very early blowing_up
zhouchaojie
#1 Unread post by zhouchaojie »
here are the output ,I have checked the depth, there are no 0 or negative value, I am a new user of the roms, it makes me confused now.....
Resolution, Grid 01: 0198x0098x020, Parallel Threads: 1, Tiling: 001x001
1235520 ntimes Number of timesteps for 3-D equations.
100.000 dt Timestep size (s) for 3-D equations.
155520 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
8640 nHIS Number of timesteps between the writing fields
into history file.
311040 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
25920 nAVG Number of timesteps between the writing of
311040 ndefAVG Number of timesteps between creation of new
time-averaged file.
25920 nDIA Number of timesteps between the writing of
311040 ndefDIA Number of timesteps between creation of new
diagnostic file.
1.0000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
1.0000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
2 Vstretching S-coordinate stretching function.
5.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E-01 theta_b S-coordinate bottom control parameter.
5.000 Tcline S-coordinate surface/bottom layer width (m) used
20050101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
Output Restart File: /public/home/wanglong/Projects/CHS/test/result/CHS_rst.nc
Prefix for History Files: /public/home/wanglong/Projects/CHS/test/result/CHS_his
Prefix for Averages Files: /public/home/wanglong/Projects/CHS/test/result/CHS_avg
Prefix for Diagnostics Files: /public/home/wanglong/Projects/CHS/test/result/CHS_dia
Input Grid File: /public/home/wanglong/Projects/CHS/test/chsouth_grid.nc
Input Nonlinear Initial File: /public/home/wanglong/Projects/CHS/test/chsouth_initial.nc
Input Boundary File: /public/home/wanglong/Projects/CHS/test/chsouth_boundary.nc
Tile partition information for Grid 01: 0198x0098x0020 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 198 1 98 388080
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 199.50 0.50 99.50 RHO-points
0 0.00 199.00 0.50 99.50 U-points
0 0.50 199.50 0.00 99.00 V-points
zeta 1 Closed Chapman Imp Chapman Imp Closed
ubar 1 Closed Flather Flather Closed
vbar 1 Closed Flather Flather Closed
u 1 Closed Rad + Nud Rad + Nud Closed
v 1 Closed Rad + Nud Rad + Nud Closed
temp 1 Closed Rad + Nud Rad + Nud Closed
salt 1 Closed Rad + Nud Rad + Nud Closed
CHS China-South Sea Simulation
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms.
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_LDRAG Linear bottom stress.
Process Information:
Thread # 0 (pid= 23154) is active.
20 0.0000000 0.0000000 0.000 0.000 0.000 0.000
19 -0.0500000 -0.0005591 -0.126 -0.126 -0.806 -1.365
18 -0.1000000 -0.0027709 -0.257 -0.257 -3.262 -6.027
17 -0.1500000 -0.0074493 -0.394 -0.394 -8.177 -15.610
16 -0.2000000 -0.0154245 -0.539 -0.539 -16.381 -31.770
15 -0.2500000 -0.0275411 -0.694 -0.694 -28.717 -56.192
14 -0.3000000 -0.0446548 -0.862 -0.862 -46.037 -90.583
13 -0.3500000 -0.0676257 -1.044 -1.044 -69.200 -136.660
12 -0.4000000 -0.0973060 -1.243 -1.243 -99.055 -196.122
11 -0.4500000 -0.1345207 -1.461 -1.461 -136.427 -270.615
10 -0.5000000 -0.1800368 -1.700 -1.700 -182.079 -361.669
9 -0.5500000 -0.2345153 -1.961 -1.961 -236.671 -470.604
8 -0.6000000 -0.2984398 -2.246 -2.246 -300.686 -598.384
7 -0.6500000 -0.3720103 -2.555 -2.555 -374.323 -745.407
