I got the error when I run WRF-ROMS using COAWST.
I activated USE_DEBUG of coast.bash file.
I tried testcase, it worked so well.
Image PC Routine Line Source
coawstG 0000000002F1E9B9 Unknown Unknown Unknown
coawstG 0000000002F1D330 Unknown Unknown Unknown
coawstG 0000000002EC4012 Unknown Unknown Unknown
coawstG 0000000002E57403 Unknown Unknown Unknown
coawstG 0000000002E603BB Unknown Unknown Unknown
libpthread.so.0 0000003DB3A0F710 Unknown Unknown Unknown
coawstG 0000000002F34B55 Unknown Unknown Unknown
coawstG 0000000002EC0CC4 Unknown Unknown Unknown
coawstG 0000000000420F1F cdecode_line_..0 325 read_coawst_par.f90
coawstG 000000000041F6DD read_coawst_par_ 81 read_coawst_par.f90
coawstG 0000000000414070 MAIN__ 62 master.f90
coawstG 0000000000411BF6 Unknown Unknown Unknown
libc.so.6 0000003DB361ED1D Unknown Unknown Unknown
coawstG 0000000000411AE9 Unknown Unknown Unknown
How can I fix it?
Thanks.
Re: forrtl: severe (174): SIGSEGV, segmentation fault occurr
Line 325 of read_coawst_par.f90 in the Build directory is:
! This routine reads in physical model input parameters. !
decode=.FALSE.
DO i=1,Lval
IF (Vstring(i:i).eq.CHAR(32)) THEN
IF (Vstring(i+1:i+1).ne.CHAR(32)) decode=.TRUE.
Iblank=i
ELSE
ie=i
ENDIF
IF (decode.or.(i.eq.Lval)) THEN
Nval=Nval+1
! Processing numeric values. Check starting character to determine
! if numeric or character values. It is possible to have both when
! processing repetitions via the multiplication symbol.
Schar=ICHAR(Vstring(is:is))
IF (((48.le.Schar).and.(Schar.le.57)).or. &
& (Schar.eq.43).or.(Schar.eq.45)) THEN
IF ((Nmul.gt.0).and. &
& (is.lt.Imul(ic)).and.(Imul(ic).lt.ie)) THEN
READ (Vstring(is:Imul(ic)-1),*) copies
Schar=ICHAR(Vstring(Imul(ic)+1:Imul(ic)+1))
IF ((43.le.Schar).and.(Schar.le.57)) THEN
READ (Vstring(Imul(ic)+1:ie),*) Rval(Nval)
DO j=1,copies-1
Rval(Nval+j)=Rval(Nval)
ELSE
string=Vstring(Imul(ic)+1:ie)
LenS=LEN_TRIM(string)
Cval(Nval)=string(1:LenS)
DO j=1,copies-1
Cval(Nval+j)=Cval(Nval)
Nval=Nval+copies-1
ic=ic+1
ELSE
string=Vstring(is:ie)
READ (string(1:LenS),*) Rval(Nval)
ELSE
! Processing character values (logicals and strings).
Cval(Nval)=Vstring(Imul(ic)+1:ie)
DO j=1,copies-1
Nval=Nval+copies-1
ic=ic+1
ELSE
325--> Cval(Nval)=TRIM(ADJUSTL(string))
IsString=.TRUE.
is=Iblank+1
ie=Lval
decode=.FALSE.
status=Nval
cdecode_line=status
RETURN
END FUNCTION cdecode_line
FUNCTION cload_i (Ninp, Vinp, Nout, Vout)
decode=.FALSE.
DO i=1,Lval
Iblank=i
ELSE
ie=i
ENDIF
Nval=Nval+1
DO j=1,copies-1
ELSE
DO j=1,copies-1
Nval=Nval+copies-1
ic=ic+1
ELSE
ELSE
DO j=1,copies-1
Nval=Nval+copies-1
ic=ic+1
ELSE
IsString=.TRUE.
is=Iblank+1
ie=Lval
decode=.FALSE.
status=Nval
cdecode_line=status
RETURN
since these are issues with coawst and not rutgers roms, lets move this discussion.
can you send to me the read_coawst_par.f90
thanks
john
jcwarner@usgs.gov
thanks
john
jcwarner@usgs.gov
I send an email with the file.jcwarner wrote:since these are issues with coawst and not rutgers roms, lets move this discussion.
thanks
john
jcwarner@usgs.gov
thanks.
