blow up at first step as long as I turn on the bulk flux
shifei
#1 Unread post by shifei »
The atmospheric forcing variables are from NCEP2. As long as I turn on the BULK_FLUXES, it blows up at first step. No nans in the forcing file. However, I tryed the analytical values, it works ok.
my_subei_all.log
(47.6 KiB) Downloaded 903 times
Re: blow up at first step as long as I turn on the bulk flux
GET_2DFLD - surface u-wind component, t = 365 06:00:00
(Rec=0001462, Index=2, File: subei_Uwind.nc)
(Tmin= 0.0000 Tmax= 3652.7500)
(Min = 1.00000000E+35 Max = -1.00000000E+35)
GET_2DFLD - surface v-wind component, t = 365 06:00:00
(Rec=0001462, Index=2, File: subei_Vwind.nc)
GET_2DFLD - surface air pressure, t = 365 06:00:00
(Rec=0001462, Index=2, File: subei_Pair.nc)
GET_2DFLD - solar shortwave radiation flux, t = 365 06:00:00
(Rec=0001462, Index=2, File: subei_swrad.nc)
GET_2DFLD - downwelling longwave radiation flux, t = 365 06:00:00
(Rec=0001462, Index=2, File: subei_lwrad.nc)
GET_2DFLD - surface air temperature, t = 365 06:00:00
(Rec=0001462, Index=2, File: subei_Tair.nc)
GET_2DFLD - surface air relative humidity, t = 365 06:00:00
(Rec=0001462, Index=2, File: subei_Qair.nc)
GET_2DFLD - rain fall rate, t = 365 06:00:00
(Rec=0001462, Index=2, File: subei_rain.nc)
DO you see anything strange here? these min/maxs are not good. perhaps you have fill values in your data?
probably replace them with zeros or some other appropriate value.
shifei
#3 Unread post by shifei »
I have checked the data, it is just this problem. Thank you very much.
nacholibre
#4 Unread post by nacholibre »
Did you make sure that your atmospheric forcing file domain has a larger footprint than your ROMS grid? Interpolation onto your domain may have a problem otherwise...
Zafer
shifei
#5 Unread post by shifei »
ROMS seems only accept the longitude and latitude of monotonous increasing. If you provide the latitude like [30 29 28 27 26 25] instead of [25 26 27 28 29 30], the weird min/max values above appear.
lanerolle
#6 Unread post by lanerolle »
The easiest way to do this is to have another coarser grid that overlaps your model grid but is bigger in extent and put the met variables on this grid and get ROMS to internally do the interpolation when the model runs. Here is a sample ncdump of what I am doing (from my met NetCDF file):
Dimensions:
           xi_surf  = 91
           eta_surf = 111
           frc_time = 5857  (UNLIMITED)
Variables:
    frc_time
           Dimensions: frc_time
           Datatype:   single
           Attributes:
                       long_name = 'Forcing time'
                       units     = 'days'
    lon_surf
           Dimensions: xi_surf,eta_surf
           Datatype:   single
           Attributes:
                       long_name = 'Longitude location of surface forcing data points'
                       units     = 'degrees'
    lat_surf
           Datatype:   single
           Attributes:
                       long_name = 'Latitude location of surface forcing data points'
                       units     = 'degrees'
    Uwind
           Dimensions: xi_surf,eta_surf,frc_time
           Datatype:   single
           Attributes:
                       long_name   = 'Eastern component of the wind speed'
                       units       = 'm/s'
                       coordinates = 'lon_surf lat_surf'
                       time        = 'frc_time'
So my coarse grid dimensions are [xi_surf, eta_surf] and the (lon,lat) on this grid are called (lon_surf, lat_surf). All of my met variables are defined on this grid and when you do so, you need to put the additional NetCDF file attribute "coordinates = 'lon_surf lat_surf'" as shown above to tell ROMS that it needs to read-off the met variables from this coarser grid and thereafter do the interpolation internally.
When you put your met variables on this coarser grid, you have to ensure that the variable values are all meaningful and should exclude NaN, Inf, 1.0e+35, type values.
#7 Unread post by kate »
Not only that, but a theme I've been hearing this year is to not use land winds over the ocean. If your atmospheric model is coarse, you can easily end up using winds from the land portion of the atmospheric grid over the coastal ocean. I'm running a program to do an extrapolation of ocean fields into the land part of all my atmospheric fields.
lanerolle
#8 Unread post by lanerolle »
Yes, Kate is correct and sorry that I did not mention it in my message. I too avoid using winds over land during the interpolation and you may also want to look at air temperature and relative humidity/dew point over land and choose to exclude them if necessary - for some applications, I do this too.
#9 Unread post by wilkin »
You have min/max values of 1e+35
Obviously you having missing values in the netcdf file that are being interpolated to ROMS. You need to fill them with something sensible or remove them. Wind speeds of 1+35 m/s will certainly blow up on the first time step.
shifei
#10 Unread post by shifei »
Thank you very much :D
