Problems with unforced model -- unrealistic circulation
Arvin_Yin
#1 Unread post by Arvin_Yin »
Hi,all
I am modeling the M2 internal tide in South China Sea. First I run the model without any forcing in the domain. The initial T/S are horizontally uniform. Initial velocity and ssh are set to zero. Then I run the model for two weeks. I thought that the ocean would remains at rest when unforced, but finally the model come out a circulation (see the following picture).
When I force the model with M2 tide, the suface Eulerian residual current come out a similar circulation. So, I think it does matters.
I wonder if there are something wrong with the model configuration. And my model configuration is:
TIDAL_FORCING
ANA_BSFLUX
ANA_BTFLUX
ANA_FSOBC
ANA_M2OBC
ANA_SMFLUX
ANA_SSFLUX
ANA_STFLUX
ASSUMED_SHAPE
DIFF_GRID
DJ_GRADPS
DOUBLE_PRECISION
GLS_MIXING
KANTHA_CLAYSON
MASKING
MIX_GEO_TS
MIX_S_UV
MPI
NONLINEAR
NONLIN_EOS
N2S2_HORAVG
POWER_LAW
PROFILE
K_GSCHEME
!RST_SINGLE
SALINITY
SOLVE3D
SPLINES
TS_U3HADVECTION
TS_C4VADVECTION
TS_DIF2
UV_ADV
UV_COR
UV_U3HADVECTION
UV_C4VADVECTION
UV_QDRAG
UV_VIS2
VAR_RHO_2D
VISC_GRID
zeta 1 Closed Chapman Exp Chapman Exp Chapman Exp
ubar 1 Closed Shchepetkin Shchepetkin Shchepetkin
vbar 1 Closed Shchepetkin Shchepetkin Shchepetkin
u 1 Closed Radiation Radiation Radiation
v 1 Closed Radiation Radiation Radiation
temp 1 Closed Radiation Radiation Radiation
salt 1 Closed Radiation Radiation Radiation
tke 1 Closed Closed Closed Closed
40320 ntimes Number of timesteps for 3-D equations.
1.0000E-01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
1.0000E-01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
6.5000E+00 theta_s S-coordinate surface control parameter.
2.0000E+00 theta_b S-coordinate bottom control parameter.
100.000 Tcline S-coordinate surface/bottom layer width (m) used
20130101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.6000E+02 Tnudg(01) Nudging/relaxation time scale (days)
3.6000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.0000E+01 Znudg Nudging/relaxation time scale (days)
3.0000E+01 M2nudg Nudging/relaxation time scale (days)
3.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
T VolCons(1) NLM western edge boundary volume conservation.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
T VolCons(4) NLM northern edge boundary volume conservation.
Thanks for your help!
Re: Problems with unforced model -- unrealistic circulation
It looks like the standard pressure gradient error-driven currents. What are your Beckmann and Haney numbers? You didn't show that. Is your stratification a function of z only?
Arvin_Yin
#3 Unread post by Arvin_Yin »
kate wrote:It looks like the standard pressure gradient error-driven currents. What are your Beckmann and Haney numbers? You didn't show that. Is your stratification a function of z only?
Thank you, Kate!
My Beckmann and Haney numbers are
Maximum grid stiffness ratios:
rx0 = 3.661005E-01 (Beckmann and Haidvogel)
rx1 = 2.942017E+01 (Haney)
I have 54 vertical levels, and
! Set vertical, terrain-following coordinates transformation equation and
! stretching function (see below for details), [1:Ngrids].
Vtransform == 2 ! transformation equation
Vstretching == 4 ! stretching function
! Vertical S-coordinates parameters (see below for details), [1:Ngrids].
THETA_S == 6.5d0 ! surface stretching parameter
THETA_B == 2.0d0 ! bottom stretching parameter
TCLINE == 100.0d0 ! critical depth (m)
Stratification function is about Transformation Equations and Vertical Stretching Functions in Vertical S-coordinate page on ROMS Wiki? I never change it , so I think it is a function of z only.
And can you tell me more about the standard pressure gradient error? Thanks.
Well, read the papers by Beckmann, Haney and Shchepetkin. Your rx numbers are similar to those I run with, but are considered quite large.
Arvin_Yin
#5 Unread post by Arvin_Yin »
Thanks.
I will read these papers. Then, what are the suitable range for rx numbers?
jpringle
#6 Unread post by jpringle »
When you are testing for the effects of pressure gradient error and topography, I would set all the boundaries to closed. I am worried about how the currents are reacting to both the northern and southern boundaries. I would not be surprised if the currents were substantially less if the boundaries were closed.
Essentially, open boundaries are hard. Pressure gradient errors are hard. Look at one at a time.
Jamie
#7 Unread post by kate »
It's a trade-off. There is some value for which the model will blow up, so you want to smooth the bathymetry to get it below that. If you smooth too much, you'll be solving a significantly different problem and the results could be misleading in that way. For instance, Bernard Barnier once told me a story of a current system where the real world had a surface current with an undercurrent vertically stacked over each other. In the model with smoothing, the shelf break isn't as steep and there's room for one current to be beside the other, which changes the stability properties, etc.
So I run what I run, knowing there are some currents due to pressure gradient errors. One hopes those currents are significantly smaller than the wind-driven currents. It is just one of many sources of error, however, what with errors in forcing fields, boundary conditions, lack of resolution, etc.
P.S. Lack of resolution contributes to pressure gradient errors.
rduran
#8 Unread post by rduran »
at the same time the signal can move around the domain when the boundaries are closed adding momentum each time it does, need to watch for that.
the rx parameters are not the whole story they are apriori upper bound estimates not sufficient conditions.
The following can help:
reduce number of sigma levels
decrease horizontal resolution,
smooth the bathymetry some more (specially where the error is biggest)
use a version of ROMS with a stiffened equation of state (I dont think ROMS rutgers has it and I dont know if getting it is a possibility)
combinations of the above
Edit: when I said "rx are apriori upper bound estimates not sufficient conditions" I meant the rx numbers recommended in the literature. It is not difficult to get considerable currents due to the pressure gradient with say r=0.2 (Beckman and Haidvogel r).
And regardless of whether your rx values are above or below the recommended values, it is not the end of the story, there are other things affecting the pressure gradient error not included in rx. The best way to know how much of an error you have is testing as described in the thread.
Arvin_Yin
#9 Unread post by Arvin_Yin »
Thank you for all the replies.
I will try one by one and report later.
rduran
#10 Unread post by rduran »
Sorry I meant to say increase horizontal resolution, as Kate said.
Either decrease vertical resolution (e.g. Decreasing number of sigma levels) or increase horizontal resolution, or both.
You have to see what is required for your application, what error is acceptable and what error is not.
