I am having problems running a realistic test for a coastal region in the pacific mexican (my_application),but it fails:
Any ideas?
Thank you!
Brianda Oliva
An error in the run the test case (my_application)?
my_application.h
- (1.24 KiB) Downloaded 195 times
ocean_myapplication.in
- (40.28 KiB) Downloaded 188 times
error.dat
- (8.52 KiB) Downloaded 181 times
Re: An error in the run the test case (my_application)?
It's failing with:
Is that unclear?READ_PHYPAR - could not find input file: ocean_ini.nc
I do not understand the error message (READ_PHYPAR - could not find input file: ocean_ini.nc).
Only I want to use the ocean_grd.c, and configure files ana_mask,ana_fsobc,ana_m2obc.
