TS_MPDATA with openMP issue
Honolulu_Wang
#1 Unread post by Honolulu_Wang »
I am using ROMS with TS_MPDATA scheme to calculate the vertical salinity profile in a real estuary. The platform I choose is Mac Pro(single working station, 8 processes), OS. When I choose openMP without TS_MPDATA(not define that in CPP), it works. However, when I choose TS_MPDATA (define TS_MPDATA in CPP) with openMP, it stops automatically, telling:
CHECKDEFS - cannot activate option: TS_MPDATA
in serial with partitions or shared-memory...
Use distributed-memory (MPI) in parallel runs.
Elapsed CPU time (seconds):
Then I comment that part in checkdefs.F in ROMS/Utility folder the recompile then to rerun.
It works! But could not make sure the results are correct are not, since I changed the code.
So is it due to that TS_MPDATA scheme could not be used under openMP environment ? If that , if we wanna to choose the good TS_MPDATA scheme to decrease numerical diffusivity, we have to use MPI?
arnaudlaurent
Location: Oceanography Department, Dalhousie University
Re: TS_MPDATA with openMP issue
#2 Unread post by arnaudlaurent »
I used to run ROMS with TS_MPDATA and OpenMP several years ago but it seems that this combination doesn't work anymore (not sure why). I just hit the same wall...