6 -0.7000000 -0.4549887 -2.887 -2.887 -457.345 -911.199
5 -0.7500000 -0.5464743 -3.241 -3.241 -548.853 -1093.964
4 -0.8000000 -0.6445848 -3.611 -3.611 -646.970 -1289.945
3 -0.8500000 -0.7460014 -3.990 -3.990 -748.384 -1492.521
2 -0.9000000 -0.8453281 -4.363 -4.363 -847.713 -1690.929
1 -0.9500000 -0.9341941 -4.710 -4.710 -936.608 -1868.467
0 -1.0000000 -1.0000000 -5.000 -5.000 -1002.500 -2000.000
12 0.0043042707117221 0.0335513677379153-0.0022367614257356 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864348 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001213 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565097 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906204 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716643 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402368 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399432 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712342 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524359 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729578 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236653 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893981 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886213 0.8237939964192927
27 0.0432936737565710 0.0230872677537126 0.3506756411451924 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772280 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880565 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256415 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325521 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348098 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479478 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213239 0.9738247715198165
36 0.0503158038019030 0.0080591141492892 0.8085423793232269 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497611 0.9930692679747334
39 0.0376397765791564 0.0033640675316746 0.9367177506289175 0.9964333355064080
40 0.0305543017255206 0.0021094083123694 0.9672720523544381 0.9985427438187774
41 0.0217382098544504 0.0010909315881854 0.9890102622088885 0.9996336754069628
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 1.93936657E+00 km
Maximum X-grid spacing, DXmax = 1.79412067E+01 km
Minimum Y-grid spacing, DYmin = 8.82198551E+00 km
Maximum Y-grid spacing, DYmax = 4.51487239E+01 km
Minimum Z-grid spacing, DZmin = 1.26397788E-01 m
Maximum Z-grid spacing, DZmax = 2.02576586E+02 m
Minimum barotropic Courant Number = 2.36319705E-03
Maximum barotropic Courant Number = 1.50161474E-01
Maximum Coriolis Courant Number = 6.00466551E-03
(Grid 01, File: chsouth_initial.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 2.14800000E+00 Max = 2.55639992E+01)
- salinity
(Min = 3.32639999E+01 Max = 3.47130013E+01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 0 00:00:00
(Rec=0000001, Index=2, File: chsouth_boundary.nc)
(Tmin= 0.0000 Tmax= 1430.0000)
(Min = -1.91762894E-01 Max = 3.29111695E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -1.63401559E-01 Max = 3.10286045E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -2.80825829E-04 Max = 2.94956088E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -1.93699211E-01 Max = 7.04723597E-03)
GET_NGFLD - temperature eastern boundary condition, t = 0 00:00:00
(Min = 1.04921162E+00 Max = 2.58121376E+01)
