ROMS Tools and Techniques
hi,i want to known
! Constants used in momentum stress computation.
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.003d0 ! m
Zos == 0.001d0 ! m
rdrg2 in one area can have diffrent constants? i mean is that some where rarg2=0.0025 .ohter rarg2=0.0014
Zob == 0.003d0 ! m
Zos == 0.001d0 ! m
Re: ROMS Tools and Techniques
Yes, you can have a spatially variable bottom drag. You set UV_DRAG_GRID. Then you have a choice of putting the bottom drag in your grid file or putting it in ana_drag.h (flag ANA_DRAG).
thanks,i am vary happy to hear this.but in ocean,i cann't find UV_DRAG_GRID,so now i not solve my problem.
thanks,i am vary happy to hear this.but in ocean.h,i cann't find UV_DRAG_GRID,so now i not solve my problem.kate wrote:Yes, you can have a spatially variable bottom drag. You set UV_DRAG_GRID. Then you have a choice of putting the bottom drag in your grid file or putting it in ana_drag.h (flag ANA_DRAG).
UV_DRAG_GRID is one of your cpp options. To search for strings in the ROMS code, you can:
from the top of the ROMS tree. You can add "-i" if you don't know the case of something.
grep -r UV_DRAG_GRID .
thank you very muchkate wrote:UV_DRAG_GRID is one of your cpp options. To search for strings in the ROMS code, you can:from the top of the ROMS tree. You can add "-i" if you don't know the case of something.Code: Select all
Hi,kate wrote:UV_DRAG_GRID is one of your cpp options. To search for strings in the ROMS code, you can:from the top of the ROMS tree. You can add "-i" if you don't know the case of something.Code: Select all
My mode is sensitive to drag coefficients and inverse techniques using adjont parameter estimation is the most resonale way, I want to know
in roms whether there have that method to deal with drag coefficients?
thanks for your help,look forward to your reply!
hi,editing in ana_drag.h like this , define ana_drag in estuary.h,then ./build_estuary.sh ,then run.But in the output file why the drag2=6E-04,not a array.pingding wrote:kate wrote:Yes, you can have a spatially variable bottom drag. You set UV_DRAG_GRID. Then you have a choice of putting the bottom drag in your grid file or putting it in ana_drag.h (flag ANA_DRAG).
in ana_drag.h like this:
# elif defined UV_QDRAG
DO j=JstrT,JendT ! based on Chezy coefficient (g/c^2)
DO i=IstrT,IendT
cff=1.8_r8*GRID(ng)%h(i,j)*LOG(GRID(ng)%h(i,j))
rdrag2(i,j)=g/(cff*cff)
#else
# if defined UV_LOGDRAG
DO j=JstrT,JendT
DO i=IstrT,IendT
ZoBot(i,j)=???
# elif defined UV_LDRAG
DO j=JstrT,JendT
DO i=IstrT,IendT
rdrag(i,j)=???
DO j=JstrT,JendT
DO i=IstrT,IendT
if(GRID(ng)%h(i,j).GE.100.0_r8)then
rdrag2(i,j)=1.5363E-03_r8
elif(GRID(ng)%h(i,j).LT.30.0_r8)then
rdrag2(i,j)=(100.0_r8-0.5413_r8*GRID(ng)%h(i,j))E-05
else
write(*,*),'12'
rdrag2(i,j)=(56.8850_r8+0.9674_r8*GRID(ng)%h(i,j))E-05
end if
output file:
1152000 ntimes Number of timesteps for 3-D equations.
3.000 dt Timestep size (s) for 3-D equations.
1 ndtfast Number of timesteps for 2-D equations between
28800 nRST Number of timesteps between the writing of data
into restart fields.
10 ninfo Number of timesteps between print of information
to standard output.
1200 nHIS Number of timesteps between the writing fields
into history file.
115200 ndefHIS Number of timesteps between creation of new
history files.
0 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
1200 nAVG Number of timesteps between the writing of
115200 ndefAVG Number of timesteps between creation of new
time-averaged file.
8.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
6.0000E-04 rdrg2 Quadratic bottom drag coefficient.
3.0000E-03 Zob Bottom roughness (m).
1028.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
1.0000E-03 Znudg Nudging/relaxation time scale (days)
Do you have both of these, in uppercase?hi,editing in ana_drag.h like this , define ana_drag in estuary.h,then ./build_estuary.sh ,then run.But in the output file why the drag2=6E-04,not a array.
#define ANA_DRAG
#define UV_DRAG_GRID
If you have both those things defined and the model is using a 2-D array of values, the report will still give you those rdrg and rdrg2 values, as well as Zob. You need to look to the report on the cpp flags - if both ANA_DRAG and UV_DRAG_GRID are defined, it will tell you ANA_DRAG_GRID is defined (mini bug).
thank you !it is solved now!wilkin wrote:Do you have both of these, in uppercase?hi,editing in ana_drag.h like this , define ana_drag in estuary.h,then ./build_estuary.sh ,then run.But in the output file why the drag2=6E-04,not a array.
#define ANA_DRAG
Thank you ! It is solved now,and the result is like you see!kate wrote:If you have both those things defined and the model is using a 2-D array of values, the report will still give you those rdrg and rdrg2 values, as well as Zob. You need to look to the report on the cpp flags - if both ANA_DRAG and UV_DRAG_GRID are defined, it will tell you ANA_DRAG_GRID is defined (mini bug).
Thank you ! I always have question why the rdrag2 at the same grid,such as rdrag2(355,466),have diffrent constant at diffrent time step?pingding wrote:hi,editing in ana_drag.h like this , define ana_drag in estuary.h,then ./build_estuary.sh ,then run.But in the output file why the drag2=6E-04,not a array.pingding wrote:kate wrote:Yes, you can have a spatially variable bottom drag. You set UV_DRAG_GRID. Then you have a choice of putting the bottom drag in your grid file or putting it in ana_drag.h (flag ANA_DRAG).
DO i=IstrT,IendT
#else
DO j=JstrT,JendT
DO i=IstrT,IendT
ZoBot(i,j)=???
DO j=JstrT,JendT
DO i=IstrT,IendT
rdrag(i,j)=???
DO j=JstrT,JendT
DO i=IstrT,IendT
else
write(*,*),'12'
end if
output file:
to standard output.
into history file.
history files.
time-averaged data.
time-averaged file.
