I recently switched machines and now I am having problems running my application. Hopefully, someone can point me in the right direction.
I compiled ROMS 3.7 on the new machine and was able to run the Upwelling Test Case successfully. I'm using the Intel compiler and NetCDF (4.3.2). When trying to run my own application I get the following error.
Thursday - March 5, 2015 - 7:21:07 PM
Shelf Test Case
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ftn
Compiler command : /opt/cray/craype/2.1.2/bin/ftn
Compiler flags : -dynamic -g -O0
Input Script :
SVN Revision : exported
Local Root : /home/mwandres/ROMS/trunk
Header Dir : /group/director967/mwandres/ROMS/SWAROMS/Run_01
Header file : shelf_test.h
Analytical Dir: /home/mwandres/ROMS/trunk/ROMS/Functionals
Resolution, Grid 01: 0658x0658x030, Parallel Nodes: 24, Tiling: 006x004
771120 ntimes Number of timesteps for 3-D equations.
40.000 dt Timestep size (s) for 3-D equations.
F LcycleRST Switch to recycle time-records in restart file.
90 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
0 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
2160 nAVG Number of timesteps between the writing of
T LuvSponge Turning ON sponge on horizontal momentum.
T LtracerSponge(01) Turning ON sponge on tracer 01: temp
T LtracerSponge(02) Turning ON sponge on tracer 02: salt
for tracer 02: salt
1 lmd_Jwt Jerlov water type.
2 Vstretching S-coordinate stretching function.
5.0000E+00 theta_s S-coordinate surface control parameter.
3.0000E-01 theta_b S-coordinate bottom control parameter.
100.000 Tcline S-coordinate surface/bottom layer width (m) used
20110101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
7.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
7.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
7.0000E+00 Znudg Nudging/relaxation time scale (days)
7.0000E+00 M2nudg Nudging/relaxation time scale (days)
7.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+01 obcfac Factor between passive and active
T LsshCLM Turning ON processing of SSH climatology.
T Lm2CLM Turning ON processing of 2D momentum climatology.
T Lm3CLM Turning ON processing of 3D momentum climatology.
T LtracerCLM(01) Turning ON processing of climatology tracer 01: temp
T LtracerCLM(02) Turning ON processing of climatology tracer 02: salt
T LnudgeM2CLM Turning ON nudging of 2D momentum climatology.
T LnudgeM3CLM Turning ON nudging of 3D momentum climatology.
T LnudgeTCLM(01) Turning ON nudging of climatology tracer 01: temp
T LnudgeTCLM(02) Turning ON nudging of climatology tracer 02: salt
T Hout(idu2dE) Write out 2D U-eastward at RHO-points.
T Hout(idv2dN) Write out 2D V-northward at RHO-points.
T Hout(idu3dE) Write out 3D U-wastward component at RHO-points.
T Hout(idv3dN) Write out 3D V-northward component at RHO-points.
T Aout(idu2dE) Write out averaged 2D U-eastward at RHO-points.
T Aout(idv2dN) Write out averaged 2D V-northward at RHO-points.
T Aout(idu3dE) Write out averaged 3D U-eastward at RHO-points.
T Aout(idv3dN) Write out averaged 3D V-northward at RHO-points.