GET_NGFLD - salinity eastern boundary condition, t = 0 00:00:00
(Min = 1.38241091E+01 Max = 3.46544914E+01)
GET_NGFLD - temperature southern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 2.48827629E+01)
GET_NGFLD - salinity southern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.45693321E+01)
Maximum grid stiffness ratios: rx0 = 8.101426E-01 (Beckmann and Haidvogel)
rx1 = 2.460969E+01 (Haney)
Initial basin volumes: TotVolume = 8.8292239712E+14 m3
MinVolume = 3.0220893296E+06 m3
MaxVolume = 2.6485366717E+10 m3
Max/Min = 8.7639258238E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 01235520)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 31 00:00:00
(Rec=0000002, Index=1, File: chsouth_boundary.nc)
(Min = -1.84981614E-01 Max = 1.40755355E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 31 00:00:00
(Min = -1.15769587E-01 Max = 3.85912329E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 31 00:00:00
(Min = -1.98467728E-02 Max = 4.95366976E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 31 00:00:00
(Min = -1.76414698E-02 Max = 5.85185885E-02)
GET_NGFLD - temperature eastern boundary condition, t = 31 00:00:00
(Min = 1.05293703E+00 Max = 2.67493687E+01)
GET_NGFLD - salinity eastern boundary condition, t = 31 00:00:00
(Min = 1.38240118E+01 Max = 3.46413422E+01)
GET_NGFLD - temperature southern boundary condition, t = 31 00:00:00
(Min = 0.00000000E+00 Max = 2.58873386E+01)
GET_NGFLD - salinity southern boundary condition, t = 31 00:00:00
(Min = 0.00000000E+00 Max = 3.45682297E+01)
0 0 00:00:00 0.000000E+00 8.478125E+03 8.478125E+03 8.829224E+14
(000,00,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: /public/home/wanglong/Projects/CHS/test/result/CHS_his_0001.nc
DEF_AVG - creating average file, Grid 01: /public/home/wanglong/Projects/CHS/test/result/CHS_avg_0001.nc
DEF_DIAGS - creating diagnostics file, Grid 01: /public/home/wanglong/Projects/CHS/test/result/CHS_dia_0001.nc
1 0 00:01:40 1.789299E-04 8.478029E+03 8.478029E+03 8.829224E+14
(100,96,01) 5.613402E-03 2.621833E-04 0.000000E+00 2.584277E-01
2 0 00:03:20 6.163918E-04 8.477838E+03 8.477839E+03 8.829227E+14
(184,51,20) 3.356748E-04 7.004853E-05 1.475031E+00 4.639972E-01
3 0 00:05:00 1.258552E-03 8.477614E+03 8.477615E+03 8.829237E+14
(185,48,20) 6.803756E-04 1.405660E-05 1.563733E+00 6.647432E-01
4 0 00:06:40 2.089459E-03 8.477373E+03 8.477375E+03 8.829252E+14
(186,48,20) 2.235542E-03 1.093114E-06 1.944758E+00 8.599670E-01
5 0 00:08:20 3.111652E-03 8.477134E+03 8.477138E+03 8.829271E+14
(187,48,20) 4.374491E-03 1.008752E-05 2.328212E+00 1.053392E+00
6 0 00:10:00 4.330676E-03 8.476909E+03 8.476914E+03 8.829294E+14
(190,46,20) 1.044480E-03 1.391924E-03 2.925310E+00 1.251163E+00
7 0 00:11:40 5.750702E-03 8.476699E+03 8.476704E+03 8.829320E+14
(189,49,20) 5.948986E-04 1.354592E-03 3.334080E+00 1.449143E+00
8 0 00:13:20 7.382219E-03 8.476502E+03 8.476510E+03 8.829346E+14
(190,47,20) 2.150543E-03 1.197780E-03 4.213287E+00 1.645868E+00
9 0 00:15:00 9.240417E-03 8.476318E+03 8.476328E+03 8.829374E+14
(189,48,20) 2.945573E-04 6.267164E-04 4.075286E+00 1.840354E+00
10 0 00:16:40 1.133784E-02 8.476147E+03 8.476158E+03 8.829402E+14
(082,98,20) 2.080882E-02 9.826687E-05 2.380251E+00 2.033919E+00
11 0 00:18:20 1.368169E-02 8.475987E+03 8.476001E+03 8.829432E+14
(081,98,20) 2.284108E-02 9.116569E-05 2.356497E+00 2.223963E+00
