -0.000 -0.000
9 -0.1000000 -0.0019414 -0.050 -0.050 -0.092 -0.134
8 -0.2000000 -0.0076391 -0.100 -0.100 -0.265 -0.429
7 -0.3000000 -0.0270074 -0.150 -0.150 -0.732 -1.315
6 -0.4000000 -0.0878699 -0.200 -0.200 -2.095 -3.990
5 -0.5000000 -0.2181019 -0.250 -0.250 -4.954 -9.657
4 -0.6000000 -0.3575721 -0.300 -0.300 -8.012 -15.723
3 -0.7000000 -0.4508634 -0.350 -0.350 -10.074 -19.797
2 -0.8000000 -0.5424010 -0.400 -0.400 -12.098 -23.795
1 -0.9000000 -0.6968391 -0.450 -0.450 -15.478 -30.507
0 -1.0000000 -1.0000000 -0.500 -0.500 -22.067 -43.633
10 0.0000000 -0.0000000 -0.000 0.000 -0.000 -0.000
9 -0.1000000 -0.0019414 -0.207 -0.200 -0.208 -0.209
8 -0.2000000 -0.0076391 -0.428 -0.400 -0.431 -0.434
7 -0.3000000 -0.0270074 -0.699 -0.600 -0.709 -0.719
6 -0.4000000 -0.0878699 -1.123 -0.800 -1.155 -1.187
5 -0.5000000 -0.2181019 -1.801 -1.000 -1.880 -1.960
4 -0.6000000 -0.3575721 -2.513 -1.200 -2.643 -2.773
3 -0.7000000 -0.4508634 -3.056 -1.400 -3.220 -3.384
2 -0.8000000 -0.5424010 -3.592 -1.600 -3.789 -3.986
1 -0.9000000 -0.6968391 -4.360 -1.800 -4.613 -4.866
0 -1.0000000 -1.0000000 -5.673 -2.000 -6.036 -6.400
Do you have any idea about what is it happening?.
Thanks a lot John.
Getting:
TCLINE == 2*2.0d0
But again, I get:
Thanks a lot John.
After reading initial conditions for grid 2 ...
But if you look immediately prior to the report in your logfile of:
You didn't declare the number of forcing files for grid 2, which you should. But the problem is probably embedding comment !Forcing Mar Menor in the FRCNAME list after the continuation character \ and before the next file name.
Change your ocean.in from:
ROMS goes on to read forcing data for both grids for t = 15749.NLM: GET_STATE - Read state initial conditions, t = 15749 00:00:00
you'll see ROMS reads forcing data from marmenor_frz.nc for t = 15766 00:00:00 but not from marmenorHR_frz.nc.STEP Day HH:MM:SS KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME Grid
toNFFILES == 1 ! number of forcing files
FRCNAME == INPUT/marmenor_frz.nc \ !Forcing Mar Menor
NFFILES == 1 1 ! number of forcing files
Dear John,
Thanks a lot for your help, every answer give me hopes to resolve this problem.
I did the changes proposed but I am still getting the error. In order to be sure that I don´t have any problem with my initial files or forcing files, I have defined them analytically, but without any improvement. Below you will find the error output and my *.h options.
I am really confused, cause as I explained in my last post, I always get the same value for S-coord using different values for theta_s,theta_b,... checking the log output I can see that the model read them properly but it has not affected to the s-coord calculation. In a extreme test I have removed the lines regarding THETA_S,THETA_B,.... from the *.in file and the model still use the same s-coord.
LOG OUTPUT
Thursday - August 13, 2015 - 5:42:45 PM
SVN Revision : 772M
180 ntimes Number of timesteps for 3-D equations.
3.000 dt Timestep size (s) for 3-D equations.
10 ndtfast Number of timesteps for 2-D equations between
to standard output.
into history file.
time-averaged data.
864000 nAVG Number of timesteps between the writing of
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
for tracer 02: salt
for turbulent energy.
0.000 charnok_alpha Charnok factor for Zos calculation.
0.000 zos_hsig_alpha Factor for Zos calculation using Hsig(Awave).
