This time I tried running the oceanG executable with lldb instead of gdb.
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
0 0 00:00:00 0.000000E+00 6.585677E+02 6.585677E+02 3.884376E+11
DEF_AVG - creating average file, Grid 01: ocean_avg.nc
Process 525 stopped
* thread #1: tid = 0x4536, 0x0000000100e2799c libnetcdff.5.dylib`__netcdf_MOD_nf90_create + 236, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0xc)
frame #0: 0x0000000100e2799c libnetcdff.5.dylib`__netcdf_MOD_nf90_create + 236
libnetcdff.5.dylib`__netcdf_MOD_nf90_create:
-> 0x100e2799c <+236>: movl (%r14), %eax
0x100e2799f <+239>: jmp 0x100e279a5 ; <+245>
0x100e279a1 <+241>: movl 0x48(%rsp), %eax
0x100e279a5 <+245>: testl %r9d, %r9d
(lldb) bt
error: unable to find CIE at 0x00000018 for cie_id = 0x00000004 for entry at 0x00000018.
error: unable to find CIE at 0x00000048 for cie_id = 0x00000004 for entry at 0x00000048.
error: unable to find CIE at 0x00000078 for cie_id = 0x00000004 for entry at 0x00000078.
error: unable to find CIE at 0x000000a8 for cie_id = 0x00000004 for entry at 0x000000a8.
error: unable to find CIE at 0x000000d8 for cie_id = 0x00000004 for entry at 0x000000d8.
error: unable to find CIE at 0x00000108 for cie_id = 0x00000004 for entry at 0x00000108.
error: unable to find CIE at 0x00000138 for cie_id = 0x00000004 for entry at 0x00000138.
error: unable to find CIE at 0x00000168 for cie_id = 0x00000004 for entry at 0x00000168.
error: unable to find CIE at 0x00000198 for cie_id = 0x00000004 for entry at 0x00000198.
error: unable to find CIE at 0x000001c8 for cie_id = 0x00000004 for entry at 0x000001c8.
error: unable to find CIE at 0x000001f8 for cie_id = 0x00000004 for entry at 0x000001f8.
error: unable to find CIE at 0x00000228 for cie_id = 0x00000004 for entry at 0x00000228.
error: unable to find CIE at 0x00000258 for cie_id = 0x00000004 for entry at 0x00000258.
error: unable to find CIE at 0x00000288 for cie_id = 0x00000004 for entry at 0x00000288.
error: unable to find CIE at 0x000002b8 for cie_id = 0x00000004 for entry at 0x000002b8.
error: unable to find CIE at 0x000002e8 for cie_id = 0x00000004 for entry at 0x000002e8.
error: unable to find CIE at 0x00000318 for cie_id = 0x00000004 for entry at 0x00000318.
error: unable to find CIE at 0x00000348 for cie_id = 0x00000004 for entry at 0x00000348.
error: unable to find CIE at 0x00000378 for cie_id = 0x00000004 for entry at 0x00000378.
error: unable to find CIE at 0x000003a8 for cie_id = 0x00000004 for entry at 0x000003a8.
error: unable to find CIE at 0x000003d8 for cie_id = 0x00000004 for entry at 0x000003d8.
error: unable to find CIE at 0x00000408 for cie_id = 0x00000004 for entry at 0x00000408.
error: unable to find CIE at 0x00000438 for cie_id = 0x00000004 for entry at 0x00000438.
error: unable to find CIE at 0x00000468 for cie_id = 0x00000004 for entry at 0x00000468.
error: unable to find CIE at 0x00000498 for cie_id = 0x00000004 for entry at 0x00000498.
error: unable to find CIE at 0x000004c8 for cie_id = 0x00000004 for entry at 0x000004c8.
error: unable to find CIE at 0x000004f8 for cie_id = 0x00000004 for entry at 0x000004f8.
error: unable to find CIE at 0x00000528 for cie_id = 0x00000004 for entry at 0x00000528.
error: unable to find CIE at 0x00000558 for cie_id = 0x00000004 for entry at 0x00000558.
error: unable to find CIE at 0x00000588 for cie_id = 0x00000004 for entry at 0x00000588.
error: unable to find CIE at 0x000005b8 for cie_id = 0x00000004 for entry at 0x000005b8.
error: unable to find CIE at 0x000005e8 for cie_id = 0x00000004 for entry at 0x000005e8.
error: unable to find CIE at 0x00000618 for cie_id = 0x00000004 for entry at 0x00000618.
error: unable to find CIE at 0x00000648 for cie_id = 0x00000004 for entry at 0x00000648.
error: unable to find CIE at 0x00000678 for cie_id = 0x00000004 for entry at 0x00000678.
error: unable to find CIE at 0x000006a8 for cie_id = 0x00000004 for entry at 0x000006a8.
error: unable to find CIE at 0x000006d8 for cie_id = 0x00000004 for entry at 0x000006d8.
error: libMODS.a(mod_netcdf.o) {0x00000876}: unhandled type tag 0x0012 (DW_TAG_string_type), please file a bug and attach the file at the start of this error message
* frame #0: 0x0000000100e2799c libnetcdff.5.dylib`__netcdf_MOD_nf90_create + 236
frame #1: 0x0000000100af6498 oceanG`netcdf_create(ng=0x00007fff5fbff8a4, model=0x00007fff5fbfeae8, ncname=0x0000000104a15cc0, ncid=0x0000000104a0c00c, _ncname=12) + 135 at mod_netcdf.f90:4283
frame #2: 0x000000010001b5f0 oceanG`def_avg(ng=0x00007fff5fbff8a4, ldef=0x0000000104a12600) + 1136 at def_avg.f90:69
frame #3: 0x000000010054571e oceanG`output(ng=0x00007fff5fbff8a4) + 26863 at output.f90:189
frame #4: 0x00000001004fcdbf oceanG`main3d(runinterval=0x0000000100da8f00) + 13793 at main3d.f90:214
frame #5: 0x0000000100001ab5 oceanG`roms_run(runinterval=0x0000000100da8f00) + 896 at ocean_control.f90:151
frame #6: 0x0000000100000df9 oceanG`ocean + 655 at master.f90:86
frame #7: 0x0000000100b7a296 oceanG`main(argc=1, argv=0x00007fff5fbffb20) + 37 at fmain.c:21
frame #8: 0x00007fff911935c9 libdyld.dylib`start + 1
I think I'll try rebuilding NetCDF and downloading an older version of GNU to fix this...I'll report back.