Input Grid File: /group/director967/mwandres/SWAROMS_forcing/swaroms_grid.nc
Input Nonlinear Initial File: /group/director967/mwandres/SWAROMS_forcing/ini_swaroms_1.nc
Input Forcing File 01: /group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_1.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_2.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_3.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_4.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_5.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_6.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_7.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_8.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_9.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_10.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_11.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_12.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_13.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_14.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_15.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_16.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_17.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_18.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_19.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_20.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_21.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_22.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_23.nc
/group/director967/mwandres/SWAROMS_forcing/wind_swaroms_hourly_24.nc
Input Forcing File 02: /group/director967/mwandres/SWAROMS_forcing/heatflux_swaroms.nc
Input Forcing File 03: /group/director967/mwandres/SWAROMS_forcing/slp_swaroms_1.nc
/group/director967/mwandres/SWAROMS_forcing/slp_swaroms_2.nc
/group/director967/mwandres/SWAROMS_forcing/slp_swaroms_3.nc
Input Forcing File 04: /group/director967/mwandres/SWAROMS_forcing/shortwaveflux_swaroms.nc
Input Forcing File 05: /group/director967/mwandres/SWAROMS_forcing/SSS_swaroms.nc
Input Forcing File 06: /group/director967/mwandres/SWAROMS_forcing/SST_swaroms.nc
Input Forcing File 07: /group/director967/mwandres/SWAROMS_forcing/tide_swaroms.nc
Input Climatology File: /group/director967/mwandres/SWAROMS_forcing/clm_swaroms_5-daily.nc
Input Nudge Coefficients File: /group/director967/mwandres/SWAROMS_forcing/nudgcoef_swaroms.nc
Input Boundary File: /group/director967/mwandres/SWAROMS_forcing/bry_swaroms_daily.nc
Tile partition information for Grid 01: 0658x0658x0030 tiling: 006x004
tile Istr Iend Jstr Jend Npts
0 1 109 1 164 536280
1 110 219 1 164 541200
2 220 329 1 164 541200
3 330 439 1 164 541200
4 440 549 1 164 541200
5 550 658 1 164 536280
6 1 109 165 329 539550
7 110 219 165 329 544500
8 220 329 165 329 544500
9 330 439 165 329 544500
10 440 549 165 329 544500
11 550 658 165 329 539550
12 1 109 330 494 539550
13 110 219 330 494 544500
14 220 329 330 494 544500
15 330 439 330 494 544500
16 440 549 330 494 544500
17 550 658 330 494 539550
18 1 109 495 658 536280
19 110 219 495 658 541200
20 220 329 495 658 541200
21 330 439 495 658 541200
22 440 549 495 658 541200
23 550 658 495 658 536280
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 109.50 0.50 164.50 RHO-points
1 109.50 219.50 0.50 164.50 RHO-points
2 219.50 329.50 0.50 164.50 RHO-points
3 329.50 439.50 0.50 164.50 RHO-points
4 439.50 549.50 0.50 164.50 RHO-points
5 549.50 658.50 0.50 164.50 RHO-points
6 0.50 109.50 164.50 329.50 RHO-points
7 109.50 219.50 164.50 329.50 RHO-points
8 219.50 329.50 164.50 329.50 RHO-points
9 329.50 439.50 164.50 329.50 RHO-points
10 439.50 549.50 164.50 329.50 RHO-points
11 549.50 658.50 164.50 329.50 RHO-points
12 0.50 109.50 329.50 494.50 RHO-points
13 109.50 219.50 329.50 494.50 RHO-points
14 219.50 329.50 329.50 494.50 RHO-points
15 329.50 439.50 329.50 494.50 RHO-points
16 439.50 549.50 329.50 494.50 RHO-points
17 549.50 658.50 329.50 494.50 RHO-points
18 0.50 109.50 494.50 658.50 RHO-points