12 0 00:20:00 1.628796E-02 8.475840E+03 8.475856E+03 8.829461E+14
(081,98,20) 2.838376E-02 1.823538E-04 2.530111E+00 2.413136E+00
13 0 00:21:40 1.917915E-02 8.475704E+03 8.475723E+03 8.829490E+14
(080,98,20) 3.184099E-02 1.099705E-04 2.698820E+00 2.605837E+00
14 0 00:23:20 2.237130E-02 8.475579E+03 8.475601E+03 8.829518E+14
(188,48,20) 2.720186E-03 1.014868E-03 3.684499E+00 2.810083E+00
15 0 00:25:00 2.587583E-02 8.475462E+03 8.475488E+03 8.829546E+14
(187,48,20) 6.961907E-03 3.853289E-04 3.725498E+00 3.032715E+00
16 0 00:26:40 2.970996E-02 8.475351E+03 8.475381E+03 8.829574E+14
(187,48,20) 6.664531E-03 1.245864E-05 3.761336E+00 3.270852E+00
17 0 00:28:20 3.389597E-02 8.475242E+03 8.475276E+03 8.829602E+14
(189,48,20) 1.514998E-03 2.657766E-04 2.711070E+00 3.517918E+00
18 0 00:30:00 3.845877E-02 8.475131E+03 8.475169E+03 8.829631E+14
(077,98,20) 4.985909E-02 5.605878E-04 3.008470E+00 3.764849E+00
19 0 00:31:40 4.342550E-02 8.475018E+03 8.475061E+03 8.829659E+14
(076,98,20) 4.361423E-02 8.600033E-04 2.550401E+00 3.999212E+00
20 0 00:33:20 4.882572E-02 8.474906E+03 8.474955E+03 8.829688E+14
(076,98,20) 5.809759E-02 1.029236E-03 3.081947E+00 4.219616E+00
21 0 00:35:00 5.469145E-02 8.474800E+03 8.474855E+03 8.829720E+14
(076,98,20) 6.795970E-02 1.014750E-03 2.773882E+00 4.488508E+00
22 0 00:36:40 6.105677E-02 8.474700E+03 8.474761E+03 8.829755E+14
(075,98,20) 6.234720E-02 1.586861E-03 3.063894E+00 4.812606E+00
23 0 00:38:20 6.795814E-02 8.474604E+03 8.474672E+03 8.829794E+14
(075,98,20) 7.574510E-02 1.635204E-03 3.063914E+00 5.113439E+00
24 0 00:40:00 7.543802E-02 8.474508E+03 8.474584E+03 8.829837E+14
(074,98,20) 6.222094E-02 2.157962E-03 2.929051E+00 5.378895E+00
25 0 00:41:40 8.354390E-02 8.474409E+03 8.474493E+03 8.829886E+14
(074,98,20) 7.963354E-02 2.330817E-03 3.276937E+00 5.597764E+00
26 0 00:43:20 9.232835E-02 8.474306E+03 8.474398E+03 8.829939E+14
(074,98,20) 9.121120E-02 2.138314E-03 2.789197E+00 5.843395E+00
27 0 00:45:00 1.018468E-01 8.474199E+03 8.474301E+03 8.829998E+14
(073,98,20) 7.880304E-02 3.033585E-03 3.228117E+00 6.063732E+00
28 0 00:46:40 1.121592E-01 8.474093E+03 8.474206E+03 8.830062E+14
(073,98,20) 9.619793E-02 2.991791E-03 3.243239E+00 6.230914E+00
29 0 00:48:20 1.233324E-01 8.473992E+03 8.474116E+03 8.830132E+14
(071,97,20) 6.941703E-02 3.625552E-03 2.906709E+00 6.457778E+00
30 0 00:50:00 1.354417E-01 8.473898E+03 8.474034E+03 8.830207E+14
(072,98,20) 9.267275E-02 3.762039E-03 3.273025E+00 6.855489E+00
31 0 00:51:40 1.485587E-01 8.473810E+03 8.473959E+03 8.830287E+14
(072,98,20) 1.089115E-01 3.502214E-03 3.007492E+00 7.195881E+00
32 0 00:53:20 1.627721E-01 8.473727E+03 8.473889E+03 8.830371E+14
(071,98,20) 8.139794E-02 4.291825E-03 3.038932E+00 7.463352E+00
33 0 00:55:00 1.781643E-01 8.473644E+03 8.473823E+03 8.830457E+14
(071,98,20) 1.023752E-01 4.319977E-03 3.276868E+00 7.646356E+00
34 0 00:56:40 1.948384E-01 8.473563E+03 8.473758E+03 8.830544E+14
(071,98,20) 1.160307E-01 3.865038E-03 2.701805E+00 7.737092E+00
35 0 00:58:20 2.128781E-01 8.473481E+03 8.473694E+03 8.830634E+14
(070,98,20) 9.149097E-02 4.611385E-03 3.243355E+00 8.012538E+00
36 0 01:00:00 2.323620E-01 8.473400E+03 8.473632E+03 8.830725E+14
(070,98,20) 1.104856E-01 4.422625E-03 3.195967E+00 8.361815E+00
37 0 01:01:40 2.533687E-01 8.473319E+03 8.473572E+03 8.830819E+14
