Forcing data in .log file is different from .nc file
Hanq
#1 Unread post by Hanq »
Dear users,
This is some informations in my .log file,but it is different from that in my input file.
For example, I checket the minimum of surface heat flux is -99.99w/m-2 in my input forcing .nc file,but here is -2.50914436E-05.It is also different for other variables.
Does anyone know what's wrong with my modeling?
Thanks very much!
(File: roms_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = -2.48218344E+00 Max = 3.12232347E+01)
- salinity
(Min = 2.33817258E+00 Max = 3.55641991E+01)
(Min = 1.17000000E+02 Max = 1.77000000E+02)
(Min = 1.85000000E+02 Max = 3.26000000E+02)
(Min = 1.00000000E+00 Max = 1.00000000E+00)
(Min = 0.00000000E+00 Max = 4.00000000E-02)
GET_NGFLD - river runoff mass transport, t = 345 00:00:00
(Rec=0012, Index=2, File: roms_river.nc)
(Min = 8.40000000E+02 Max = 1.37300000E+04)
GET_2DFLD - surface u-momentum stress, t = 345 00:00:00
(Rec=0012, Index=1, File: roms_frc.nc)
(Min = -1.73476106E-04 Max = 1.34957980E-04)
GET_2DFLD - surface v-momentum stress, t = 345 00:00:00
(Min = -2.36919224E-04 Max = -2.68120380E-06)
GET_2DFLD - surface net heat flux, t = 345 00:00:00
(Min = -2.50914436E-05 Max = 1.57007871E-05)
GET_2DFLD - sea surface temperature climatology, t = 345 00:00:00
(Min = 4.90581638E+00 Max = 2.95751114E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 345 00:00:00
(Min = -1.61127110E-05 Max = -4.75281946E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 345 00:00:00
(Min = -1.83060502E-07 Max = 1.15392521E-07)
Re: Forcing data in .log file is different from .nc file
Did you set a _FillValue of -99.99 by chance?
Hanq
#3 Unread post by Hanq »
Dear Kate,
The range of surface heat flux is -99.99~230 in the whole domain for 12 months. I never give a _FillValue. It is the same to other variables.
ROMS is then dividing by (rho0*Cp) to get the units it uses internally.
Hanq
#5 Unread post by Hanq »
Dear Kate,
Thanks very much for your explaination so patient! I am looking forward to using ROMS well and discussing with everyone here.
Thanks again!