19 109.50 219.50 494.50 658.50 RHO-points
20 219.50 329.50 494.50 658.50 RHO-points
21 329.50 439.50 494.50 658.50 RHO-points
22 439.50 549.50 494.50 658.50 RHO-points
23 549.50 658.50 494.50 658.50 RHO-points
0 1.00 109.50 0.50 164.50 U-points
1 109.50 219.50 0.50 164.50 U-points
2 219.50 329.50 0.50 164.50 U-points
3 329.50 439.50 0.50 164.50 U-points
4 439.50 549.50 0.50 164.50 U-points
5 549.50 658.00 0.50 164.50 U-points
6 1.00 109.50 164.50 329.50 U-points
7 109.50 219.50 164.50 329.50 U-points
8 219.50 329.50 164.50 329.50 U-points
9 329.50 439.50 164.50 329.50 U-points
10 439.50 549.50 164.50 329.50 U-points
11 549.50 658.00 164.50 329.50 U-points
12 1.00 109.50 329.50 494.50 U-points
13 109.50 219.50 329.50 494.50 U-points
14 219.50 329.50 329.50 494.50 U-points
15 329.50 439.50 329.50 494.50 U-points
16 439.50 549.50 329.50 494.50 U-points
17 549.50 658.00 329.50 494.50 U-points
18 1.00 109.50 494.50 658.50 U-points
19 109.50 219.50 494.50 658.50 U-points
20 219.50 329.50 494.50 658.50 U-points
21 329.50 439.50 494.50 658.50 U-points
22 439.50 549.50 494.50 658.50 U-points
23 549.50 658.00 494.50 658.50 U-points
0 0.50 109.50 1.00 164.50 V-points
1 109.50 219.50 1.00 164.50 V-points
2 219.50 329.50 1.00 164.50 V-points
3 329.50 439.50 1.00 164.50 V-points
4 439.50 549.50 1.00 164.50 V-points
5 549.50 658.50 1.00 164.50 V-points
6 0.50 109.50 164.50 329.50 V-points
7 109.50 219.50 164.50 329.50 V-points
8 219.50 329.50 164.50 329.50 V-points
9 329.50 439.50 164.50 329.50 V-points
10 439.50 549.50 164.50 329.50 V-points
11 549.50 658.50 164.50 329.50 V-points
12 0.50 109.50 329.50 494.50 V-points
13 109.50 219.50 329.50 494.50 V-points
14 219.50 329.50 329.50 494.50 V-points
15 329.50 439.50 329.50 494.50 V-points
16 439.50 549.50 329.50 494.50 V-points
17 549.50 658.50 329.50 494.50 V-points
18 0.50 109.50 494.50 658.00 V-points
19 109.50 219.50 494.50 658.00 V-points
20 219.50 329.50 494.50 658.00 V-points
21 329.50 439.50 494.50 658.00 V-points
22 439.50 549.50 494.50 658.00 V-points
23 549.50 658.50 494.50 658.00 V-points
HaloSizeI(1) = 244
HaloSizeJ(1) = 354
TileSide(1) = 171
TileSize(1) = 19836
zeta 1 Chapman Exp Chapman Exp Chapman Exp Chapman Exp
ubar 1 Shchepetkin Shchepetkin Shchepetkin Shchepetkin
vbar 1 Shchepetkin Shchepetkin Shchepetkin Shchepetkin
u 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
v 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
SHELF_TEST Shelf Test Case
ADD_FSOBC Adding tidal elevation to processed OBC data.
ADD_M2OBC Adding tidal currents to processed OBC data.
ATM_PRESS Impose atmospheric pressure onto sea surface.
LMD_CONVEC LMD convective mixing due to shear instability.
LMD_MIXING Large/McWilliams/Doney interior mixing.
LMD_NONLOCAL LMD convective nonlocal transport.
LMD_RIMIX LMD diffusivity due to shear instability.
LMD_SKPP KPP surface boundary layer mixing.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
QCORRECTION Surface net heat flux correction.
SALINITY Using salinity.
SRELAXATION Surface salinity relaxation as surface flux.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_TIDES Add tidal currents to 2D momentum climatologies.
Process Information:
Node # 0 (pid= 26266) is active.
Node # 5 (pid= 26271) is active.
Node # 6 (pid= 26272) is active.
Node # 7 (pid= 26273) is active.
Node # 13 (pid= 26279) is active.
Node # 11 (pid= 26277) is active.
Node # 15 (pid= 26281) is active.
Node # 4 (pid= 26270) is active.
Node # 10 (pid= 26276) is active.
Node # 12 (pid= 26278) is active.
Node # 17 (pid= 26283) is active.
Node # 21 (pid= 26287) is active.
Node # 18 (pid= 26284) is active.
Node # 22 (pid= 26288) is active.
Node # 9 (pid= 26275) is active.
Node # 3 (pid= 26269) is active.
Node # 19 (pid= 26285) is active.
Node # 16 (pid= 26282) is active.
Node # 20 (pid= 26286) is active.
Node # 14 (pid= 26280) is active.
Node # 1 (pid= 26267) is active.
Node # 8 (pid= 26274) is active.
Node # 23 (pid= 26289) is active.
Node # 2 (pid= 26268) is active.
