I have both AVERAGE and AVERAGE_DETIDE defined in the .h file, and the average period is 3 days.
Any comments? Thanks!Model Input Parameters: ROMS/TOMS version 3.6
180.000 dt Timestep size (s) for 3-D equations.
1440 nAVG Number of timesteps between the writing of
T Aout(idFsuD) Write out detided free-surface.
T Aout(idu2dD) Write out detided 2D U-velocity.
T Aout(idv2dD) Write out detided 2D V-velocity.
T Aout(idu3dD) Write out detided 3D U-velocity.
T Aout(idv3dD) Write out detided 3D V-velocity.
T Aout(idTrcD) Write out detided tracer 01: temp
T Aout(idTrcD) Write out detided tracer 02: salt
AVERAGES_DETIDE Writing out time-averaged nonlinear model detided fields.
(File: roms_ini_3Dtide.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 2.50000000E+01 Max = 2.50000000E+01)
- salinity
(Min = 3.40000000E+01 Max = 3.40000000E+01)
GET_NGFLD - tidal period
(Min = 4.30819210E+04 Max = 2.38071599E+06)
(Min = 2.15870429E-05 Max = 1.64282025E+01)
(Min = 4.72656640E-07 Max = 6.28318293E+00)
(Min = 3.70293942E-07 Max = 6.28318519E+00)
(Min = 1.32158243E-07 Max = 6.28318525E+00)
(Min = 1.15745545E-06 Max = 3.66242255E+00)
(Min = -4.56800388E-01 Max = 4.20064194E-01)
NETCDF_ENDDEF - unable to end definition mode for file:
../../inputs/scs30_gebco/roms_tide.nc
call from: def_tides.F
ROMS/TOMS - Output error ............ exit_flag: 3
REASON: NetCDF: One or more variable sizes violate format constraints