0.000 sz_alpha Factor for Wave dissipation surface tke flux .
0.000 crgban_cw Factor for Craig/Banner surface tke flux.
0.0000E+00 Zos Surface roughness (m).
0.0000E+00 theta_s S-coordinate surface control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
17.000 T0 Background potential temperature (C) constant.
37.000 S0 Background salinity (PSU) constant.
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
Output Averages File: OUTPUT/marmenor_avg.nc
540 ntimes Number of timesteps for 3-D equations.
1.000 dt Timestep size (s) for 3-D equations.
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
1.0000E-02 Zos Surface roughness (m).
for tracer 02: salt
for 3D momentum.
Output Averages File: OUTPUT/marmenorHR_avg.nc
tke 1 Closed Closed Closed Closed
Thread # 0 (pid= 30723) is active.
Time Splitting Weights for Grid 01: ndtfast = 10 nfast = 15
1 0.0014850648765542 0.1000000000000000 0.0014850648765542 0.1000000000000000
2 0.0059386031399402 0.0998514935123446 0.0074236680164944 0.1998514935123445
3 0.0133457074936657 0.0992576331983506 0.0207693755101601 0.2991091267106951
4 0.0236484051180389 0.0979230624489840 0.0444177806281990 0.3970321891596791
5 0.0366959666818608 0.0955582219371801 0.0811137473100598 0.4925904110968592
6 0.0521753389587947 0.0918886252689940 0.1332890862688545 0.5844790363658532
7 0.0695217010484137 0.0866710913731145 0.2028107873172682 0.6711501277389678
8 0.0878091442019233 0.0797189212682732 0.2906199315191915 0.7508690490072409
9 0.1056214752525633 0.0709380068480808 0.3962414067717548 0.8218070558553218
10 0.1209031436506851 0.0603758593228245 0.5171445504224399 0.8821829151781463
11 0.1307902921035067 0.0482855449577560 0.6479348425259466 0.9304684601359023
12 0.1314219308195445 0.0352065157474053 0.7793567733454911 0.9656749758833076
13 0.1177312353577226 0.0220643226654509 0.8970880087032138 0.9877392985487585
14 0.0832169680811588 0.0102911991296786 0.9803049767843727 0.9980304976784371
15 0.0196950232156274 0.0019695023215627 1.0000000000000000 0.9999999999999999
ndtfast, nfast = 10 15 nfast/ndtfast = 1.50000
1.000000000000 1.083803072626 0.541901536313 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.00000
Time Splitting Weights for Grid 02: ndtfast = 10 nfast = 15
Minimum Z-grid spacing, DZmin = 5.00000000E-02 m
Maximum Z-grid spacing, DZmax = 4.36330972E+00 m
Minimum barotropic Courant Number = 1.60528934E-02
Maximum barotropic Courant Number = 1.49524771E-01
Maximum Coriolis Courant Number = 2.68255786E-04
Minimum Z-grid spacing, DZmin = 5.61898073E-01 m
Maximum Z-grid spacing, DZmax = 6.39971063E-01 m
Minimum barotropic Courant Number = 5.40612253E-02
Maximum barotropic Courant Number = 5.76894480E-02
Maximum Coriolis Courant Number = 8.92822667E-05
02 01 03 3.00000 03
rx1 = 1.797161E+01 (Haney)
MinVolume = 1.7319671673E+02 m3
MaxVolume = 1.5106824075E+04 m3
Max/Min = 8.7223501465E+01
rx1 = 3.578860E-02 (Haney)
MinVolume = 2.2167067957E+02 m3
MaxVolume = 2.4944616710E+02 m3
Max/Min = 1.1253006829E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00000180)
NL ROMS/TOMS: started time-stepping: (Grid: 02 TimeSteps: 00000001 - 00000540)
0 15749 00:00:00 0.000000E+00 1.028344E+02 1.028344E+02 2.921251E+09 01
0 15749 00:00:00 0.000000E+00 3.033419E+01 3.033419E+01 4.550000E+07 02
1 15749 00:00:01 NaN NaN NaN NaN 02
WRT_RST - wrote re-start fields (Index=2,1) into time record = 0000001 01
WRT_RST - wrote re-start fields (Index=2,2) into time record = 0000001 02
Thread # 0 CPU: 3.772
Total: 3.772
Allocation and array initialization .............. 0.328 ( 8.6957 %)
Ocean state initialization ....................... 0.052 ( 1.3786 %)
Computation of vertical boundary conditions ...... 0.004 ( 0.1060 %)