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0002280 -0.303 -1.678 -3.871 -4.592
28 -0.0666667 -0.0010668 -0.607 -3.387 -9.476 -12.703
27 -0.1000000 -0.0027513 -0.912 -5.138 -17.482 -25.688
26 -0.1333333 -0.0055210 -1.217 -6.943 -28.568 -44.927
25 -0.1666667 -0.0096191 -1.524 -8.814 -43.426 -71.823
24 -0.2000000 -0.0152929 -1.832 -10.765 -62.757 -107.798
23 -0.2333333 -0.0227930 -2.142 -12.806 -87.273 -154.299
22 -0.2666667 -0.0323729 -2.454 -14.952 -117.694 -212.786
21 -0.3000000 -0.0442884 -2.768 -17.214 -154.746 -284.733
20 -0.3333333 -0.0587960 -3.084 -19.606 -199.156 -371.618
19 -0.3666667 -0.0761512 -3.403 -22.141 -251.651 -474.915
18 -0.4000000 -0.0966065 -3.724 -24.830 -312.946 -596.077
17 -0.4333333 -0.1204077 -4.049 -27.687 -383.741 -736.522
16 -0.4666667 -0.1477897 -4.377 -30.723 -464.701 -897.603
15 -0.5000000 -0.1789710 -4.708 -33.949 -556.448 -1080.580
14 -0.5333333 -0.2141455 -5.043 -37.374 -659.531 -1286.570
13 -0.5666667 -0.2534730 -5.382 -41.007 -774.405 -1516.494
12 -0.6000000 -0.2970661 -5.725 -44.853 -901.388 -1771.000
11 -0.6333333 -0.3449735 -6.071 -48.915 -1040.620 -2050.370
10 -0.6666667 -0.3971582 -6.422 -53.191 -1191.995 -2354.391
9 -0.7000000 -0.4534709 -6.776 -57.674 -1355.089 -2682.201
8 -0.7333333 -0.5136145 -7.134 -62.347 -1529.059 -3032.089
7 -0.7666667 -0.5771002 -7.494 -67.188 -1712.517 -3401.237
6 -0.8000000 -0.6431915 -7.857 -72.160 -1903.373 -3785.403
5 -0.8333333 -0.7108346 -8.222 -77.208 -2098.633 -4178.510
4 -0.8666667 -0.7785693 -8.587 -82.262 -2294.154 -4572.146
3 -0.9000000 -0.8444192 -8.949 -87.221 -2484.325 -4954.920
2 -0.9333333 -0.9057532 -9.308 -91.954 -2661.674 -5311.668
1 -0.9666667 -0.9591133 -9.660 -96.289 -2816.386 -5622.462
0 -1.0000000 -1.0000000 -10.000 -100.000 -2935.686 -5861.372
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136460 0.1501639558342179
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649002
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792858
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911026
7 0.0054132615310267 0.0499970966129952 0.0054713292711215 0.3506690825040978
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405417
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876600
10 0.0161716623600090 0.0486998273761630 0.0421751148367486 0.4983983377638230
11 0.0207585511322367 0.0478912442581626 0.0629336659689853 0.5462895820219856
12 0.0257765478740990 0.0468533167015507 0.0887102138430843 0.5931428987235363
13 0.0311633730493853 0.0455644893078458 0.1198735868924696 0.6387073880313821
14 0.0368391158442262 0.0440063206553765 0.1567127027366958 0.6827137086867585
15 0.0427031802506397 0.0421643648631652 0.1994158829873354 0.7248780735499237
16 0.0486309868367616 0.0400292058506332 0.2480468698240970 0.7649072794005569
17 0.0544704302037591 0.0375976565087951 0.3025173000278562 0.8025049359093520
18 0.0600380921294285 0.0348741349986072 0.3625553921572847 0.8373790709079592
19 0.0651152103984763 0.0318722303921358 0.4276706025557610 0.8692513013000949
20 0.0694434033194839 0.0286164698722119 0.4971140058752449 0.8978677711723068
21 0.0727201499285569 0.0251442997062377 0.5698341558038018 0.9230120708785445
22 0.0745940258796570 0.0215082922098099 0.6444281816834588 0.9445203630883544
23 0.0746596950216180 0.0177785909158270 0.7190878767050768 0.9622989540041814
