What does OBCFAC mean??
kobl1201
#1 Unread post by kobl1201 »
i use open boundary in ROMS model.
i was OBCFAC. it mean that ratio of inflow and outflow nudging time scale.
if i set OBCFAC = 1.0d0, what different effect between OBCFAC = 366.0d0 and OBCFAC = 1.0d0 for running model over 1 year.
my output average is 1 day, and M3NUDG = 1.0d0.
Re: What does OBCFAC mean??
If OBCFAC is 1, then both the incoming and outgoing timescales are the same. In general, we want the outgoing timescales to be longer, i.e., stronger nudging on inflow. That's OBCFAC > 1. Having M3NUDG=1 is setting the outgoing timescale to one day, stronger than I would recommend. If you are doing LBC=RadNud, you want the radiation to dominate on outflow.
#3 Unread post by wilkin »
Since this is a recurring topic I've updated the entries describing TNUDG and OBCFAC in the entry for ocean.in WikiROMS:
https://www.myroms.org/wiki/index.php/ocean.in