(069,98,20) 7.876480E-02 4.183685E-03 2.987151E+00 8.632169E+00
38 0 01:03:20 2.759588E-01 8.473237E+03 8.473513E+03 8.830914E+14
(069,98,20) 1.013995E-01 4.279415E-03 3.373946E+00 8.813875E+00
39 0 01:05:00 3.001408E-01 8.473156E+03 8.473456E+03 8.831011E+14
(069,98,20) 1.170150E-01 3.860999E-03 2.928909E+00 8.901033E+00
40 0 01:06:40 3.259519E-01 8.473075E+03 8.473401E+03 8.831110E+14
(068,98,20) 8.985717E-02 4.002488E-03 3.282169E+00 8.893317E+00
41 0 01:08:20 3.533475E-01 8.472996E+03 8.473349E+03 8.831211E+14
(068,98,20) 1.096720E-01 3.825629E-03 3.304661E+00 8.798172E+00
42 0 01:10:00 3.823576E-01 8.472918E+03 8.473300E+03 8.831315E+14
(067,98,20) 7.776326E-02 3.634346E-03 3.058456E+00 8.811698E+00
43 0 01:11:40 4.129811E-01 8.472841E+03 8.473254E+03 8.831420E+14
(067,98,20) 1.001394E-01 3.676213E-03 3.451956E+00 9.009731E+00
44 0 01:13:20 4.454346E-01 8.472763E+03 8.473208E+03 8.831524E+14
(074,33,20) 3.177135E-02 4.228970E-03 3.383427E+00 9.114218E+00
45 0 01:15:00 4.809424E-01 8.472683E+03 8.473164E+03 8.831627E+14
(066,98,20) 9.071340E-02 3.431107E-03 3.442409E+00 1.180460E+01
46 0 01:16:40 5.249684E-01 8.472602E+03 8.473127E+03 8.831729E+14
(066,98,20) 1.084213E-01 3.130223E-03 3.268604E+00 2.405290E+01
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001
Elapsed CPU time (seconds):
Thread # 0 CPU: 1266.517
Total: 1266.517
Allocation and array initialization .............. 4.169 ( 0.3292 %)
Ocean state initialization ....................... 1.059 ( 0.0836 %)
Reading of input data ............................ 0.030 ( 0.0024 %)
Processing of input data ......................... 0.168 ( 0.0133 %)
Processing of output time averaged data .......... 167.136 (13.1965 %)
Computation of vertical boundary conditions ...... 0.233 ( 0.0184 %)
Computation of global information integrals ...... 11.849 ( 0.9356 %)
Writing of output data ........................... 0.246 ( 0.0194 %)
Model 2D kernel .................................. 610.615 (48.2121 %)
2D/3D coupling, vertical metrics ................. 6.817 ( 0.5382 %)
Omega vertical velocity .......................... 6.685 ( 0.5278 %)
Equation of state for seawater ................... 6.485 ( 0.5120 %)
3D equations right-side terms .................... 55.380 ( 4.3726 %)
3D equations predictor step ...................... 84.623 ( 6.6816 %)
Pressure gradient ................................ 31.771 ( 2.5085 %)
Harmonic mixing of tracers, S-surfaces ........... 18.521 ( 1.4624 %)
Harmonic stress tensor, S-surfaces ............... 29.093 ( 2.2971 %)
Corrector time-step for 3D momentum .............. 129.143 (10.1967 %)
Corrector time-step for tracers .................. 92.967 ( 7.3404 %)
Total: 1256.990 99.2477
All percentages are with respect to total time = 1266.517
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Thursday - May 21, 2015 - 1:23:29 AM
rtopper
Re: very early blowing_up
#2 Unread post by rtopper »
Smoothing your bathymetry will probably solve your problem.
Your current rx0 and rx1 values are too high:
If you search this forum you'll find that rx0 values are usually recommended to be < 0.2 and rx1 ~ 5-8 (although Kate will tell you she runs her model with much higher rx1 values).
#3 Unread post by jcwarner »
if it blows up after 46 time steps, you could set NHIS = 5 (or so) and look at the output to see where things are going strange.