24 0.0724526566618460 0.0140456061647461 0.7915405333669228 0.9763445601689276
25 0.0674437485167025 0.0104229733316538 0.8589842818836253 0.9867675335005814
26 0.0590334053485720 0.0070507859058187 0.9180176872321973 0.9938183194064002
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740005 0.9996892670186999
29 0.0062146596259994 0.0003107329813000 0.9999999999999999 0.9999999999999999
Minimum X-grid spacing, DXmin = 9.15285382E-01 km
Maximum X-grid spacing, DXmax = 9.88519886E-01 km
Minimum Y-grid spacing, DYmin = 1.00465782E+00 km
Maximum Y-grid spacing, DYmax = 1.08378433E+00 km
Minimum Z-grid spacing, DZmin = 3.03237601E-01 m
Maximum Z-grid spacing, DZmax = 3.93635877E+02 m
Minimum barotropic Courant Number = 2.72384155E-02
Maximum barotropic Courant Number = 7.07848930E-01
Maximum Coriolis Courant Number = 3.41865647E-03
(Grid 01, File: ini_swaroms_1.nc, Rec=0001, Index=1)
- free-surface
(Min = -1.96265428E-01 Max = 6.32038935E-01)
(Min = -9.43264790E-01 Max = 9.74793862E-01)
(Min = -9.03534831E-01 Max = 1.00000000E+00)
- u-momentum component
(Min = -9.47758030E-01 Max = 9.99202279E-01)
- v-momentum component
(Min = -9.96947082E-01 Max = 1.00000000E+00)
- potential temperature
(Min = -4.77926821E-01 Max = 3.19486850E+01)
- salinity
(Min = 3.42487820E+01 Max = 3.90081289E+01)
GET_NGFLD - tidal period
(Min = 2.19720214E+04 Max = 2.38071314E+06)
(Min = 0.00000000E+00 Max = 1.76025754E-01)
(Min = 0.00000000E+00 Max = 6.28318504E+00)
(Min = 0.00000000E+00 Max = 6.28318450E+00)
(Min = 0.00000000E+00 Max = 6.28318508E+00)
(Min = 0.00000000E+00 Max = 1.47537251E-01)
(Min = -1.52269089E-02 Max = 2.78817677E-02)
GET_2DFLD - surface u-momentum stress, t = 0 00:00:00
(Rec=0000001, Index=1, File: wind_swaroms_hourly_1.nc)
(Tmin= 0.0000 Tmax= 15.5000)
(Min = -1.62303570E-04 Max = -1.71978371E-05)
GET_2DFLD - surface v-momentum stress, t = 0 00:00:00
(Min = 1.28578441E-06 Max = 1.91043474E-04)
GET_2DFLD - surface air pressure, t = 0 00:00:00
(Rec=0000001, Index=1, File: slp_swaroms_1.nc)
(Tmin= 0.0000 Tmax= 120.0000)
(Min = 1.00708039E+03 Max = 1.02067391E+03)
GET_2DFLD - solar shortwave radiation flux, t = 0 00:00:00
(Rec=0000001, Index=1, File: shortwaveflux_swaroms.nc)
(Tmin= 0.0000 Tmax= 364.0000)
(Min = -9.41877188E-06 Max = -4.61518713E-06)
GET_2DFLD - surface net heat flux, t = 0 00:00:00
(Rec=0000001, Index=1, File: heatflux_swaroms.nc)
(Min = -1.28562668E-06 Max = 1.79086748E-05)
GET_2DFLD - sea surface temperature climatology, t = 0 00:00:00
(Rec=0000001, Index=1, File: SST_swaroms.nc)
(Tmin= 0.0000 Tmax= 359.0000)
(Min = 1.73455747E+01 Max = 3.19748223E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 0 00:00:00
(Min = -7.34461548E-06 Max = -7.34461548E-06)
GET_2DFLD - sea surface salinity climatology, t = 0 00:00:00
(Rec=0000001, Index=1, File: SSS_swaroms.nc)
(Min = 3.53488108E+01 Max = 3.68430748E+01)
GET_NGFLD - free-surface western boundary condition, t = 0 00:00:00
(Rec=0000001, Index=2, File: bry_swaroms_daily.nc)
(Min = -2.68286541E-02 Max = 3.63557369E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 0 00:00:00
(Min = -1.11554898E-01 Max = 4.62492943E-01)
GET_NGFLD - free-surface southern boundary condition, t = 0 00:00:00
(Min = 7.69634396E-02 Max = 2.80776292E-01)
GET_NGFLD - free-surface northern boundary condition, t = 0 00:00:00
(Min = 2.11504012E-01 Max = 5.73245764E-01)
