Potential bug in sfc_temp in albedo.F file
In Nonlinear/albedo.F file, the local variable sfc_temp (declared on line 185) is never set but used on line 258, 259, 263, 264, ... I suppose it should be set to variable tis (i.e., ice surface temperature).
Re: Potential bug in sfc_temp in albedo.F file
Yikes, right you are. tis is in Celcius though, not Kelvins. I pushed the update. Thanks!
