I am trying to run a case where I have 4 nested layers refine grid case. I create the 3 refine grids using coarse2fine fucntion.
I also used contact.m to create my contact file.
My grids are 1:5 refined factor from the one before. Each grid is inside of the one before. I read that the dt needs to be decrease by the refine factor and also that it needs to be divisible of the donot grid.
I ran the case of 3 nested without problem. DT == 30.0d0 6.0d0 1.0d0
However I am trying now to incorporated my last and final nested grid, but is blowing up and I am not sure how to solve the problem. The first time I ran it it was blowing up because the donor grid needs to be an exact divisible number.
I change it to DT == 30.0d0 6.0d0 1.0d0 1.0d0 and now I get the following error:
PUT_REFINE2D - unbounded contact points temporal: interpolation:
cr = 03 dg = 02 ng = 03
iic(dg) = ******* told = 1 tnew = 2
iic(ng) = 0000008 Wold = 1.83333 Wnew = -0.83333
time(ng) = ******* time(told) = ******* time(tnew) = *******
PUT_REFINE3D - unbounded contact points temporal: interpolation:
Elapsed CPU time (seconds):
Node # 0 CPU: 21.731
Node # 0 CPU: 21.747
ROMS/TOMS - Output NetCDF summary for Grid 02:
ROMS/TOMS - Output NetCDF summary for Grid 03:
ROMS/TOMS - Output NetCDF summary for Grid 04:
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS - Fatal algorithm result .. exit_flag: 8
Is this is because I have to add the DT from the first grid to be able to always be a factor of 5, is that the case then it might blow up bc the dt is too high?
I attached my contact file and my input file.
I am new trying to understand the contact file, I just want to make sure that is not the problem.
Legna
Four Nested Grid
Four Nested Grid
ocean_crocker_reef.in
- (118.9 KiB) Downloaded 480 times
- Crocker_contact.nc
- (12.49 MiB) Downloaded 441 times
Re: Four Nested Grid
my experience with the nesting is that the child grids do not have to step on a time scale factor equal to the spatial scale factor. That is a recommendation, but not a requirement. I have not seen that error before, but you should be able to use dt of the child as the same as the parent. You could also try:
DT == 30.0d0 6.0d0 1.0d0 0.5d0
and see if that works.