GET_NGFLD - 2D u-momentum western boundary condition, t = 0 00:00:00
(Min = -2.07402840E-01 Max = 1.71332672E-01)
GET_NGFLD - 2D v-momentum western boundary condition, t = 0 00:00:00
(Min = -1.10001653E-01 Max = 1.44644707E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 0 00:00:00
(Min = -2.40321144E-01 Max = 6.99999988E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -6.99999988E-01 Max = 6.99999988E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -1.20745249E-01 Max = -3.61825223E-03)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -1.44162789E-01 Max = 1.30990833E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 0 00:00:00
(Min = -5.13688684E-01 Max = 6.99999988E-01)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 0 00:00:00
(Min = -4.96419817E-01 Max = 6.99999988E-01)
GET_NGFLD - 3D u-momentum western boundary condition, t = 0 00:00:00
(Min = -5.66633761E-01 Max = 5.26594341E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 0 00:00:00
(Min = -3.41100842E-01 Max = 3.08129042E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 0 00:00:00
(Min = -3.73503655E-01 Max = 9.98474300E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -9.96947110E-01 Max = 1.00000000E+00)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -3.15203428E-01 Max = 1.17294788E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -3.67530793E-01 Max = 2.41186172E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 0 00:00:00
(Min = -5.52202940E-01 Max = 9.96099472E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 0 00:00:00
(Min = -6.23038769E-01 Max = 1.00000000E+00)
GET_NGFLD - temperature western boundary condition, t = 0 00:00:00
(Min = 3.00000000E+00 Max = 2.28988609E+01)
GET_NGFLD - salinity western boundary condition, t = 0 00:00:00
(Min = 3.42930183E+01 Max = 3.58285446E+01)
GET_NGFLD - temperature eastern boundary condition, t = 0 00:00:00
(Min = 3.00000000E+00 Max = 3.19392090E+01)
GET_NGFLD - salinity eastern boundary condition, t = 0 00:00:00
(Min = 3.43532906E+01 Max = 3.65564423E+01)
GET_NGFLD - temperature southern boundary condition, t = 0 00:00:00
(Min = 3.00000000E+00 Max = 2.03461266E+01)
GET_NGFLD - salinity southern boundary condition, t = 0 00:00:00
(Min = 3.43681564E+01 Max = 3.57434921E+01)
GET_NGFLD - temperature northern boundary condition, t = 0 00:00:00
(Min = 3.00000000E+00 Max = 2.99007492E+01)
GET_NGFLD - salinity northern boundary condition, t = 0 00:00:00
(Min = 3.43533630E+01 Max = 3.66022072E+01)
GET_2DFLD - sea surface height climatology, t = 0 00:00:00
(Rec=0000001, Index=1, File: clm_swaroms_5-daily.nc)
(Tmin= 0.0000 Tmax= 357.5000)
(Min = -1.96265429E-01 Max = 6.32038951E-01)
GET_2DFLD - vertically integrated u-momentum climatologt = 0 00:00:00
(Min = -9.43264782E-01 Max = 9.74793851E-01)
GET_2DFLD - vertically integrated v-momentum climatologt = 0 00:00:00
(Min = -9.03534830E-01 Max = 1.00000000E+00)
GET_3DFLD - u-momentum component climatology, t = 0 00:00:00
(Min = -9.47758019E-01 Max = 9.99202251E-01)
GET_3DFLD - v-momentum component climatology, t = 0 00:00:00
GET_3DFLD - potential temperature climatology, t = 0 00:00:00
(Min = -4.77926821E-01 Max = 3.19486847E+01)
GET_3DFLD - salinity climatology, t = 0 00:00:00
(Min = 3.42487831E+01 Max = 3.90081291E+01)
Maximum grid stiffness ratios: rx0 = 1.891907E-01 (Beckmann and Haidvogel)
