I am introducing a tide signal from the western boundary for my model. I uses zeta_west variable in a boundary input file to specify the signal. When I tried to change the boundary condition of 2D V-momentum from Fla to Red at the West boundary the model stop taking my boundary input file.
Anyone have an idea why this happens?
Appreciate for the help.
Boundary input stop working when BC is changed to Red
Re: Boundary input stop working when BC is changed to Red
What is your western ubar boundary condition? The logic in question is in inp_par.F:
Setting either ubar or vbar to Fla will tell ROMS to read the free surface. There's also this:
CASE ('FLA')
S(ibry,ifield,igrid)%Flather = .TRUE.
S(ibry,ifield,igrid)%acquire = .TRUE.
S(ibry,isFsur,igrid)%acquire = .TRUE.
CASE ('RED')
S(ibry,ifield,igrid)%reduced = .TRUE.
#if defined FSOBC_REDUCED
Thanks for your reply!kate wrote:What is your western ubar boundary condition? The logic in question is in inp_par.F:Setting either ubar or vbar to Fla will tell ROMS to read the free surface. There's also this:Code: Select all
CASE ('FLA') S(ibry,ifield,igrid)%Flather = .TRUE. S(ibry,ifield,igrid)%acquire = .TRUE. S(ibry,isFsur,igrid)%acquire = .TRUE.
CASE ('RED') S(ibry,ifield,igrid)%reduced = .TRUE. #if defined FSOBC_REDUCED S(ibry,isFsur,igrid)%acquire = .TRUE. #endif
I used Red for ubar and Fla for vbar, and now I wanted to use Red for both. That's when it stop to read the free surface.
