Error: unable to open existing NetCDF file
langlangxie
#1 Unread post by langlangxie »
Hi,everyone.
I have had some trouble in my ROMS.
Look :NLM: GET_STATE - Read state initial conditions, t = 0 00:00:00
(Grid 01, File: roms_ini_Y2001M1.nc, Rec=0001, Index=1)
- free-surface
(Min = 3.77269772E-01 Max = 9.62686659E-01)
(Min = -2.90209194E-01 Max = 2.30861325E-01)
(Min = -3.20704000E-01 Max = 1.98291190E-01)
- u-momentum component
(Min = -6.59128062E-01 Max = 4.74615451E-01)
- v-momentum component
(Min = -7.47192880E-01 Max = 8.06815021E-01)
- potential temperature
(Min = 1.18689602E+00 Max = 2.95576195E+01)
- salinity
(Min = 2.94315109E+01 Max = 3.49142715E+01)
I think my .nc have error,can you tell me some new suggestions.
My .h:
** svn $Id: weddell.h 25 2007-04-09 23:43:58Z arango $
** Copyright (c) 2002-2007 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Application flag: Control run for the Indian Ocean
** Input script: ioctl.in
/**************************** Basic physics options **************************/
#define MIX_GEO_TS /* mixing on geopotential (constant Z) surfaces */
#define MIX_S_UV /* use if mixing along constant S-surfaces */
/*************************** Basic numerics options **************************/
#define SPLINES /* use to activate parabolic splines reconstruction */
#define TS_U3HADVECTION /* define if 3rd-order upstream horiz. advection */
#define TS_C4VADVECTION /* use if 4th-order centered vertical advection */
!#define PROFILE /* use if time profiling */
/************************************ Outputs ********************************/
!#define DIAGNOSTICS_UV
!#define DIAGNOSTICS_TS
/*************************atmospheric boundary layer***********************************/
#define BULK_FLUXES
#ifdef BULK_FLUXES
#define COOL_SKIN
#define EMINUSP
#define LONGWAVE
#define SHORTWAVE
!#define ANA_HUMIDITY
!#define ANA__MASK
!#define ANA_SMFLUX
!#define ANA_SRFLUX
!#define ANA_STFLUX
!#define ANA_TAIR
!#define ANA_WINDS
/*********************** Surface and bottom boundary conditions **************/
/* Bottom boundary conditions */
#define ANA_BSFLUX /* analytical bottom salinity flux */
#define ANA_BTFLUX /* analytical bottom temperature flux */
#undef ANA_INITIAL
#define UV_QDRAG /* use to turn ON or OFF linear bottom friction */
/* Surface boundary conditions */
#define QCORRECTION
#define SCORRECTION
My .in:
GRDNAME == roms_grd.nc
ININAME == roms_ini_Y2001M1.nc
ITLNAME == ocean_itl.nc
IRPNAME == ocean_irp.nc
IADNAME == ocean_iad.nc
FWDNAME == ocean_fwd.nc
ADSNAME == ocean_ads.nc
BRYNAME == roms_bry_Y2001M1.nc
! CLMNAME == scs_clm_Y2001M1.nc
NFFILES == 2 ! number of unique forcing files
FRCNAME == roms_frc_CFSR_Y2001M1.nc |
roms_blk_CFSR_Y2001M1.nc
Thanks a lot!
xie
Re: Error: unable to open existing NetCDF file
You need to find out which file it's not reading. After the (successful) call to get_state, the next data calls are get_idata and get_data. Do you have any point sources? They would get set in your ocean.in file (LuvSrc and friends). If not, then it's going to your boundary, climatology and forcing files. How did you set all those options in your ocean.in?