rx1 = 9.528096E+00 (Haney)
Initial basin volumes: TotVolume = 1.4833127335E+15 m3
MinVolume = 2.9021897077E+05 m3
MaxVolume = 3.9720016771E+08 m3
Max/Min = 1.3686223428E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00771120)
GET_2DFLD - surface u-momentum stress, t = 0 01:00:00
(Rec=0000002, Index=2, File: wind_swaroms_hourly_1.nc)
GET_2DFLD - surface v-momentum stress, t = 0 01:00:00
GET_2DFLD - surface air pressure, t = 0 03:00:00
(Rec=0000002, Index=2, File: slp_swaroms_1.nc)
(Min = 1.00403318E+03 Max = 1.02082240E+03)
GET_2DFLD - solar shortwave radiation flux, t = 1 00:00:00
(Rec=0000002, Index=2, File: shortwaveflux_swaroms.nc)
(Min = -7.78145951E-06 Max = -2.18735630E-06)
GET_2DFLD - surface net heat flux, t = 1 00:00:00
(Rec=0000002, Index=2, File: heatflux_swaroms.nc)
(Min = 2.67841574E-06 Max = 2.55704424E-05)
GET_2DFLD - sea surface temperature climatology, t = 1 00:00:00
(Rec=0000002, Index=2, File: SST_swaroms.nc)
(Min = 1.75029559E+01 Max = 3.19824292E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 1 00:00:00
GET_2DFLD - sea surface salinity climatology, t = 1 00:00:00
(Rec=0000002, Index=2, File: SSS_swaroms.nc)
(Min = 3.54060870E+01 Max = 3.65095995E+01)
GET_NGFLD - free-surface western boundary condition, t = 1 00:00:00
(Rec=0000002, Index=1, File: bry_swaroms_daily.nc)
(Min = -9.49327350E-02 Max = 3.58419508E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 1 00:00:00
(Min = 1.36437759E-01 Max = 4.70546782E-01)
GET_NGFLD - free-surface southern boundary condition, t = 1 00:00:00
(Min = 1.04657732E-01 Max = 2.61275798E-01)
GET_NGFLD - free-surface northern boundary condition, t = 1 00:00:00
(Min = 2.24225312E-01 Max = 5.10675550E-01)
GET_NGFLD - 2D u-momentum western boundary condition, t = 1 00:00:00
(Min = -2.06651106E-01 Max = 1.78312749E-01)
GET_NGFLD - 2D v-momentum western boundary condition, t = 1 00:00:00
(Min = -6.12969995E-02 Max = 1.29566967E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 1 00:00:00
(Min = -2.95531243E-01 Max = 6.99999988E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 1 00:00:00
GET_NGFLD - 2D u-momentum southern boundary condition, t = 1 00:00:00
(Min = -1.20748602E-01 Max = 1.15296310E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -8.52280036E-02 Max = 1.21257253E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 1 00:00:00
(Min = -3.18091184E-01 Max = 6.99999988E-01)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 1 00:00:00
(Min = -4.16347772E-01 Max = 4.74890292E-01)
GET_NGFLD - 3D u-momentum western boundary condition, t = 1 00:00:00
(Min = -5.40363312E-01 Max = 5.47621965E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 1 00:00:00
(Min = -2.26476789E-01 Max = 2.31167585E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 1 00:00:00
(Min = -2.98738420E-01 Max = 9.95667160E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -9.97168422E-01 Max = 1.00000000E+00)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 1 00:00:00
(Min = -2.86866546E-01 Max = 9.49283466E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -2.28786692E-01 Max = 1.92137063E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 1 00:00:00
(Min = -3.57701629E-01 Max = 9.94913638E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 1 00:00:00
(Min = -4.87613171E-01 Max = 5.16477227E-01)
GET_NGFLD - temperature western boundary condition, t = 1 00:00:00