Computation of global information integrals ...... 0.024 ( 0.6363 %)
Writing of output data ........................... 0.400 (10.6045 %)
Model 2D kernel .................................. 0.548 (14.5281 %)
2D/3D coupling, vertical metrics ................. 0.052 ( 1.3786 %)
Omega vertical velocity .......................... 0.012 ( 0.3181 %)
Equation of state for seawater ................... 0.080 ( 2.1209 %)
GLS vertical mixing parameterization ............. 0.840 (22.2693 %)
3D equations right-side terms .................... 0.076 ( 2.0148 %)
3D equations predictor step ...................... 0.088 ( 2.3330 %)
Pressure gradient ................................ 0.064 ( 1.6967 %)
Harmonic stress tensor, S-surfaces ............... 0.040 ( 1.0605 %)
Corrector time-step for 3D momentum .............. 0.080 ( 2.1209 %)
Corrector time-step for tracers .................. 0.084 ( 2.2270 %)
Total: 2.772 73.4889
All percentages are with respect to total time = 3.772
Total: 3.772
Ocean state initialization ....................... 0.040 ( 1.0605 %)
Computation of global information integrals ...... 0.032 ( 0.8484 %)
Writing of output data ........................... 0.068 ( 1.8028 %)
Model 2D kernel .................................. 0.084 ( 2.2269 %)
2D/3D coupling, vertical metrics ................. 0.012 ( 0.3181 %)
Omega vertical velocity .......................... 0.004 ( 0.1060 %)
Equation of state for seawater ................... 0.028 ( 0.7423 %)
GLS vertical mixing parameterization ............. 0.176 ( 4.6660 %)
3D equations right-side terms .................... 0.012 ( 0.3181 %)
3D equations predictor step ...................... 0.020 ( 0.5302 %)
Pressure gradient ................................ 0.012 ( 0.3181 %)
Harmonic stress tensor, S-surfaces ............... 0.004 ( 0.1060 %)
Corrector time-step for 3D momentum .............. 0.016 ( 0.4242 %)
Corrector time-step for tracers .................. 0.016 ( 0.4242 %)
Total: 0.852 22.5875
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Thursday - August 13, 2015 - 5:42:49 PM
LOG OUTPUT
SVN Revision : 772M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
02 01 03 3.00000 03
Total: 3.772
Total: 3.772
Looking over the logfile output you've showed you haven't tried theta_s more than 0.1, so it will have very little effect. Strictly speaking theta_s = 0 is invalid, but the limit theta_s -> 0 is OK. You get regular sigma coordinates. You need theta_s of 3 or more to really see any appreciable stretching in the deepest water. Read more at https://www.myroms.org/wiki/index.php/V ... coordinate
But vertical coordinate does not appear to be your problem unless you are incorrectly evaluating the z coordinate in creating your initial conditions and introducing a lot of initial potential energy in the stratification. My intuition is to suspect your grid or initial conditions. I assume you plotted up the initial conditions file you were using before to make sure it is dynamically sensible.
Your time steps are extremely small (1 s for the baroclinic mode and 0.1 s for the barotropic) yet the run is blowing up on the very first time step of the nested grid, so I think the initial conditions are not dynamically sensible or include NaNs.
As a rule, I would say NDTFAST = 10 is too small. Recommended values are 20 or greater. I don't know if that cold be a problem or not.
Dear John,
I have tried different values for THETA_S, including values higher than 3.
In my last runs, I have defined my initial condition by ANA_INITIAL, so I am not using any initial condition files.
Trying different things I have used several values for DT and NDTFAST but I haven´t get any advance.
Thanks John!!!
Thanks John!!!
