bulk options
pooran
Location: Khoramshahr Marine Science and Technology Universi
bulk options
#1 Unread post by pooran »
dear
i turn on follow options:
#define BULK_FLUXES
# ifdef BULK_FLUXES
# define EMINUSP
# define EMINUSP_SSH
# define ALBEDO
# define CLOUDS
# define COOL_SKIN
!# define ANA_SRFLUX
!# define LONGWAVE
#define SHORTWAVE
and there are cloud fraction, surface air pressure (mb),air temperature at 2m (c),wind,rain fall(kilogram m-2 s-1),solar shortwave radiation flux (w/m2),net longwave radiation flux (w/m2 as force file.
1-ALBEDO and CLOUDS have not seen as activated options in output file. it means that they have not defined or it is common?
2- model SST is understimated. would you please help me how can increae it.
cheers
pooran
Re: bulk options
I'm not sure ALBEDO or CLOUDS are doing anything for you in the trunk code. ALBEDO shows up in ana_srflux.h, not in bulk_fluxes.
Can you provide incoming LONGWAVE instead of net? Then you can #define LONGWAVE_OUT based on your SST which will help limit your heat loss.
pooran
Re: bulk options
#3 Unread post by pooran »
do you mean downwelling longwave radiation flux?
lanerolle
Re: bulk options
#4 Unread post by lanerolle »
Yes, look at the LONGWAVE_OUT CPP. It allows to you to input downward longwave radiation flux while calculating the upward longwave radiation flux internally (in bulk_flux.F).