(Min = 3.00000000E+00 Max = 2.30262661E+01)
GET_NGFLD - salinity western boundary condition, t = 1 00:00:00
(Min = 3.42483292E+01 Max = 3.58303986E+01)
GET_NGFLD - temperature eastern boundary condition, t = 1 00:00:00
(Min = 3.00000000E+00 Max = 3.19610729E+01)
GET_NGFLD - salinity eastern boundary condition, t = 1 00:00:00
(Min = 3.43338356E+01 Max = 3.67156944E+01)
GET_NGFLD - temperature southern boundary condition, t = 1 00:00:00
(Min = 3.00000000E+00 Max = 2.06022377E+01)
GET_NGFLD - salinity southern boundary condition, t = 1 00:00:00
(Min = 3.43606453E+01 Max = 3.57745857E+01)
GET_NGFLD - temperature northern boundary condition, t = 1 00:00:00
(Min = 3.00000000E+00 Max = 3.19286232E+01)
GET_NGFLD - salinity northern boundary condition, t = 1 00:00:00
(Min = 3.44109764E+01 Max = 3.70000000E+01)
GET_2DFLD - sea surface height climatology, t = 2 12:00:00
(Rec=0000002, Index=2, File: clm_swaroms_5-daily.nc)
(Min = 3.58463125E-03 Max = 5.34310818E-01)
GET_2DFLD - vertically integrated u-momentum climatologt = 2 12:00:00
(Min = -2.78307229E-01 Max = 4.91491824E-01)
GET_2DFLD - vertically integrated v-momentum climatologt = 2 12:00:00
(Min = -5.65756917E-01 Max = 6.92312300E-01)
GET_3DFLD - u-momentum component climatology, t = 2 12:00:00
(Min = -4.47749317E-01 Max = 7.42663324E-01)
GET_3DFLD - v-momentum component climatology, t = 2 12:00:00
(Min = -6.94904327E-01 Max = 7.16680169E-01)
GET_3DFLD - potential temperature climatology, t = 2 12:00:00
(Min = -2.14943722E-01 Max = 2.55803528E+01)
GET_3DFLD - salinity climatology, t = 2 12:00:00
(Min = 3.43606720E+01 Max = 3.76055679E+01)
0 0 00:00:00 4.802833E-03 2.229103E+04 2.229104E+04 1.483609E+15
(649,368,30) 4.177157E-02 3.798408E-02 0.000000E+00 1.409943E+00
DEF_AVG - creating average file, Grid 01: ocean_avg.nc
DEF_VAR - unable to define variable: Tobc_in
in NetCDF file: ocean_avg.nc
Elapsed CPU time (seconds):
Node # 1 CPU: 16.937
Node # 5 CPU: 16.945
Node # 21 CPU: 16.941
Node # 18 CPU: 16.941
Node # 13 CPU: 16.937
Node # 17 CPU: 16.941
Node # 8 CPU: 16.937
Node # 15 CPU: 16.941
Node # 20 CPU: 16.941
Node # 16 CPU: 16.937
Node # 22 CPU: 16.945
Node # 19 CPU: 16.941
Node # 12 CPU: 16.941
Node # 23 CPU: 16.937
Node # 4 CPU: 16.937
Node # 10 CPU: 16.941
Node # 2 CPU: 16.941
Node # 7 CPU: 16.941
Node # 0 CPU: 16.569
Node # 9 CPU: 16.941
Node # 14 CPU: 16.941
Node # 11 CPU: 16.941
Node # 3 CPU: 16.941
Node # 6 CPU: 16.945
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS - Output error ............ exit_flag: 3
REASON: NetCDF: Invalid dimension ID or name
Application 2415487 resources: utime ~372s, stime ~39s, Rss ~556748, inblocks ~41898784, outblocks ~18636
** svn $Id: inlet_test.h 646 2013-01-22 23:35:19Z arango $
** Copyright (c) 2002-2013 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Inlet Test Case, waves-ocean (SWAN/ROMS) two-way coupling.
** Application flag: INLET_TEST
** Input script: ocean_inlet_test.in
** coupling_inlet_test.in
** sediment_inlet_test.in
#define ATM_PRESS
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#define SSH_TIDES
#define UV_TIDES
#define SPLINES
#define QCORRECTION
#define SRELAXATION
#define LMD_MIXING
#ifdef LMD_MIXING
#define LMD_RIMIX
#define LMD_CONVEC
#define LMD_SKPP
#define LMD_NONLOCAL
#define ADD_FSOBC
#define ADD_M2OBC
#define RADIATION_2D
Moritz
