How to convert potential temperature to temperature
Cool Findings and Plots
Alex5
#1 Unread post by Alex5 »
I want to calculate ocean heat content which is defined by temperature. Does anyone know how to convert potential temperature to temperature. Thanks.
Alex
Re: How to convert potential temperature to temperature
#2 Unread post by wilkin »
fdaryabor
#3 Unread post by fdaryabor »
Dear,
You can use the attachment file.
Hope can help you.
sw_temp.m
(1.86 KiB) Downloaded 1640 times
sw_ptmp.m
the complementary function,
sw_ptmp: Potential temperature
(3.6 KiB) Downloaded 1691 times
sw_temp.m
sw_temp: Temperature from potential temperature
(1.86 KiB) Downloaded 1537 times
Alex5
#4 Unread post by Alex5 »
Thanks a lot. I will try them. :D
Alex5
#5 Unread post by Alex5 »
wilkin wrote:There is a "seawater" toolbox
in Matlab
http://www.cmar.csiro.au/datacentre/ext ... awater.htm
or Python
https://pypi.python.org/pypi/seawater/
Dear Wilkin,
Could I ask another question, why roms use potential temperature instead of temperature? Actually, I am very new to ocean model, I am wondering if the ocean models prefer potential temperature. Thanks.
Alex
#6 Unread post by wilkin »
If you could put seawater in a container that insulates it from exchanging heat with any of the surrounding water, then move it from one depth to another, its temperature will change by virtue of the compression due to pressure. However, its potential temperature would not. That's basically the definition of potential temperature. So this is what we want in an ocean model - the model temperature only changes in response to heat exchange from surface fluxes or mixing with adjacent water of a different temperature. Just moving from one depth to another does nothing.
Alex5
#7 Unread post by Alex5 »
wilkin wrote:If you could put seawater in a container that insulates it from exchanging heat with any of the surrounding water, then move it from one depth to another, its temperature will change by virtue of the compression due to pressure. However, its potential temperature would not. That's basically the definition of potential temperature. So this is what we want in an ocean model - the model temperature only changes in response to heat exchange from surface fluxes or mixing with adjacent water of a different temperature. Just moving from one depth to another does nothing.
Thanks for your explanation. :D
